#1639 |
What is the latest status on the valve spring recall?
Are people still doing it? Or did everyone who is gonna do it, already do it? I never did the recall. I doubt I will bother at this point. Who else decided to skip the recall ? |
#1640 | |
I did it early on, and have had no issues, but if given the choice again and given my car had 100K miles on it at the time, I would not bother. At the time I used it as some "free labor" to get other work done such as changing plugs, etc. The general agreement seems to be skip it because if they were going to fail, it's likely they already would have.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#1641 |
I'm at 60k miles, and don't plan to bother with the recall.
Was just curious if dealers are still screwing up the repair |
#1642 |
Drives: '13 Whiteout
#1643 | |
Not sure if there is a place you can get the progression on a recall (how many are complete) but that would be interesting.
#1644 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Necro.
My car was on PNO for the past 4 years so never did the recall. California forced me to do the recall before I could reactivate my registration. I feel like I just started the clock to my car's demise ![]() -- Is there anything I can do to verify the sealant was properly placed?
#1645 | |
LMGTFY
Drives: 13 FRS, 91 Miata
#1646 |
Addicted
Forgive my lack of knowledge here, how difficult is it to drop the oil pan to inspect? Is it as simple as lifting the car and accessing it or is more disassembly required?
Are there any DIY guides or YT videos I can reference? I checked around but don't see anything definitive. Thank you!
#1648 |
That will tell you if there is sealant in the pickup tube but not if any of the channels were plugged. Unfortunately the only way to check that would be t I pull the timing cover which means you have to reseal and be back to not knowing.
#1649 | |
Many of the failures occurred before Subaru issued the updated instructions and tech awareness was low. They are all well aware by now! Not to say that it couldn’t still happen but the odds are much much lower now than they were 4 years ago. Even if you pull the pan and see sealant a shady dealer isn’t going to do anything about it anyway. A good dealer may but even then if it hasn’t failed then there is no issue in their mind.
#1650 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Got my springs done last winter. Aintn't broke yet. 0.02
Been out to the ocean a few times and out to the races this weekend. Don't feel bad. Stuff happens and you get over it.
"I gotta rock." -- Charley Brown |
#1651 |
Drives: 2023 GR86
Vehicle Mileage: 66,096
Vehicle Make: Scion FR-S 2013 Mileage After Recall Performed: 63,716 (done twice, first one at 51,216) Symptom(s): Engine knocking after a hard pull from a stop sign on a highway on-ramp, headed uphill. Loss of power before eventual stall. Failure: Crankshaft rod bearing failure. Dealer quoted $7k+ to replace only the lower end and send some parts out for machining. Resolution(?): None yet, currently reaching out to corporate. Initially got the GM to agree on a trade-in value towards a GR86, but they have no idea when they'd get one (friend said he waited over a year!?) and the trade-in would drop as time goes by. Backtracked and now seeking repairs. State: Milford, CT, USA Dealership Offering Repair: Colonial Toyota This was a bit of a saga. I brought it in for the J02 recall initially at 51,216, but it always had a small leak around the timing cover and I brought it back 6 times over 3 years to have it "fixed". They kept pulling and resealing the timing cover, as well as completely replaced it, before having a regional specialist come out who decided the valve cover wasn't sealed properly during the recall. So they pulled the engine and sealed the valve cover a second time. This was right before winter, so I was barely driving it before April when this happened. The car's never been tracked, autox'ed, redlined, or otherwise thrashed as it's my daily. Credit where it's due, they never charged me for the repairs up until this point and always comp'ed a rental. UPDATE: Dealer's buying out the car in cash and I've got a reserve on an incoming '23 GR86 somewhere else. Life's good Last edited by Dylan; 05-26-2023 at 02:40 PM. |
#1652 | |
Drives: 2018 Subaru BRZ Limited with PP
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
