orthojoe
Old 12-05-2014, 01:50 AM   #295
Ultramaroon
not playing cards
Ultramaroon's Avatar
Not sure if troll...
Just a little kid. I felt compelled to say something so you wouldn't have to.
Old 12-05-2014, 01:55 AM   #296
c2yp7ic
c2yp7ic's Avatar
Drives:
Sorta on the right track. Actually i was tying to look out for the "little kids" who try this "pedal dance" and drive off a damn cliff. Its not a bad idea it just needs to be done with caution not just every time you drive fast.
c2yp7ic is offline   Reply With Quote
Old 12-05-2014, 01:57 AM   #297
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
Originally Posted by c2yp7ic View Post
Just want to throw it out there that pedal dance does not work for automatics and also holding down traction control is extremely dangerous and should never be used in rain or on city streets.
Turning off traction control (3 sec press) has become part of my routine every time I get in the car. 7700+ miles and I bet less than 500 of those were with traction control on. But then again I learned to drive without ABS or any other nannies. The whole cutting power when getting some wheel spin (hard shift into second) makes me want to strangle whoever designed that particular "feature". If you're just a commuter then sure, leave it on but as for me I'm a driver.
Amaya is offline   Reply With Quote
The Following 3 Users Say Thank You to Amaya For This Useful Post:
Blokatos (05-15-2016), CSG Mike (12-05-2014), renfield90 (12-05-2014)
Old 12-05-2014, 02:17 AM   #298
Not sure if has subaru in real life... maybe should go back to counterstrike
I don't have a subaru IRL, but I did play CPL CS.
Old 12-05-2014, 02:18 AM   #299
Sounds like you need some driving lessons.
I wonder how people did it, even 10 years ago, when most cars didn't have traction control.
Oh, the pedal dance works on Automatics. Read instructions. Carefully. And learn to drive standard like a man.
hmong337 (01-19-2015), Ultramaroon (01-19-2015)
Old 12-05-2014, 02:23 AM   #300
c2yp7ic
c2yp7ic's Avatar
Drives:
Actually yes i do need lessons lol help me with the pedal dance. no sorry standards not for me anymore its fun and all but as a daily driver i just dont want to deal with it. Paddle shifters pretty much gives me what i want in a manual and auto together.
Old 12-05-2014, 02:33 AM   #301
s2d4
s2d4's Avatar
I take that as a compliment since im not trolling
Umm I tried to save you but then you fell right into this one...
Old 12-05-2014, 02:41 AM   #302
Amaya
Amaya's Avatar
1. Remove/replace all electronic nannies with manual stuff
2. Sell removed components
3. Profit
4. Drive happy
The Following User Says Thank You to Amaya For This Useful Post:
Old 12-05-2014, 02:45 AM   #303
c2yp7ic
c2yp7ic's Avatar
Drives:
Now that i know this is possible i may try it however i still need to see if the pedal dance truly does work for autobots
Old 01-18-2015, 08:49 PM   #304
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
pedal dance not working on my 2015 brz. Is the pedal dance different on the
2015 brz/frs. Or can a flash tune be a possible problem. I would love to know the answer since i have had two instances this past weekend where the EBD screwed up a nice turn during AX.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 01-18-2015, 10:33 PM   #305
Is your car FULLY warmed up? I know it works on the 2015
Old 01-18-2015, 10:51 PM   #306
Ultramaroon
not playing cards
Do we know which temperature parameter it uses? I've wondered if it doesn't use the oil temp because it will lock out even when the water temp gauge hits "normal."
Old 01-18-2015, 11:12 PM   #307
It's only water temp.
190F
Ultramaroon (01-18-2015)
Old 01-19-2015, 08:10 AM   #308
brzaapi
CAR-AHOLIC
brzaapi's Avatar
yes sir, car is fully warmed up. I have tried it a half dozen times over the last few weeks. I always try it after I drive somewhere.
Oh, but one problem I didn't think of. I have a mishomoto thermostat installed that definitely keeps my temps lower. Maybe that is not allowing the coolant temp to hit a proper level.
Thanks for your help.
Daily: Audi TT RS
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 11:24 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 08:55 AM
