#323 | |
Drives: BRZ MT SWP
#324 | |
"New hotness"
Drives: WRB Limited MT BRZ
See here:
#325 |
Proud of Boxer
#326 |
"New hotness"
I explained it to him.
| The Following User Says Thank You to JonnyRocket For This Useful Post: | s0sl0w (11-03-2013) |
#327 | |
Just did the mod, have the clutch pedal resting about 1-2mm below level with the brake. Want to make sure I'm fully disengaged with pedal fully pushed to wall. Thanks! |
#328 | |
Drives: old
| The Following User Says Thank You to Ozzman For This Useful Post: | 1Cor10:23 (11-04-2013) |
#329 | |
Drives: Subaru BRZ Sport Tech Satin White
He's saying you select first twice in succession with the clutch pedal on the floor. The first time you may or may not get the clunk as the synchronizers stop the gears from spinning (cold oil may stop the spinning) technically this is called "stirring", the gears continue to spin at engine speed for a period after you push the clutch, even when the car is stationary. How long depends on a number of factors. Selecting any gear while stationary should stop the gears from moving. You then select neutral and then select any gear, first works well as does reverse. There will be another clunk only if the clutch plate is dragging. If your clutch is properly adjusted the second time you select a gear it should go in easily with no clunk. |
| The Following User Says Thank You to Suberman For This Useful Post: | 1Cor10:23 (11-04-2013) |
#330 | |
#331 | |
Drives: old
On my old car you could test pilot bearing friction clutch drag etc, by depressing the clutch, waiting 3 seconds and throwing it into reverse, if it ground then something was wrong, either the clutch was dragging or the pilot bearing was buggered. On the BRZ/FRS it seems that reverse is synchronized as I have never heard it grind even being impatient with reverse. So throwing it into first/second, whatever and listening for the clunk serves the same purpose. |
#332 |
Sorry to bring this up again but it seems like there was 2 slightly different variations of this test mentioned above, both yielding slightly different results for me
@Suberman - holding clutch-in and quickly shifting to first (clunk if done quickly after clutch-in), still holding clutch down -> neutral -> re-select first (no clunk; barely any resistance) @Ozzman - clutch-in and quick shift first (clunk) -> shift neutral, release clutch -> clutch-in for 3 seconds, shift first (slight clunk, much less than quickly shifting into first without holding clutch first 3 seconds, however; not as smooth as holding down clutch and re-selecting first (as per @Suberman suggestion) Difference is that 2nd method prescribes releasing the clutch before clutching-in for 3 seconds pre-shift to first. Bottom-line I guess is that I've got the clutch set at most perhaps 2mm below the brake (it's really hard to tell down there, even with a ruler) - any danger here? When trying to get the car rolling from stop, I've got about 1" on the pedal before feeling it - just worried that it's dragging and it's minimal to the point that I can't feel it. thoughts? Greatly appreciate all the mechanically-inclined members of the community chiming in! |
#333 | |
Either method works but the method I describe should be foolproof. By selecting a gear while stationary the gears must stop spinning. Selecting neutral while still holding the clutch pedal down will start the gears moving again only if the clutch plate is dragging. Waiting with the clutch pedal depressed is less precise as you don't know how long it takes for the gears to stop spinning. Either method will work if correctly applied. Basically, if the gears don't crunch when you shift, especially into first or reverse when stationary, then your clutch is disengaging enough. The really important aspect is adequate free play at the top of the clutch pedal stroke. As long as you have the correct pedal free play then your clutch fully engages and will not slip. That is the critical thing to be sure about. |
#334 | |
Thanks |
#335 | |
This is also why the practical limit on this mod is clutch drag when the pedal is fully depressed. If you have no clutch drag when the pedal is on the floor and you still have the specified free play at the top of the pedal travel then the pedal adjustment is perfect. |
| The Following User Says Thank You to Suberman For This Useful Post: | 1Cor10:23 (11-06-2013) |
#336 |
1570/2500
Drives: 2013 FR-S 10 Series
Thank you for this great DIY! It made a great difference in overall drivability.
To add to the discussion above, a great test to ensure the clutch is disengaging fully is to find a perfectly flat parking lot and place the gearbox in 1st with the clutch in. Rev the engine slowly up to 6K RPM. If the clutch isn't disengaging fully then the car will start to move. |
| Tags |
| clutch adjustment, clutch helper spring |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
| Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 02:17 PM |
| My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* | wanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-02-2012 01:41 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
