#435 |
Drives: "14 BRZ Limited - SWP
Are you able to use the header for N/A? I plan to get the ptuning kit later on but no funds yet :/.
#437 | |
Seems Legit
Drives: Toyota
PTUNING Turbo Kit Owners Topic
Seeing as how the ptuning turbo system is designed to be used without replacing the factory header, I would say their race header follows the same path as the stock header.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
#438 |
Seems Legit
Drives: Toyota
Prototype header design
#440 |
Drives: 2014 Forester XT, Porsche 944
Will the header fit with the factory front heat shield like you previously mentioned in this thread?
#441 |
Drives: White FR-S
#442 |
Drives: White FR-S
Here are some teaser pics of our finalized prototype PTUNING 4-1 EL Race Header. Production on the header is already under way. Multiple fixtures are currently being made for the production of this header. Please ignore the multiple small sections used in this prototype as we were continuously tweaking the individual runner lengths. The production headers will utilize the fewest number of weld joints possible.
Here are a couple of design goals we had for our 4-1 Header: - Clears factory metal undertray without modifications or spacers. - No extremes upturns in the header at the front of the engine means less heat transmitted into the engine compartment. - Closest to equal length runners as possible. We purposely made runners 1 and 4 shorter to compensate for the offset exhaust ports on the FA20 cylinder heads. This ensures that the overall runner length from the exhaust valves to the merge collector outlet are roughly the same length between all cylinders. - Rotational firing order through the merge collector for optimum exhaust scavenging. - Double-slip merge collector. This style merge collector is uber expensive to implement. It does away with flex joints, yet still allows for proper heat expansion on a boxer engine. - Custom stainless spring retention system to allow for heat expansion at the collector (Not shown in pics). - Full T304 Stainless Steel construction. This includes the CNC machined head flanges, V-band connection, and 2-bolt flange. - As always, our products are 100% made in the USA using only premium grade Domestic stainless steel. ![]() - Toan ![]() ![]()
| The Following 10 Users Say Thank You to ptuning For This Useful Post: | bjun (07-08-2014), buddy32 (07-08-2014), Darryljr11 (07-08-2014), Dinko (07-08-2014), ecko04 (07-08-2014), kanundrum (07-08-2014), mkivsoopra (07-08-2014), mnsayer (07-09-2014), OICU812 (07-08-2014), rb6freak (07-09-2014) |
#444 |
Drives: white premium brz M/T
Ah can't wait! Any info on the sound?
| The Following User Says Thank You to bjun For This Useful Post: | Mrc@ptuning (07-09-2014) |
#445 |
Just a dude
Drives: Scion FR-S 2013
The header looks great, long awaited but great indeed. I figure since it's looking like FI is not happening for me this season that by next spring PT should by then finally have all their kit bits ie: header, lava oil cooler etc all available day one when a person wants to order. As much as I admire several other kits (actually just a few) when it comes to Turbo I really do like a lot of the details in this kit overall.
| The Following User Says Thank You to OICU812 For This Useful Post: | Mrc@ptuning (07-09-2014) |
#446 |
Drives: White FR-S
#447 |
Drives: White FR-S
This header, when used with our PTUNING Turbo System will be slightly louder than the stock header at idle and cruising speeds. It will be moderately louder at WOT. It definitely sounds awesome when coupled with our 3" dual exhaust system.
![]() - Toan |
| The Following User Says Thank You to ptuning For This Useful Post: | bjun (07-14-2014) |
#448 |
Drives: 1980 corvette, 2014 Subaru BRZ
any pricing/availability/dyno? I am very interested to use this NA until I turbo.
| Tags |
| ptuning, turbo kit |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 11:46 AM |
| Full Blown Turbo Kit Owners Topic | King Tut | Forced Induction | 2637 | 12-27-2020 04:44 PM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 01:36 PM |
| P&L Turbo Owners Topic Thread | GTB/ZR-1 | Forced Induction | 4 | 09-01-2013 07:27 PM |
