Old 02-25-2014, 04:37 PM   #351
utekineir
blowhard
Drives: frs, project forester
Originally Posted by Ralph Spoilsport View Post
Crowding of the oil filter / sandwich plate area and the fact that the bumper has to come off for air filter service are the two significant annoyances of the KW kit. But I don't think either would stop me from buying it... and it's on my short list.
As far as CSG's IAT measurements (which are great to see, thanks Mike), remember that these are post IC measurements. Really what his measurements show is that the whole system (intake / compressor / intercooler) works.
Changing an sc belt on the side of the road could be called an annoyance as well.
I like the idea of at least having a functioning water pump if the belt were to snap.
utekineir is offline   Reply With Quote
Old 02-25-2014, 04:38 PM   #352
If anyone would like to volunteer, I'd like to get on-track measurements with a KW equipped car, so that I can make another thread showing ambient vs iat for the SC kits.
I already have data on the JR and Vortech kits.
Lap times are appropriate for the mods on each car, but more importantly, the amount of WOT time on the cars will be within a few percent, for the closest comparison possible, within reason.
Originally Posted by Zach3794 View Post
In any case...you're supercharging the car. Are you really gonna get all hot and bothered that you have to take the bumper off once a year or less? Really??? It takes 15 minutes max to take the bumper off..this is trade off for consistently better IAT's is definitely a worthy trade IMO.
Do you have data to actually prove that IATs are lower? It's difficult to get lower IAT than ambient...
Old 02-25-2014, 04:45 PM   #353
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
I did take a log yesterday..lemme check what they were.
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 02-25-2014, 04:53 PM   #354
Zach3794
My IAT's were around 28-30 degrees Celsius during my testing (albeit it was very short). So about 82-86 degrees. Temperatures did go up when the car sat at a red light, which I imagine is to be fully expected. I'm not saying the JR kit is worse, you've proven it isn't, but I imagine there are at least a few examples of kits with less than ideal locations for air intake. Ambient was around 73-75 degrees at time of testing yesterday.
Old 02-25-2014, 09:31 PM   #355
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
It'd be nice to have an outside source do these test so it's non biased. Nothing against the guys at CSG, but I get strong feeling of bias everytime they post in a S/C thread lol.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 02-25-2014, 09:33 PM   #356
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Liking a kit because it's good doesn't make you biased. Liking it because you are related to the company/people behind it is.
Sent from my Nexus 7 using Tapatalk
Mad1723 is offline   Reply With Quote
Old 02-25-2014, 09:34 PM   #357
Zach3794
I think CSG is gonna be about as non biased as it gets.
Old 02-25-2014, 09:37 PM   #358
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Way to state the fucking obvious. downing another kit because it wasn't the koolaid you drank is. Lol
Omar GC
Instagram: 2jzus
Old 02-25-2014, 10:15 PM   #359
Totally normal.
As you sit at a light, the IAT will go up, and as soon as you start moving, you'll see it drop, but it'll quickly go up again if you're at WOT. As long as you're matching ambient while cruising, the system is working. IAT goes up when you're sitting because the charge pipes are getting heated by the heat in the engine bay. As soon as air is flowing through the engine bay and the charge pipes (movement), it drops down.
What we'll be looking for is how much the rise is under extended WOT conditions; that'll expose how efficient the whole cooling system and piping solution really is.
Old 02-25-2014, 10:15 PM   #360
Zach3794
Sounds about right to me.
Old 02-27-2014, 02:56 PM   #361
ExcelerateRep
ExcelerateRep's Avatar
Drives: 2013 Crystal Black BRZ
Hey guys, just finished installing the kit on my BR-Z and I absolutely love it! Here are a couple of pics of it installed!
Don't want to take up too much space so here's the link to the Facebook Album:
https://www.facebook.com/media/set/?...2591963&type=3
ExcelerateRep is offline   Reply With Quote
Old 02-28-2014, 01:20 AM   #362
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
So I noticed one thing that differed from my install... I mounted my rotrex oil cooler to the top of the a/c condenser with the inlet and outlets on the bottom in fears of it being easier to fall off the condenser if I mounted the brackets to the lower section. My ride is extremely harsh/stiff 10k/11k spring rates and dampening near max stiff to daily lol.(have mine also mounted offset to the passenger side).
Anyone foresee any issues that would arise from this? So far with about 1300 miles on the setup everything seems fine.
Omar GC
Instagram: 2jzus
Old 02-28-2014, 03:18 AM   #363
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Have any of you owners of this kit managed to find an Engine Oil cooler kit that works around the KW setup? If not any hints when they will have one? Been "really" quiet from the KW guys in their upcoming stuff lately. Sorry likely wrong place to post, I'll also post this in KWs own thread but figured maybe some of you existing owners may have a more inside scoop?
Old 02-28-2014, 08:32 AM   #364
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
^this. Specifically are there any clearance issues going with the OEM Forester oil cooler/warmer option? I started logging my oil temps pre-install to get a baseline. How high are temps getting post-KW install without an engine cooler?
mit_peid is offline   Reply With Quote
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
