Koji_Online
Old 04-07-2014, 11:58 AM   #449
taiguy
Drives: 2013 Black BRZ Limited
adjusted the clutch pedal slightly below the brake and drove it around for a few days. Readjusted to slightly above the brake pedal and I like it more.
taiguy is offline   Reply With Quote
Old 04-09-2014, 01:25 PM   #450
manonastick
Drives: WRB ZC6
If you guys know how hard is to adjust this on a RHD you would cry. I had the clutch 2-3mm below the brake and after awhile the clutch sometimes does not return. I moved it 2-3mm above the brake now and still feels great but would it do any damage to the spring from having it a bit too low? just curious its feels fine but im not too sure
manonastick is offline   Reply With Quote
Old 04-09-2014, 04:10 PM   #451
chas3wba0
chas3wba0's Avatar
Drives: Yes
If it will put your mind at ease, then no, I don't think it's possible to damage the spring from this adjustment. It's just a coiled piece of metal.
Trust me, I'm an engineer
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 04-09-2014, 10:31 PM   #452
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Ugg... took me a few tries to get it right. First time had it WAY too low... Second time wound up back to stock... Third time was just right (I think)
I added a couple plastic washer to where the pin attaches to the clutch pedal. Kinda surprised they aren't there already, most attachment points like that have washers of some kind.
Kostamojen is offline   Reply With Quote
Old 04-10-2014, 03:36 PM   #453
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
I'm a little surprised by how few turns everyone else seemed to have made. I did 6-8 full rotations and my clutch sits just slightly above my brake pedal. Maybe I had a super-high clutch from the factory, or maybe the threading is different in '14s vs '13s?
xxBrun0xx is offline   Reply With Quote
The Following User Says Thank You to xxBrun0xx For This Useful Post:
jcw99 (09-11-2015)
Old 04-10-2014, 06:33 PM   #454
Kostamojen
I'm at 1 wind right now. 2 was way too much. So ya kinda surprising...
The Following User Says Thank You to Kostamojen For This Useful Post:
jcw99 (09-11-2015)
Old 04-10-2014, 08:08 PM   #455
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I have a '14 and I only did 1.5 turns. 2 turns was too low for me. I have to think if I did 8 rotations, my pedal would be half an inch off of the floor!
Did you spin the clevis? It's that u-shaped bracket thing. And did you make sure to loosen the nut right behind the clevis before turning?
unsurety is offline   Reply With Quote
The Following User Says Thank You to unsurety For This Useful Post:
jcw99 (01-24-2015)
Old 04-11-2014, 01:16 PM   #456
xxBrun0xx
xxBrun0xx's Avatar
I didn't spin the U-shaped bracket, but I did loosen the nut right behind it before turning. Oh well, it's slightly above the break pedal now and is at just the right height for me. Just wish we could get rid of some of the travel before engagement!
Old 04-12-2014, 07:16 PM   #457
punkrawkpunk88
Drives: 2008 Tiburon GS Sport, 2013 BRZ WRB
Thank you for this topic. I have been wanting to do it for awhile but I have been too nervous. I think the car is so much better now
However... I kind of suck so it took me over 3 hours, not 5 minutes
punkrawkpunk88 is offline   Reply With Quote
The Following User Says Thank You to punkrawkpunk88 For This Useful Post:
italy7 (04-22-2014)
Old 04-14-2014, 04:04 AM   #458
manonastick
Drives: WRB ZC6
Well moving it back up above the brake pedal(2~3mm) i seems to still have some clutch sag. . . initially it was gone but for some reason my clutch sags come back by itself. . .
Old 04-20-2014, 04:36 AM   #459
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I've had to adjust mine a couple times and noticed the engagement is much higher after a couple drives as if it is adjusting itself right back to the stock engagement height... anyone else experiencing this?
Old 04-20-2014, 03:08 PM   #460
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Ok so after reading through this thread end to end I went ahead today and adjusted the clutch pedal using the cotter pin/rotate clevis method. It was a bit challenging given the width of my shoulders but I was able to get it done. I have the clutch pedal just slightly higher than the brake. Stock it was a good 1/2 - 3/4" higher than the clutch pedal. This being my first manual it was a big of challenge to get used to that motion but now, WOW the difference is immense. It took three full turns of the clevis to get the clutch positioned where it now is. My girlfriend and I went for a nice jaunt around the local area afterward to try it out and wow, what a difference. Haven't even had it a week and that just turned my skill level up immensely. Thanks so much for this.
phobos512 is offline   Reply With Quote
Old 04-20-2014, 04:00 PM   #461
manonastick
Drives: WRB ZC6
Edit i finally know why it keeps getting lower.
The nut was not tighten soo remember to do it right guys
The Following 2 Users Say Thank You to manonastick For This Useful Post:
codesplice (04-21-2014), jcw99 (09-11-2015)
Old 04-29-2014, 12:15 AM   #462
aristo
aristo's Avatar
Drives: BRZ SWP 14
Bump with a question: Do you guys think it would be a good idea to adjust the clutch back to normal height before getting it checked out for service by the techs at a dealer?
Would they care that the height of engagement was lowered at all? (Because it is quite a significant difference after changing it)
Great 'mod' for the car by the way.. To anyone who is still hesitant or putting off doing it, go do it! It's very easy as long as you follow the video guide.
aristo is offline   Reply With Quote
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
