#421 | |
Canyon Carver
Drives: 2013 CBS BRZ Limited 6MT
"Displaying of the shift position indicator and shift-up indicator can be turned on/off. STEP 1 Press the “ODO/TRIP” switch repeatedly until the setting screen is displayed. (→P. 186) STEP 2 Each time the switch is pressed and held, the display changes between on/off. “G-on”: Display on “G-oFF”: Display off"
'13 Crystal Black Silica BRZ Limited 6MT | Michelin Pilot Super Sports | Limo tint | WeatherTech mats & cargo liner | LEDs replace incandescents | Rydeen backup camera | LED mirror covers | smoke side markers | cQuartz Finest nano paint protection | full front clear bra | stubby antenna | Euro armrest | Grimmspeed hood struts, MC brace
| The Following 2 Users Say Thank You to CoolBReeZe For This Useful Post: | s0sl0w (03-09-2014), SciOnDrifTtSlIdeR (03-09-2014) |
#422 |
Drifter
thanks my manual is currently in storage with the car... i suppose i maybe should have kept it with me to study it over the winter.
#423 |
You're not missing much without the indicator. I hardly look at it anymore. I wish it would indicate based on rowing the stick but it'll only display when the clutch is engaged.
Sent from my SGH-I317M using Tapatalk
#424 |
Proud of Boxer
#425 |
I just did this adjustment (using the pin-removal technique)... hardest part was getting into position to actually do the adjustment.
Feels awesome. I learned to drive manual with this car, and I have struggled with smooth shifting for the year that I've owned it. I can finally shift without having to float or drag my heel that last (what feels like) inch to fully engage. plus my gear indicator still works, so that's awesome. |
#426 | |
Boosted
Drives: Sideways
#427 | |
Canyon Carver
My recommendations are based upon ownership and clutch work on multiple manual transmission cars over the past 40+ years. As a consequence, any "other than stock" adjustment that I discuss is performed at the owner's sole risk. With that out of the way, I'll be glad to help in person if you're in the Austin area. If not; remember that the "upper" or "released" pedal adjustment should require depressing the pedal about an inch before you feel resistance from the clutch master cylinder. This assures that constant pressure isn't bringing the throwout bearing into contact with the clutch pressure plate. As you learned, the throwout bearing soon wears out. If you noticed discoloration on pressure plate diaphragm spring I hope that you replaced the pressure plate as well. The "lower" or "depressed" pedal adjustment should require that you release the clutch pedal from the fully-depressed position at least an inch before it begins to engage. This ensures that the clutch fully disengages during shifts and at stop lights. A dragging clutch wears the driven plate quickly and overheats the pressure plate. It can also lead to "crunchy shifts" and rapid synchro wear since the transmission is still being driven during shifts. I used the "pull the pin and rotate the fork" method for my adjustment. On my car, 1-1/2 turns from stock was the compromise that gave me appropriate clearance at each end of the travel. Your car may be different after the transmission R&R to replace the throwout bearing. PM me if you live in Austin and would like my help. Either way, best of luck with the renewed throwout bearing.
#428 |
Pretend Mechanic
Drives: '13 Raven FR-S M/T
Adjusted mine just below brake pedal, took it for a spin, love it.
went back into the garage and removed the helper spring, now it feels like a clutch! |
#429 |
Drives: JAWS
How far down did you go compared to the brake pedal?? Also did you make sure to adjust the cruise control sensor so it wasn't riding your pedal? Not doubting you just trying to figure out why it'd do that.
#430 | |
Boosted
Drives: Sideways
I adjusted the pedal down so that it was even with the brake pedal, and then I let it down just a little bit, so now the clutch pedal is just barely below the same level as the brake pedal. Perhaps it needs to come up more? Is the stock level above the brake pedal level? If so, how much? Maybe I'll just bring it on the same level as the brake or just a tad higher. The extra level of "comfort" isn't worth the hassle of removing the entire transmission and replacing the throwout bearing again.
#431 | |
Drives: JAWS
#432 |
Canyon Carver
FWIW, my clutch pedal is a few mm above the brake pedal. When adjusted below or even with the brake pedal it engaged too close to the floorboard for my comfort.
| The Following User Says Thank You to CoolBReeZe For This Useful Post: | JB86'd (03-12-2014) |
#433 | |
Drives: '14 WRB BRZ Limited
#434 |
Elite Recognized Geek
Drives: 2014 DGM BRZ Limited
Knocked this out today (so much for that "not gonna mod the new car" thing). I went the "remove the pin; spin the fork" route and found 1-1/2 turns to be just about perfect. I don't know if it needed it, but I went ahead and adjusted the sensor too to be safe.
Thanks to the OP for the walkthrough and to all the rest for the helpful comments and discussion, the clutch on my car feels like I expected it to from day one. Sent from my Nexus 4 using Tapatalk
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+ |
| The Following User Says Thank You to codesplice For This Useful Post: | jcw99 (01-24-2015) |
| Tags |
| clutch adjustment, clutch helper spring |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
| Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 02:17 PM |
| My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* | wanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-02-2012 01:41 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
