#4005 |
Drives: 2013 FR-S Argento
you'll be fine, especially if you're running pump and don't abuse your clutch
Sent from my SM-N920V using Tapatalk |
#4006 |
Stuck In a Sandbox
Drives: FRS RS1.0
Picking up my kit from 86Speed in the next few days. im going with a tune from Delicious tuning as well. Does anyone know how much boost I should be safe with running completely stock everywhere else (clutch, internals, injectors, etc)? Question #2: am I okay running without an oil cooler if im just DD around town? I am getting the Skunk 2 Radiator with it and was wondering if that would suffice for your everyday spirited driving. TIA
#4007 | |
Drives: 2013 Ultramarine FR-S
Do not get the skunk 2 radiator. If it's the one with the built in oil cooler, it will require a lot of cutting and custom work. I don't use an oil cooler on mine and I just take it out in the summer for cruises and blasting around lakes up here. Everything else you should be fine. I think the boost is supposed to be around 9 psi? Been a while since I've looked |
#4008 | |
Stuck In a Sandbox
Drives: FRS RS1.0
im not sure if it is or not. 86Speed just said it came with the kit as a freebie. Im not one to complain about free stuff lol. Ill have to look into that a bit more. Thanks for the heads up
#4009 | |
Stuck In a Sandbox
Drives: FRS RS1.0
I believe its just the regular radiator without the built in oil cooler. The one with the oil cooler looks quite a bit thicker. is that what your reffering to with cutting? |
#4010 | |
Yeah the one with the oil cooler. The non-oil cooler one I have no personal experience with nor have I seen any threads on. |
#4011 | |
BoostedBRZ
Drives: Turbo BRZ
#4012 | |
Stuck In a Sandbox
Drives: FRS RS1.0
Thank you very much for the detailed response! I have full faith in the guys at delicious to give me a good tune. Im just hoping i dont come to regret getting this kit. There are a ton of people on here that bash the hell out of it.
#4013 | |
BoostedBRZ
Drives: Turbo BRZ
#4014 |
Drives: Scion FRS. Silver with black badges
What requirements are needed for this install? Like Injectors, fuel pump, etc
#4015 |
Drives: '13 Sport Tech
Just finished all 290 pages of this thread. Picked up a BRZ with the C30 kit, had latest pulleys and new belt installed yesterday when I bought the car. Has anyone made a video of setting belt tension? Would be super helpful if someone were to do so!
Thanks |
#4016 | |
BoostedBRZ
Drives: Turbo BRZ
Read through the thread or search as it's been answered numerous times. If you plan on c30 with no high boost pulley then you'll be fine stock everything. The clutch will probably eventually go. Anything else like high boost pulley, c38, e85, etc. You will need a fuel pump, bigger injectors, and a clutch.
#4017 | |
BoostedBRZ
Drives: Turbo BRZ
#4018 | |
Drives: frs
clutch - replace after (and if) the OEM goes while you still own the car. If I recall correctly I have not read threads when people street driving their cars with centrifugal SSs had to replace their stock clutch because it died. Most folks replace theirs because of suggestion like above (opinions, which are based on what?) or suggestions from shops/tuners (there's the ones making money off of you). |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
