Old 05-14-2015, 08:20 AM   #3333
vgi
Drives: frs
Originally Posted by fteightysix View Post
Im at 19.2 psi for just under a year and close to 15k miles.. been fine so far..
got some video coming soon, though the high speed pulls were done at over 4500 ft elevation and about 17psi , the other pulls show the normal boost around 19psi
-Thomas
It makes me want to fly to vegas just to see that beast.
vgi is offline   Reply With Quote
Old 05-15-2015, 11:35 AM   #3334
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I have so much fun on the C30 and stock pulley, I can't even imagine the bigger blower.
post_break is offline   Reply With Quote
Old 05-15-2015, 12:03 PM   #3335
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
The C30 is the sweet spot for stock internals and a daily driver I think. It sits right below the need for a new clutch, injectors, and all that jazz on 93 octane. E85 is a different story though. The stock injectors are probably pushed to their limits at high rpms on 93 octane so I would probably upgrade those, but I'll let someone who tunes make that decision.
The C38 is for crazy people, lol.
2016 Camaro SS is offline   Reply With Quote
Old 05-15-2015, 12:35 PM   #3336
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
C38 is fine with proper tuning. Nice thing with it is that there is almost no boost below 3k. This I feel puts much less wear and tear on the motor for this of us that are daily drivers.
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 05-15-2015, 09:29 PM   #3337
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We've done several c38's with and without the high boost pulley. Our sprintex 335 kit runs 19 psi starting from 4000 rpm (vs 6500 on the c38 KW kit). Some motors are weaker than others, sometimes you can employ tuning strategies to keep it together longer. Either way after hitting 427 on a stock motor with just 12-13 psi on a turbo today, I wouldn't let a single case get in the way of enjoying the high boost.
Xero-Limit is offline   Reply With Quote
Old 05-15-2015, 11:17 PM   #3338
Kojiro
Drives: 2014 Black BRZ Limited
I've had my c38 kit since January and it has been nothing, but fantastic.
Great job from Moto-East. They've both my stock c38 tune and tune with injectors.
I'm going to be getting a high boost pulley set up soon, but going to be getting
a stroker kit as well. Hopefully that'll be enough for the added boost.
Kojiro is offline   Reply With Quote
Old 05-16-2015, 04:18 PM   #3339
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
Hello fellow KW owners. Can someone take a peak at my datalog? I am currently working with Moto-East on a tune and this is the second revision. Mike has been good and been sending updates. I just want to see if my car is safe to drive in the mean time before he sends me the third revision. Since its the weekend, I probably wont hear from him till Monday.
Anyways, here is the datalog:
http://www.datazap.me/u/projek01/3rd...-cruise-111kmh
With my limited experience with tuning, I am worred about the fairly high fuel trim numbers and fairly consistant knock learn numbers.
Thanks for the help!
projek_01 is offline   Reply With Quote
Old 05-17-2015, 02:35 PM   #3340
SPCorBUST
SPCorBUST's Avatar
The "C38 is crazy and requires a built motor" argument doesn't really held any water. How many C38 owners running safely on stock motor and injectors or E85 plus a stock clutch will it take to change that mentality?
I'm probably biased because I've run the C38 and C30 on 91 and E85, but the latter is very noticeably slower. The C38 scared passengers and blew the doors off of RS5's, new M6's, etc. without flinching. The C30 on the otherhand, barely impresses. Again, maybe thats because I already experienced the other side, which skews my perspective. And some of that may be attributable to tune as well.
If you are buying an OTS from a tuner anyway, (because you don't need CARB where you are) then why not spend the extra $300 for more power everywhere? Perhaps later spending another $300 and switching to larger injectors for E85 and monstrous power? Seems like a no brainer.
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 05-17-2015, 11:09 PM   #3341
scionfr_s
scionfr_s's Avatar
Drives: Scion FR-S
Is there anyway to make the BOV make the phhh noise louder?
scionfr_s is offline   Reply With Quote
Old 05-17-2015, 11:14 PM   #3342
SPCorBUST
SPCorBUST's Avatar
The billet bypass valve is a little louder I think
Old 05-18-2015, 06:07 AM   #3343
autograph
autograph's Avatar
Drives: 6MT Hot Lava
@SPCorBUST -- out of curiosity, given your words in favor of the C38 blower, why did you choose the C30 JR kit that you currently have? (according to your signature)
autograph is offline   Reply With Quote
Old 05-18-2015, 07:21 AM   #3344
Billion
Drives: 2013 Toyota 86
Im guessing CARB Tune
Billion is offline   Reply With Quote
Old 05-18-2015, 08:12 AM   #3345
SPCorBUST
SPCorBUST's Avatar
Mostly CARB. After owning both kits though, I'd prefer a mix of the two, and have been thinking about if that could happen. Each kit has its virtues.
Old 05-18-2015, 08:14 AM   #3346
Billion
What do you prefer about the Jackson kit?
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
