Koji_Online
Old 11-28-2014, 07:17 PM   #533
-____-
Just consider what the car in this pic will be like when the rebuild is done though!
Old 11-28-2014, 07:20 PM   #534
Ultramaroon
not playing cards
Ultramaroon's Avatar
brittle?
Old 11-28-2014, 07:24 PM   #535
brittle?
http://www.ft86club.com/forums/showthread.php?t=67509
Old 11-28-2014, 07:27 PM   #536
Ultramaroon
not playing cards
Yeah, I'm following it but not enough to dig out my metallurgy notes. I honestly hope I'm wrong.
Old 12-06-2014, 01:28 PM   #537
babydriver
Hit the road and I'm gone
babydriver's Avatar
Hot stuff!
With regard to the clutch pedal adjustment, I took care of it this morning on my 2015 FR-S. Much better action and a predictable point of operation. Fast too. As it turned out, I did not need to adjust the cruise control switch position; everything worked normally after moving the pedal.
I strongly suggest that anyone doing this adjustment get a pair of "bent" needle nose pliers from their neighborhood Radio Shack. This greatly eases the adjustment of the rod itself. The angled tip really makes it much easier to get around while standing on your head!
Slip, slidin' away.
Old 01-19-2015, 11:39 AM   #538
LostSalad
Drives: Toyota 86 - Charcoal Grey
Is this thread still alive?
I got on my back yesterday, but my car is RHD, so I'm not sure exactly what to do without screwing things up. Is there any chance that someone with a RHD can explain in a bit more detail or post a photo?
LostSalad is offline   Reply With Quote
Old 01-21-2015, 08:45 AM   #539
loafy777
Drives: 2014 Monogram FR-S
Just press the clutch pedala few times with your hand while you are down there. You should see some movement closer to the gas pedal.
I imagine the instructions would be the same but let us know if you aren't seeing it.
While on the topic... anyone do this and get some god awful chatter at low speed? The day after I adjusted my pedal I observed this a few times in the parking garage at work. After that, it's worked like a champ outside of the horrible clutch work on my part while getting used to the new engagement position.
loafy777 is offline   Reply With Quote
Old 01-21-2015, 09:42 AM   #540
LostSalad
Yeah OK, I was a bit vague. I saw where the clutch was actuating. There is a white plastic pin that gets compressed whenever the pedal is fully released. I'm assuming that I need to adjust whatever is holding that but I can't quite draw a parallel with the original video.
I think I'll try and do a video myself to just show what I'm seeing and what I'm confused about. It's currently raining so it might take a day.
Old 01-21-2015, 09:44 AM   #541
loafy777
That's for the cruise/gear select. The adjustment point for the pedal itself is on the opposite side of the pedal set.
Old 01-21-2015, 09:54 AM   #542
LostSalad
See that's where my problem comes in - on the RHD, everything happens right there, at the cruise control switch. There is nothing happening on the other side of the pedal set. Unless I'm misunderstanding what you meant.
Old 01-21-2015, 09:56 AM   #543
loafy777
Hmmm... On the US version, it's closer to the gas pedal. There is another rod/bracket assembly.
Let me know if you find it, otherwise I'll try to snag a hi-res pic after work.
Old 01-21-2015, 10:36 AM   #544
LostSalad
This is all I've got (clutch slightly depressed). You can see the switch on the left, but there is nothing else that moves at all when the pedal moves.
I hope this picture doesn't come up too enormous. I snapped it at work so I couldn't get a great angle but it should give an idea of what's going on.
Old 01-21-2015, 10:02 PM   #545
Cop
Cop's Avatar
Drives: 2013 FRS
Just did this after work today and the car feels GREAT.
Not familiar with RHD but you should see a rod pushing into the firewall on the upper portion of your picture. That is the rod you need to adjust in order to change the pedal position.
Cop is offline   Reply With Quote
Old 01-24-2015, 02:57 AM   #546
LostSalad
Gotcha. I guess it's this?
So I adjust that rod until the clutch feels good, then adjust the sensor for cruise control if needed?
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
