Old 09-24-2014, 05:39 PM   #2143
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Local's BRZ we did, went for E85 couple weeks ago and finally brought the sheet by
86SPEED is offline   Reply With Quote
Old 09-24-2014, 07:23 PM   #2144
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
That's sweet, 300 I think is the sweet spot for me as well.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 09-24-2014, 08:51 PM   #2145
86SPEED
86SPEED's Avatar
Thats the only number i personally want.. 300 WHP.. i never really had a goal. and i know ill hit it 300 and im really happy with that.. the 400hp was fun to drive, but at the top of the first 3 gears its useless all id does is spin his 255's.. ill run the e85 because of the safety reasons, and i asked them to make is extremely safe.. id rather give 25hp and know ill be safe then try and push the limits..
Old 09-24-2014, 11:50 PM   #2146
Poodles
Drives: 2015 Series.Blue
PCV absolutely does not need a "valve," and I can name plenty of cars off the top of my head that don't run valves.
Regardless, it appears the twins do run one, but I haven't taken it apart myself to see.
Old 09-25-2014, 12:24 AM   #2147
gmsii
gmsii's Avatar
Crankcase ventilation (which I am assuming is what you are referring to) and PCV are not the same
gmsii is offline   Reply With Quote
Old 09-25-2014, 12:37 AM   #2148
Poodles
Incorrect: http://www.autoshop101.com/forms/h63.pdf
Regardless, valveless setup works under boost as well if it's routed correctly (as Toyota did for decades)
Old 09-25-2014, 08:25 AM   #2149
FR-S Matt
Dumb question, crank case is the one on the driver side? (Right side if you're facing the engine)
I've got Radium catch cans so I'm assuming I need a 1/2" checkvalve somewhere in that line going to the crank? I know the other line goes to the intake manifold, but the other line should be the crank case where you don't want it to see boost? Just making sure I understand it right.
and the direction of flow goes Crank case ---> Catch Can ----> Intake Manifold or the other way around?
I'm pretty sure you don't have to touch anything on the PCV side of things after reading about some of the turbo guys setups. It's mainly preventing the crank case from being pressurized.
Old 09-25-2014, 08:47 AM   #2150
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That is the way it is supposed to work as the vacuum produced in the intake manifold pulls the crankcase pressure out. The problem is that in a forced induction application not only does that vacuum go away under throttle, but you are now pressurizing the intake manifold which is then going to attempt to pressurize your crankcase reversing that flow without a check valve.
Old 09-25-2014, 09:33 AM   #2151
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Check valves are like $5. They should just be installed for piece of mind knowing you're not putting 10PSI into the crank case regardless if there is a valve stock or not. Herp derp it does it doesn't have one stock, just put one in and be done knowing that it has one since you put it in.
post_break is offline   Reply With Quote
Old 09-25-2014, 11:03 AM   #2152
gmsii
gmsii's Avatar
this is like the third time this thread has veered off into 'check valve catch can land'......can we get it back on topic which is the KW SC kit? lol
Old 09-25-2014, 11:44 AM   #2153
myd_lyf_crysys
myd_lyf_crysys's Avatar
Drives: 2013 Asphalt FR-S
Originally Posted by Freeman View Post
Nice, looks like its time for me to get back over and see Bob for tuning.
What's your exhaust setup like?
AVO 2.5" header-back
myd_lyf_crysys is offline   Reply With Quote
Old 09-25-2014, 07:34 PM   #2154
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I've seen this video on @KraftWerks Facebook page, good explanation of the system
[ame="http://youtu.be/EIR8GZxcfZ4"]http://youtu.be/EIR8GZxcfZ4[/ame]
glamcem is offline   Reply With Quote
Old 09-25-2014, 07:37 PM   #2155
86SPEED
86SPEED's Avatar
Talking
@glamcem
I was just coming to post this.
Old 09-25-2014, 07:52 PM   #2156
86SPEED
86SPEED's Avatar
Originally Posted by myd_lyf_crysys View Post
Got the car back on Saturday and made the 4 1/2 hour trip back home... The car finally goes as good as it looks!
@Drift_Office was kind enough to snap a few pictures during the install.
To @KraftWerks, @Drift_Office and @fteightysix...
Awesome - Shoot us an email on how much you love it
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
