Old 06-29-2014, 11:24 AM   #1709
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by supertwo View Post
Can you run a Jackson Racing CARB legal tune on KW supercharger???
It will not work. The Jackson Racing CARB Tune uses the MAF sensor for determining load and has a particular piping setup for their MAF. Where as the piping on the Kraftwerks kit is different and most of these tunes are based on Speed Density. Plus without actually owning a Jackson Racing Kit, I do not think you could even order a CARB tune from them legally.
Cheers,
William Knose
Old 06-29-2014, 11:41 AM   #1710
captain_jack
captain_jack's Avatar
Cheers,
William Knose
Pretty much what I said and thought.thanks for confirming
Old 06-29-2014, 08:20 PM   #1711
supertwo
Drives: 2014 BRZ
Red face
Cheers,
William Knose
I bought a used Kraftwerks kit but without ECUTEK. Can I purchase an Ecutek with tune from you guys? Please excuse my ignorance but what exactly makes any of these kits CARB legal.
Is there any chance I can pass Maryland emmisions with this kit installed?
supertwo is offline   Reply With Quote
Old 06-30-2014, 12:06 PM   #1712
DeliciousTuning
Unknown on the rules and regulations and areas of Maryland. You would need to do some research to know what is legal or not.
As for actual CARB certification, you need to purchase the tune directly from the company that had it approved and have it installed on their kit they had CARB approved.
Cheers,
William Knose
Old 06-30-2014, 12:36 PM   #1713
FR-S Matt
So what is the exact side of the check valve we should use? I ordered those plastic ones in a post earlier and they seem a bit small for the 1/2" hose for the radium catch can crank case side. I probably need just a bigger one to match that size. I assume that plastic one is for the stock hose on the crank side.
Old 06-30-2014, 12:37 PM   #1714
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I put mine on the 5/8" hose that goes from the catch can to the crank case nipple on the block.
post_break is offline   Reply With Quote
Old 06-30-2014, 12:44 PM   #1715
FR-S Matt
So as long as it's somewhere on that long hose coming from the catch, it doesn't matter where the valve is placed as long as it's pointing towards the crank case? Also, double spring clamping both sides, or worm clamps? This might be worthy of making a post specifically about it.
Old 06-30-2014, 12:49 PM   #1716
post_break
post_break's Avatar
You want air to flow from the crank to the catch can, not the other way around. I have no clamp on the block nipple since the pressure stops at the check valve. Put clamps on the check valve obviously.
Old 06-30-2014, 12:54 PM   #1717
FR-S Matt
Glad I double checked. Thank you sir!
Old 06-30-2014, 01:21 PM   #1718
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
@supertwo, yes we can sell the Ecutek and tune. It's hard to speak about passing in MD as we do not know the smog or vehicle regulations there.
KraftWerks is offline   Reply With Quote
Old 06-30-2014, 06:00 PM   #1719
D-VO
Drives: Whiteout FR-S, Evo 8 RS
I'm still in the middle of some tuning (having issues with fueling)and currently only doing 2nd gear passes for safety, but power wise this is where I'm at:
D-VO is offline   Reply With Quote
Old 06-30-2014, 10:12 PM   #1720
supertwo
Drives: 2014 BRZ
Can you please PM me with pricing for the Ecutek and tune??
Old 07-01-2014, 08:16 AM   #1721
vgi
Drives: frs
looking good. are you monitoring mafv? what's your voltage at 7400?
also, are you getting tip-in knock when driving?
vgi is offline   Reply With Quote
Old 07-01-2014, 03:29 PM   #1722
D-VO
No knock at WOT or tip in only in a small area down at 2100RPM. MAF Volts have been around 4.7 - 4.8 at 7400RPM. I also removed about 3 degrees of timing from 5000rpm - 7600RPM until I get the AFR's right.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
