Old 11-18-2014, 04:47 PM   #995
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by BRZZZZZZZZZZ View Post
For those of you with serious track/race set ups, I need help. I am currently sitting at 255/40/17s on a 17x9 +35, and I want to get more tire or a stickier tire under my car for auto x and lapping next year, as I am now going boosted and have very little in terms of limitations for my set up for auto x.
Lets here some somewhat budget friendly options.
does it need to be streetable?
your'e not telling us your suspension setup and what tire is on there now.
Jive Turkey is offline   Reply With Quote
Old 11-18-2014, 04:53 PM   #996
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Dunlop Z11s on RCE Yellows and Bilstein sport shocks. -3 degrees of camber and 0 toe all around.
Can be streetable or I can use my 255 setup as street tires as long as all 4 wheels and tires will fit into the car to take to events.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 11-18-2014, 04:56 PM   #997
Jive Turkey
the tuna, no crust.
why do you have so much camber in the rear and front? why no toe?
Old 11-18-2014, 05:01 PM   #998
M23
Drives: 86
Wurr all da whips wid 285 and 295 rubber at dawg?! I need dems so I can tear da streets and canyuns up mah nig. Nah meen?
M23 is offline   Reply With Quote
Old 11-18-2014, 05:06 PM   #999
BRZZZZZZZZZZ
Car Nut
Because that is how I prefer my alignment setup for auto x, being that I have no damping adjustment as well. The camber is partially to clear the rear fenders as well, 255s on a +35 wheel rub with anything less than -2.8 degrees of rear camber on my car for some reason.
This is not a street car, its a weekend toy that is primarily used for auto x.
Old 11-18-2014, 05:13 PM   #1000
Jive Turkey
the tuna, no crust.
i'm 265 +40 and have ZERO issues and i run -1.4 in the rear. plenty of room. but i guess its because i'm on a stiffer suspension as well.
Old 11-18-2014, 05:25 PM   #1001
BRZZZZZZZZZZ
Car Nut
Suspension probably has a lot to do with it, and you are 5mm less agressive, what kind of tire? Certain tires have much more rounded sidewalls as well.
Old 11-18-2014, 05:29 PM   #1002
Jive Turkey
the tuna, no crust.
RE11, 265/35 sidewall is pretty square.
as far as your question, just start looking into R-comps and stickier tires. can always get some conti takeoffs from racecars, but those are not streetable
Old 11-21-2014, 02:53 AM   #1003
GT86NZID
GT86NZID's Avatar
Drives: GT86 '14, F10 '15 & AMG GTS '16
New wheels with Adrenalin RE002 installed today
Pic before alignment spec +38 265/35
GT86NZID is offline   Reply With Quote
Old 11-22-2014, 01:28 AM   #1004
86boy
Drives: 2013 Toyota 86
anyone tried 275 at the rear on stock fenders? (willing to roll fender)
86boy is offline   Reply With Quote
Old 11-24-2014, 01:14 PM   #1005
Jive Turkey
the tuna, no crust.
i know people who run as big as a 285 in the rear.
its all a matter of your wheel offset/width and your alignment specs that will determine what you can in the end fit in terms of tire width.
you can fit that, rolling would most likely be necessary, as well as a relatively stiff suspension.
Old 11-24-2014, 02:18 PM   #1006
M23
Drives: 86
Crawford BRZ runs 275 square, stock fenders. They have also ran 285 in the rear (with 265 out front).
[ame="https://www.youtube.com/watch?v=JKXzDhGhoEg"]Crawford Performance Turbo BRZ! Balance Meets Power - Ignition Episode 71 - YouTube[/ame]
I'd love to see 295 under stock fenders.
Old 11-25-2014, 11:32 AM   #1007
myusernameisrob
myusernameisrob's Avatar
Drives: FR-Z
Originally Posted by ATL BRZ View Post
17x9 +42
245/40/17
myusernameisrob is offline   Reply With Quote
Old 11-25-2014, 05:21 PM   #1008
ShutterSpeed
Drives: Olive Drab/Army FRS
QUALITY OVER QUANTITY
ShutterSpeed is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
