Koji_Online
Old 02-04-2014, 10:48 AM   #379
1Cor10:23
1Cor10:23's Avatar
Originally Posted by trevorovert View Post
Glad I'm not the only one. I posted a thread in the Issues subforum
http://www.ft86club.com/forums/showthread.php?t=57383
theres a video there too
I get this as well but when I examined, seems to be the sensor going in and out? Wasn't overly concerned...
Edit: your noise seems to be a bit louder than mine, with a bit more 'pop'. Mine is more like a 'click', will take a look next time and compare.
I also noticed that there seems to be 2 sounds in your video - a click on every push and release (similar to mine) but also a pop once every while (not on every engagement).
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
86-tundra (02-04-2014)
Old 02-04-2014, 11:16 AM   #380
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
yes, there are 2 sounds. on push and on release. Not sure which pop every once in a while you're talking about, now I'm confused, lol. The pops don't happen every push and release. But I can get it to happen consistently.
drove my frs into work this morning and couldn't notice it unless I had music on mute
86-tundra is offline   Reply With Quote
Old 02-04-2014, 11:24 AM   #381
1Cor10:23
1Cor10:23's Avatar
Haha sorry for the confusion; the last ~10 seconds or so of your video, there are 2 distinct sounds, one is more of a slight click, which happens on every push and release whereas the other is more of a 'poppy' click, which happens ~60% of the time or so.
Now, it has been a while since I did this mod so perhaps the first of the two sounds (one that always occurs) is part of the normal operation of the clutch and I just can't remember what it used to sound like when stock (perhaps the slight sound of pushing in and letting off of the gear indicator white sensor head).
However, I think you're referring to the second sound that occurs about ~60% of the time and has more of a 'poppy' tone
Old 02-04-2014, 01:04 PM   #382
86-tundra
Troll Hunter
86-tundra's Avatar
Lol yes, I am talking about the one where I move to above the dash, and it is very audible. I think the other one you are talking about is just simply normal operation of the clutch
The Following User Says Thank You to 86-tundra For This Useful Post:
1Cor10:23 (02-04-2014)
Old 02-04-2014, 01:11 PM   #383
1Cor10:23
1Cor10:23's Avatar
Gotcha, well sorry can't be of any help hope you get it resolved soon!
Old 02-04-2014, 04:41 PM   #384
1Cor10:23
1Cor10:23's Avatar
Originally Posted by s0sl0w View Post
Did this today, HUGE improvement in the clutch.
I did modify the technique discussed however, Subaru didn't intend for you to spin the metal rod to adjust the clutch.
I took off the safety clip, squeezed the plastic safety clip on the pin and took out the pin then pulled the rod down and spun the long "u" shaped bit down, took two tries to get it at a point I liked but it was much easier that trying to spin the rod. Also the gear indicator and cruise worked without adjustment.
Could you please elaborate on why you shouldn't spin the rod? Is there a net difference between the two methods when complete or is it just for ease of completion that you spun the U bracket instead?
Thanks!
Old 02-04-2014, 10:58 PM   #385
s0sl0w
Proud of Boxer
Thanks!
Spinning the rod could score the cup it's seated in and if there's any sealing there, damage it. Not too mention it's about a billion times easier to adjust the clutch as intended.
I'm not prepared to make sweeping statements about what spinning the rod would or won't damage. What I will say (and this comes from several years spent working on airplanes, 10+ years of working on cars, my lifespan helping my dad work on things, and my perspective as an engineering student; take it for whatever that's worth to you.)
Working on things in amanner they weren't intended to be worked on is, generally speaking, bad maintenance practice. When you're doing it for no benefit to the process and potential harm it's foolish. There is nothing gained by spinning the rod vs. popping the clip and spinning the bracket, so why do it?
s0sl0w is offline   Reply With Quote
The Following 4 Users Say Thank You to s0sl0w For This Useful Post:
1Cor10:23 (02-05-2014), CoolBReeZe (02-04-2014), jcw99 (01-24-2015), unsurety (04-01-2014)
Old 02-05-2014, 12:01 AM   #386
JB86'd
JB86'd's Avatar
Drives: JAWS
@s0sl0w I did the adjustment per the instructions on the first page, and didn't read about spinning the u-bracket until much later. It was really easy for me to spin the rod and it didn't seem to damage anything. Too late now I guess! We need a master tech to chime in here
The Following User Says Thank You to JB86'd For This Useful Post:
Old 02-05-2014, 12:32 AM   #387
s0sl0w
Proud of Boxer
Like I said, It probably won't, but there are good reason's not to all the same.
I pm'd the OP requesting that he add my suggestion to his OP; we'll see.
Old 02-11-2014, 12:23 AM   #388
sastexan
Drives: '13 FR-S Ultramarine manual
Different issue - the spring won't return my clutch all the way back up now. I have to pull the pedal with my toes up about 25% of the time for the pedal to return to the top of its travel. I adjusted the pedal back up a little higher but still having the same problem.
Anyone else with the same issue?
'13 FR-S - Ultramarine manual
(GONE) '98.5 Contour SVT - modded (and threw rod with buyer)
'01 Camry 5S-FE (wife's old car)
'11 Odyssey EX-L - familymobile and hauler - food-encrusted carpets and other appropriate features
sastexan is offline   Reply With Quote
Old 02-11-2014, 12:45 AM   #389
Vlady
Vlady's Avatar
Drives: Argento Scion FRS
Considered doing this but forget it now! Let me know when you resolve this issue. I am curious about what is going on here.
Vlady is offline   Reply With Quote
Old 02-11-2014, 01:53 AM   #390
JB86'd
JB86'd's Avatar
Drives: JAWS
What level is your clutch at, compared to your brake pedal?
Old 02-11-2014, 07:02 AM   #391
sastexan
Pretty much level. I didn't measure it with a ruler; I kept adjusting it until I was happy with how the pedal felt and how it engaged. I'll try to measure it today.
Old 02-11-2014, 08:00 AM   #392
fatherfork
Fears Hiccups
fatherfork's Avatar
Drives: Toyota badged 2013 Whiteout FR-S
See my posts here and here.
I had a concern this might be a problem. There's tension on the pedal both ways, but I can see how it might be possible to get stuck between if the clutch is adjusted too low. Try making it a couple mm above the brake pedal and see if you can regain some of the outward tension.
fatherfork is offline   Reply With Quote
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
