Koji_Online
Old 08-13-2012, 04:42 PM   #57
Foobar
SLO NO MO
Foobar's Avatar
Just spent 10 minutes doing this (including a 5 minute test drive) and the results are perfect. I set my clutch just a little bit higher than the brake. I had them even at first, but I didn't quite like how low it sat, so I raised it a hair, took it for another spin, and now it's perfect.
Thanks!
Old 08-13-2012, 09:08 PM   #58
EvoXDD
Trident Motorsports Owner
Drives: DGM. DD for my EvoX
Originally Posted by MY13FRS View Post
Sadly, I tried and couldn't do this mod as my back gave out 15 mins of trying to get under the dash.
Too bad, as I too feel the clutch travel is waaaay too long.
bring it to me and ill do it for a 6 pack
previous cars:1998 chevy s10 2001 Prelude SH 1992 (JDM)RX7 FD Current Cars:2010 Mitsubushi Evo X GSR 2013 Subaru BRZ Sponsors:Mishimoto/Flossy/Tomei
Craig.tridentms@gmail.com
EvoXDD is offline   Reply With Quote
Old 08-16-2012, 06:28 PM   #59
jm1681
Drives: MKVI VW GTI
I admit, I'm a complete wuss when it comes to messing with things like this, but the grab in the clutch is by FAR what I dislike most about the car. I might HAVE to try this tomorrow
jm1681 is offline   Reply With Quote
Old 08-16-2012, 06:51 PM   #60
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Go for it. Whats the worst that can happen?
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 08-16-2012, 06:55 PM   #61
jm1681
Drives: MKVI VW GTI
What if I accidentally touch the secret bolt that makes your entire car fall apart?
Seriously though, I just worry about making an adjustment that MAY ruin the clutch on my brand new car Is this something that if I brought it to the dealership, that they might be able to either help me with, do for me, or at least weigh in on any potential damage to my clutch disc?
Yes, I'm fully aware of how puss it sounds to ask that, but what can I do? I'm very cautious of these types of things
Old 08-17-2012, 12:46 PM   #62
djdnz
1337
Drives: 2013 BRZ WRB S/C
Don't take it to the dealership, they will think you are crazy. In fact, if you do it don't ever tell the dealership, they like to blame things on customers and when you tell them you adjusted a nut on the clutch, they will say you're to blame for the leaking trunk seal etc.
Just do it yourself. It's easy and you'll feel a sense of accomplishment.
djdnz is offline   Reply With Quote
Old 08-17-2012, 04:10 PM   #63
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I asked a buddy of mine that works in the toyota service dept.
While his words aren't worth crap in a court he did say that this is safe to do and its been done countless times in countless vehicles.
The master cylinder readjusts the clutch pedal's release and full engagement points - nothing affecting the actual clutch (apparently)
Old 08-17-2012, 06:01 PM   #64
jm1681
Drives: MKVI VW GTI
Makes me feel a little better, but I'm still a bit hesitant
Old 08-18-2012, 03:21 PM   #65
BRZ4me
BRZ4me's Avatar
Drives: A4, Isuzu Vehicross
Just did this - took me less than 5 minutes to do. Big difference in roll out. Lucky I can still contort my body to get under dashboards after so many years.
BRZ4me: Lightning Red Subaru BRZ
ETA: @ Home :happy0180:
BRZ4me is offline   Reply With Quote
Old 08-26-2012, 08:46 PM   #66
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I did this when the write up first came around and I ended up over adjusting the clutch and when I went to dial it back in I ended up at the stock location..or maybe worse. I drove another members car today with this done and the difference is soooo immense.
I came home and did it to my car in about ten minutes and I would NEVER go back. It's a bit early to say but I think this is gonna end up being my favorite mud ever. If you haven't done it yet get off the computer and go do it! Thank the OP later.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 08-26-2012, 09:38 PM   #67
smokeyFRS
smokeyFRS's Avatar
Drives: 2013 Scion FRS MT / Argento
After the adjustment, is your clutch pedal higher or lower or same level as your brake pedal?
smokeyFRS is offline   Reply With Quote
Old 08-26-2012, 09:44 PM   #68
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Slightly lower.
When I was checking out the BRZ owners car (Phaedrus' car) I rested my iphone on his brake pedal and used it to see that the clutch pedal was about 10-15mm lower. I then did the same thing on my car except I rested my iPhone on my clutch pedal and saw that my clutch pedal was about 10-15mm higher than my brake. Basically the opposite of what seems to be the optimum clutch height.
The Following User Says Thank You to Laika For This Useful Post:
smokeyFRS (08-30-2012)
Old 09-01-2012, 03:31 PM   #69
Dusky
Dusky's Avatar
Drives: X3, 350z
I would appreciate it if someone can post video when they do the mod to show where the brackets are? i've spent a good 15 minutes and a wrecked back finding the two screws holding the bolt and the only thing that I can see are the two set of screws holding the two switches.
Edit: I also messed up one of the switches... came too loose and the car won't start, i tightened it back and it is all working for now. Obviously, I messed up a simple mod.
Dusky is offline   Reply With Quote
Old 09-02-2012, 02:28 PM   #70
bpracer
Drives: Asphalt FR-S
Awesome, I didn't like the clutch engagement, but was starting to get used to it. Now, it is where it should have been all along.
I needed a second 14mm wrench as the two nuts on the sensor were pretty tight.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
