Old 07-02-2015, 02:14 PM   #3487
Scracho
Drives: 2018 Subaru BRZ
Originally Posted by BRZZZZZZZZZZ View Post
Sold my car a couple days ago, I will miss the S/C but not much else about the car...
What's the next project?
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
Old 07-02-2015, 02:18 PM   #3488
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Not so much a project, learn to drive in my Miata for a few years then maybe get a faster car or turn it into a Exocet? Continue to keep my T4R running, no mods for that other than some studded winters so I am unstoppable.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 07-03-2015, 02:57 PM   #3489
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
getting ready for the 4th of July track event at the Ridge Motorsports Park (Shelton, WA) I will be testing Racechrono's engine datalogging (previously used Torque App with Nexus 7) ..
clutch/brake fluid bleed is complete, changed the bleeder screws, engine oil, checked the belt tensioner.. let's see how the Ventus Z214s will hold up tomorrow
glamcem is offline   Reply With Quote
Old 07-05-2015, 07:58 PM   #3490
glamcem
glamcem's Avatar
Fourth of July spin.. I mean track!! event
@KraftWerks @moto-mike @Wonderbar
[ame="http://youtu.be/zj2_yBwBENY"]http://youtu.be/zj2_yBwBENY[/ame]
Old 07-06-2015, 01:10 PM   #3491
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
has anyone else have any experience with the kraftwerks/skunk2 oil cooler? Or any other oil cooler for that matter? I've had a few track days and I've gotten a way without using one, but I feel like I definitely need one. I just don't want oil spraying everywhere in the engine bay... Looking for some reviews or which one to buy vs. what not to buy.
Also, just to keep updated with my process, Kraftwerks customer service is amazing!!! Seriously CJ is the man, he has always replied to my responses promptly. On my second belt due to the first one ripping. I still think the 21mm rule is not a great way to start with how tight you want to use the belt, so maybe an update on that would be great for future kits. I'm currently running a flex fuel tune with a c38 running pretty much anywhere from e82-e86. Sadly no numbers My guess is a tad over 300whp with a conservative tune from Mike at Moto-East.
pgranberg11 is offline   Reply With Quote
Old 07-06-2015, 01:24 PM   #3492
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
There isn't really a good option for an oil cooler with this kit. Best one I've seen is the OEM forester oil to liquid cooler.
I had the KW oil cooler kit on for a while and took it off because it leaked, and I could never quite pin down the source. I'm thinking about using a custom spacer with the kit so i can run a thermostatic sandwich plate and new lines with a Setrab oil cooler.
Freeman is offline   Reply With Quote
Old 07-06-2015, 01:44 PM   #3493
Freeman
Freeman's Avatar
Originally Posted by Freeman View Post
SC made it to KraftWerksUS today. Will update on the warranty claim when I hear back. I know some are waiting to hear back on if rotrex will approve the warranty claim due to the cogged belt design.
well to update, the warranty claim got denied, so i bought a new blower and got it installed yesterday. belt tension currently at 61hz according to the app.
i should have the car back on the road by this weekend, i just have to take out the DSS drive shaft and tighten up the bolts at the header to overpipe connection.
no i dont know the reason it got denied, and if i ever hear back why i can update.
Old 07-06-2015, 05:36 PM   #3494
Jcl
Drives: 2014 BRZ
Could maybe do something like this? Use the kw sandwich run the lines to this then the setrab oil cooler.
http://www.summitracing.com/int/part...5792/overview/
Jcl is offline   Reply With Quote
Old 07-06-2015, 05:52 PM   #3495
FirestormFRS
Yes.
FirestormFRS is offline   Reply With Quote
Old 07-06-2015, 11:40 PM   #3496
Jcl
Drives: 2014 BRZ
That was on my list anyway but I didnt keep my kit long enough lol
Old 07-11-2015, 02:17 PM   #3497
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
Anything special needed to clean the air intake filter? I have the bumper off and just knocked the filter on the ground to shake off the loose dirt.
This isn't a wet filter is it?
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
Old 07-11-2015, 02:20 PM   #3498
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Kraftwerks Supercharger Owners Thread
I need to replace the 75mm pulley with a new 95mm pulley. I'm having a hard time removing the blower pulley cause it just spins. Any suggestions?
mit_peid is offline   Reply With Quote
Old 07-11-2015, 02:33 PM   #3499
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
TapatalkAttachment 114717
Do you have an extra belt handy? I heated up the bolt to loosen the loctite and then wrapped the extra belt around the pulley to hold it tight. Then I just tried to hold the belt as tight and steady as possible while putting all my weight onto the Allen wrench.
It was a pain, but I got all the bolts free after getting pissed off enough and building up adrenaline haha
KW V3
Old 07-11-2015, 10:43 PM   #3500
mit_peid
Boosted Noob
mit_peid's Avatar
Yeah I have an extra belt... How did you heat up the bolt.... one of my buddies suggested getting a pulley puller?
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
