go_a_way1
Old 11-14-2014, 12:01 PM   #7855
Winjr
Drives: 2013 Subaru BRZ Premium
Originally Posted by Gary in NJ View Post
More importantly then extracting every last bit of available horsepower from the engine, a safe tune will ensure that you don't grenade your engine. Shiv's OFT is designed so users can easily download the tune to their ECU and safely operate their cars. You will always benefit from a custom tune. You may not make any additional horsepower (you could potentially make less at certain rpm's & throttle positions) but you'll have the piece of mind that your engine isn't experiencing knock or detonation.
Yes. I went with an Ecutek custom tune and still had the tuner "dial back" the horsepower gains a bit, just for my own peace of mind. Glad I did. The car has been running like a dream.
Winjr is offline   Reply With Quote
Old 11-14-2014, 03:40 PM   #7856
TM
TM's Avatar
Drives: DGM BRZ 6MT
Full throttle Electric Supercharger Build Thread
My battery couldn't start the car for the first time. I have the system installed for about 7 months now.
It was 65 degrees two days ago, drove fine to and from work. 35 degrees yesterday, didn't really drive that much - only to pick up take out (down the block) and to the gym (~5 miles each way), cranked fine.
This morning, I couldn't start the car. Around ~27-29 degrees. The battery had enough juice to lock/unlock the car and turn on all the electronics. It would only crank once or twice and then die. After several more attempts, it wouldn't crank at all. I turned off the heater/AC, seat warmer, ESC, and anything else with an off button; still wouldn't crank. Had to ask my buddy come and jump my car - started up fine instantly after attaching the jumper cables.
TM is offline   Reply With Quote
Old 11-14-2014, 04:19 PM   #7857
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
This morning, I couldn't start the car. Around ~27-27 degrees. The battery had enough juice to lock/unlock the car and turn on all the electronics. It would only crank once or twice and then die. After several more attempts, it wouldn't crank at all. I turned off the heater/AC, seat warmer, ESC, and anything else with an off button; still wouldn't crank. Had to ask my buddy come and jump my car - started up fine instantly after attaching the jumper cables.
Mine has been weak at 35-40 degrees F. Thinking of ordering a backup.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 11-14-2014, 04:27 PM   #7858
robwbright
Originally Posted by Chimera View Post
This is a super long thread... I'm sure someone has asked this.. I'll ask anyways.
Energy transformation is an inherently lossful process. The idea here as I understand it is that your charging batteries during less that 100% utilization cycles to create a reserve, then expending that reserve to add air pressure to the engine under heavy demand.
Is this the idea more or less?
So, when running this kit is there any appreciable fuel consumption variation beyond the considerably increased use under 90%+ throttle? IE when the system is idle and already fully charged.
My cruising gas mileage is better by 2-3 mpg. I've shown 40.3 and 40.4 mpg on two different 15-25 mile trips traveling 55-65 mph. Overall average is down because I stomp on it so much.
2006 Saab 9-3 2.0t
The Following 2 Users Say Thank You to robwbright For This Useful Post:
Chimera (11-17-2014), DAEMANO (11-14-2014)
Old 11-14-2014, 06:54 PM   #7859
GerryL
Drives: White BRZ
I've been thinking that keeping something like this on board might be a good idea.
[ame="http://www.amazon.com/gp/product/B00M1OUBES/ref=s9_simh_gw_p263_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf _rd_s=center-2&pf_rd_r=1QMA4ATHHJRA72W70EVZ&pf_rd_t=101&pf_rd_p =1688200382&pf_rd_i=507846"]Amazon.com: NOCO Genius Boost GB30 12V UltraSafe Lithium Jump Starter: Automotive[/ame]
GerryL is offline   Reply With Quote
Old 11-14-2014, 06:56 PM   #7860
DAEMANO
Time Traveller
I have to ask, did you check to see if you had any loose cables or fittings?
Old 11-14-2014, 07:20 PM   #7861
Robftss
Drives: VW
Hey guys, I have heard some of the positive posts are working loose. TM this may or may not be the case with you. The last set of kits had these extra washers.... 3/8 flat and a 3/8 lock... torque down till lock is collapsed.
I just checked with Bu-Tang for 'starting' update, all seems well in our balmy -15C
Robftss is offline   Reply With Quote
The Following 2 Users Say Thank You to Robftss For This Useful Post:
DAEMANO (11-14-2014), Fareast auto part (11-16-2014)
Old 11-14-2014, 08:03 PM   #7862
robwbright
I'll check the connections. Doesn't really make sense to be having issues in the 30s and 40s when the Canada guys don't have them at 0.
2006 Saab 9-3 2.0t
The Following User Says Thank You to robwbright For This Useful Post:
Old 11-14-2014, 08:23 PM   #7863
TM
TM's Avatar
Drives: DGM BRZ 6MT
I checked around the terminals before I jumped it and there weren't any. I drove to work after I jumped it (~15 miles) and it didn't have a problem starting back up after work. We'll see how it goes -- there'll be plenty of cold days ahead.
The Following User Says Thank You to TM For This Useful Post:
Old 11-14-2014, 08:33 PM   #7864
DAEMANO
Time Traveller
No doubt out there in NY. It was 72 degrees out here Best of luck man.
Old 11-14-2014, 08:47 PM   #7865
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Any chance you have something connected to the odb2 port?
Installed Mods:
Old 11-14-2014, 09:06 PM   #7866
TM
TM's Avatar
Drives: DGM BRZ 6MT
I'll be moving to SF in jan/feb. Hooray!!! But I'll be leaving my car here in NY until May. Then I'll be coming back and driving my brz over there.
Nope. I'm pretty sure I don't have anything plugged in or on that could be draining the battery.
Old 11-14-2014, 09:08 PM   #7867
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by Robftss View Post
Attachment 95796
Thanks, I'll check again tomorrow morning when there's light out.
Old 11-15-2014, 01:18 AM   #7868
robwbright
I have the cable for the OFT connected to the port but nothing is connected to the cable. Can that create a draw?
2006 Saab 9-3 2.0t
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
