go_a_way1
Old 11-18-2014, 06:29 PM   #7911
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by robwbright View Post
Guess I shoulda pushed for that money back guarantee. LOL.
I'll figure it out.
Installed Mods:
Old 11-18-2014, 07:27 PM   #7912
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
went back to 93 tune, even with the cold it always starts on the first crank for me. I have the ESC set to auto off, no other electrical mods. I did notice the cold causing my starter to sound weaker, but I'm still on the factory starter battery, so I should have enough reserve for multiple cranks if necessary.
The Following User Says Thank You to Target70 For This Useful Post:
raven1231 (11-18-2014)
Old 11-18-2014, 08:14 PM   #7913
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
I am also back on 93 octane for now - similar experience to what's described above. Cranked it and cranked it and the battery died, had to jump it to get it started. Switched back to 93 and it starts right up.
My thought is that I had e85 in my tank that was put in there when the weather was warmer, and maybe the local station had not yet switched over to the e60 (i think) for the colder weather. I suspect that if, after I finish this tank of 93, I could switch back again without the issues I'd been seeing recently.
VR46 is offline   Reply With Quote
Old 11-18-2014, 08:17 PM   #7914
DAEMANO
Time Traveller
When the weather turns "cold" I put 2 gallons of CA91 to 9 gallons of E85 and the car starts on the 1st or 2nd crank. If I try to start it on 100% e85 it could take several cranks above that. Add a lil pump gas to your e85 and you're golden.
Old 11-18-2014, 08:35 PM   #7915
TM
TM's Avatar
Drives: DGM BRZ 6MT
The disconnected the wires to the battery, tightened the nut on the positive terminal down, and reconnected everything. Not very fun doing it in my complex's parking lot in the snowing 20F weather in the dark. The initial start up took 5-6 cranks and then started up. But it's usually the mornings after a long winter night where it wouldn't start up. So it's see how tomorrow morning goes.
TM is offline   Reply With Quote
The Following User Says Thank You to TM For This Useful Post:
DAEMANO (11-18-2014)
Old 11-18-2014, 08:41 PM   #7916
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
If you've been driving around with a loose/poor connection, your battery may be in a low state of charge. It might take an hour of operation to get the battery to hold 12.8-12.9 VDC.
Also, this time of year you should be using the recommended 0w20 oil.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
The Following User Says Thank You to Gary in NJ For This Useful Post:
Old 11-18-2014, 09:27 PM   #7917
predator800
Drives: 2015 Scion FRS
Out of curiosity. For those of you were the battery is failing, how long is your drive everyday. Time wise. Just wondering if it's not getting fully charged between runs. Even if this a problem, my name is staying on the waiting list. I was planing on taking off the supercharger in the winter. Would be nice to keep it all winter though.
predator800 is offline   Reply With Quote
Old 11-18-2014, 09:44 PM   #7918
Sojhinn
Sojhinn's Avatar
There are some with issues and some with out. We are trying tofind out where the issue is. Maybe we should compile a list of devices. Also a voltage reading on the battery would help to see if there's a drain.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
predator800 (11-18-2014)
Old 11-18-2014, 09:49 PM   #7919
TM
TM's Avatar
Drives: DGM BRZ 6MT
My drive is about 15 minutes to a meeting downtown. After 2-3 hours, drive 20 minutes back to office. May or may not go out for lunch. 4-5 hours later, 30 minute drive back home or to the gym, and if I do go to the gym, another 10 minutes to drive home after 1.5 hours of working out.
I'll be storing it for the winter in 4 weeks. Hope I can make it that long.
Old 11-19-2014, 10:52 AM   #7920
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
What is this "auto off" setting on the ESC? I must have missed something. I just use the switch on the meter to turn it off.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 11-19-2014, 10:54 AM   #7921
robwbright
FYI, I left everything off last night and unhooked the sub. Temps are about 24 Degrees F right now, so it was probably high teens last night. Battery was pretty weak but it did start this morning. If it will keep doing that, I should be able to live with it as it doesn't get below the teens at night here more than 3 or 4 nights most winters.
2006 Saab 9-3 2.0t
Old 11-19-2014, 11:29 AM   #7922
raven1231
I'm assuming the fuse that turns it off when you turn the car off
Old 11-19-2014, 11:36 AM   #7923
TM
TM's Avatar
Drives: DGM BRZ 6MT
Car did not start this morning again. Home thermometer read 16F, but car read 20F.
I don't think it's a bad battery because I would leave my car untouched for 3-4 days during the summer on some weekends and it would still start up just fine.
Spoke to my friend who's an electrical engineer and he thinks it just the colder weather causing it to discharge at a faster rate. He's going to come over after work and measure the voltage. I'll also measure it tomorrow morning (and maybe throughout the night if I wake up) to see how much it drops.
Worst case scenario is that I go back to stock for the next several weeks until I store my car.
Old 11-19-2014, 01:33 PM   #7924
Gary in NJ
Gary in NJ's Avatar
Oh the horror!
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
