orthojoe
Old 01-21-2013, 03:04 PM   #71
des
des's Avatar
I had exactly the same experience yesterday -- repeated incidents of ice mode during a single run (probably four or five during on a 50-second course). Interesting trick, and maybe useful for a better driver than I am, but I won't be trying it again.
On stock pads.
des is offline   Reply With Quote
Old 01-21-2013, 03:31 PM   #72
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I did have this on one run during the autocross (did 2 events with the full off mode). I thought maybe I was too hard the ABS hit back hard (caused me to have to use my sidewalls as a brake in the decreasing radius I was entering). I need more seat time with these DS2500s to figure this out for sure.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 01-21-2013, 03:56 PM   #73
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Originally Posted by Evil86 View Post
In two cars, with three different drivers, on a fast autox course, the Pedal Dance induced ice mode. That was during comp runs. We all reverted to the regular disabling of traction and stability, no more ice mode.
It make work on tracks and time trails, but on a fast autox course, I would never do it again.
Were said vehicles on crappy stock brake fluid per chance?
Huehuecoyotl is offline   Reply With Quote
Old 01-21-2013, 09:08 PM   #74
Evil86
Evil86's Avatar
Drives: Monkey-butt red FR-S
What brake pads were being used?
I've speculated (without confirmation) that the stock brakes have a rear bias, based on sizing, when using the same compound front and rear.
Stock.
Evil86 is offline   Reply With Quote
Old 01-21-2013, 09:11 PM   #75
Evil86
Evil86's Avatar
Probably,mine was, still fair warning.
Old 01-21-2013, 09:27 PM   #76
bucket
Drives: 4 wheels
Originally Posted by Kido1986 View Post
I noticed a difference doing a "mini time-attack" this weekend (think less technical autocross with multiple hotlaps). I could trailbrake into the corner much better and get rotation. I was on the OEM tires for this so they rotate really easy as is (new track tires are on order) but when attempting to trail brake before the pedal dance, the pedal would go hard like a normal car's ABS pulsing, annoying.
So how did this affect trail braking on vs off...like how eagerly/soon/late did the car rotate? I didn't really notice anything too unusual going with all of the aids off and got the car to rotate very well on the brakes without disabling the brake biasing (didn't actually realize that was a thing until now). It felt a lot like my s14, just without the kick from the turbo.
bucket is offline   Reply With Quote
Old 01-21-2013, 10:05 PM   #77
Kido1986
Dodging cones
Kido1986's Avatar
It didn't rotate much but that was after I mistakenly put too big of a FSB on the car so a lack of rotation was a problem already
Old 01-23-2013, 11:09 AM   #78
hey mike i have a quick question about this. u said that the car has to be fully warmed up but done within the first 30seconds the car turns on. im not getting this part... could u explain this to me please. thanks man!
Make sure the temp gauge (engine coolant temp) is at the "normal" position where it would be after driving the car for 15 minutes or so. Once it's there, turn the engine off, turn it back on, and then do the pedal dance, and it'll work. If the engine isn't at full operating temperature, it wont work.
7thgear (01-23-2013), Freedom (05-13-2014)
Old 01-23-2013, 12:49 PM   #79
sw20kosh
Drives: 2013 Black FR-S
How would one do this at a track event? Between sessions the engine will cool down and prevent you from doing this before a sessions begins.
Old 01-23-2013, 01:39 PM   #80
03Z33
drift
03Z33's Avatar
It works fine as long as the car hasn't been sitting for over 3-4 hours. If you can't get the car to go into diagnostic mode that means you SHOULD NOT be on track, car should be at least partially warmed up to where the coolant gauge is over the minimum mark before any hard driving.
03Z33 is offline   Reply With Quote
The Following 2 Users Say Thank You to 03Z33 For This Useful Post:
afx (02-17-2015), chanomatik (01-24-2013)
Old 01-23-2013, 01:40 PM   #81
Kido1986
Dodging cones
Kido1986's Avatar
Idle for 5-10 minutes to warm the car up. Should be doing that before a track session anyway
The Following User Says Thank You to Kido1986 For This Useful Post:
Old 01-23-2013, 02:06 PM   #82
R2
It may work on tracks and time trails, but on a fast autox course, I would never do it again.
If you don't mind my asking, what is this "Ice Mode" you speak of?
R2 is offline   Reply With Quote
The Following User Says Thank You to R2 For This Useful Post:
sw20kosh (01-23-2013)
Old 01-23-2013, 02:35 PM   #83
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Originally Posted by Evasive Motorsports View Post
we have just gotten a module to do this, easy as pushing a button. More information to come.
Price?
-Acree
Acree is offline   Reply With Quote
Old 01-23-2013, 02:49 PM   #84
Let it idle for a bit before your session.
You should be warming up the entire car before driving hard, as previously mentioned...
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 11:24 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 08:55 AM
