#505 |
There are now 2 carseats!
Drives: 2013 DGM BRZ
So, I did this and was careful about following all the warnings about having enough play. The car has 7700 miles on it. I also have rear diff reenforecement bushings. When the car is fully warmed up and i accelerate (sometimes more up hill) I get this metalic sound from the rear of the car as the drivetrain flexes.
It is like a squeak, not a grind, not a shudder (I know what a shuddering clutch feels like). There is no bump, no front end noise. Could this be a contributor, or am I just experiencing increased NVH from the bushings? |
#506 | |
Drives: 2014 WRB BRZ Limited
| The Following User Says Thank You to xxBrun0xx For This Useful Post: | aristo (08-09-2014) |
#507 | ||
Fiebru
Drives: Scion FR-S and Integra Type R
Did you do the adjustment? I might try it tomorrow
Current Cars:
2017 White Platinum Ford Fiesta ST 2013 Raven Scion FR-S 2012 Spruce Mica Toyota Tacoma TRD Off-Road 2000 Phoenix Yellow Acura Integra Type R |
#508 | |
| The Following User Says Thank You to protpibe For This Useful Post: | Draco_PR23 (08-09-2014) |
#509 | |
Fiebru
I will try to back off the adjustment .... The clutch feels great and and I recommend it also
Current Cars:
#510 |
Drives: is300 / Fr-s
Can someone clarify exactly how the sensor is supposed to be after adjustment. When I made the adjustment the threading from the sensor did more adjusting of the height than the spinning rod. Also if the clutch is not supposed to be pressing on the threading much, I have no Idea how to get the threading to lock.
Daily Driver:2002 Lexus is300 Graphite Gray Pearl
Garage Queen:2014 Monogram Fr-s Asphalt 6MT my.is: iJAYDM Clublexus: JDis3 IG:@j0nathandiaz Last edited by JDis3; 08-12-2014 at 12:36 AM. |
#511 | |
Garage Queen:2014 Monogram Fr-s Asphalt 6MT my.is: iJAYDM Clublexus: JDis3 IG:@j0nathandiaz Last edited by JDis3; 08-12-2014 at 02:22 PM. |
#512 | |
Drives: 2013 Asphalt FRS
Hope this will help
#513 | |
Drives: '13 Raven FR-S, MT
.ck |
#514 | |
Garage Queen:2014 Monogram Fr-s Asphalt 6MT my.is: iJAYDM Clublexus: JDis3 IG:@j0nathandiaz |
#515 |
No, don't let it rest on the threads. I'll grab a pic later today
.ck |
#516 | ||
Elite Recognized Geek
Drives: 2014 DGM BRZ Limited
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+ |
#517 | |
| The Following User Says Thank You to JDis3 For This Useful Post: | codesplice (08-12-2014) |
#518 |
Doh! You did, my bad.
![]() But yes, it is correct. There should just be a tiny bit of the white plastic switch sticking up beyond the metal threads. You don't want the pedal arm to actually touch those threads, just the plastic bit. In general, if you can still lift the clutch with your hand slightly above where it rests you're probably good.
G+ |
| The Following User Says Thank You to codesplice For This Useful Post: | JDis3 (08-12-2014) |
| Tags |
| clutch adjustment, clutch helper spring |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
| Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 02:17 PM |
| My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* | wanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-02-2012 01:41 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
