Koji_Online
Old 05-15-2013, 09:36 AM   #281
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by Mikem53 View Post
I haven't done this mod yet... My car isn't a week old yet and I'm still getting used to it.. One thing concerns me.. There needs to be some free play in the pedal as it is adjusted from the factory.. Otherwise the throw out bearing is engaged which will cause premature wear..
Just as you are not supposed to put your foot lightly on the clutch say when your at a light in neutral... Cause that slight pressure causes wear on the throw out bearing.. So if you are taking up slack by this adjustment .. You might be actually causing the throw out bearing to be engaged..
Again.. I don't know the "feel" or have any hands on with this car... Just know how it works and what could be happening if adjusted incorrectly..
This is a misconception of what this adjustment actually does. You aren't changing anything in the clutch. The actual engagement isn't changing in the slightest. What you are doing is moving a lever to a more comfortable position. The only way you could screw up the clutch is if you held the pedal down while you adjusted the sensor. This would cause the clutch to be in a permanent state of partial engagement as if you were riding the pedal all the time. The actual clutch pedal adjustment (more accurate way of describing it) has no effect on what is going on down in the clutch.
Old 05-18-2013, 10:03 PM   #282
BeRZed
Just did this. Made a huge difference! Not sure if it's just me but the clutch feels a bit lighter when you first step on it. Is this normal or have I done something wrong? I've set it to about parallel to the brake pedal.
BeRZed is offline   Reply With Quote
Old 05-18-2013, 10:09 PM   #283
Sensisnow
Drives: 05 TSX & 13 BRZ
Originally Posted by BeRZed View Post
Just did this. Made a huge difference! Not sure if it's just me but the clutch feels a bit lighter when you first step on it. Is this normal or have I done something wrong? I've set it to about parallel to the break pedal.
It's not really lighter, but the decreased travel length kind of gives the illusion that it is.
Sensisnow is offline   Reply With Quote
Old 05-19-2013, 02:10 AM   #284
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
Just did this too... It will make sitting in traffic much more tolerable
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 05-20-2013, 10:10 PM   #285
oinkoinkpig
Drives: frs
Just did this today. Its easy and simple to do while following the video instructions. Thanks a lot. This definitely made a huge difference. Like what most people said, good for traffic.
oinkoinkpig is offline   Reply With Quote
Old 05-21-2013, 06:27 PM   #286
patricksanders
patricksanders's Avatar
Drives: Whiteout FR-S
Just did this. Feels so good. Thanks for the guide!
patricksanders is offline   Reply With Quote
Old 05-21-2013, 10:17 PM   #287
Bullnettles
Drives: Scion FR-S 2013
Just did this, it's 100% better. Definitely bring a ruler, I thought I'd eyeball it and going down there twice is not advised.
Bullnettles is offline   Reply With Quote
Old 05-29-2013, 09:26 PM   #288
s0sl0w
Proud of Boxer
Did this today, HUGE improvement in the clutch.
I did modify the technique discussed however, Subaru didn't intend for you to spin the metal rod to adjust the clutch.
I took off the safety clip, squeezed the plastic safety clip on the pin and took out the pin then pulled the rod down and spun the long "u" shaped bit down, took two tries to get it at a point I liked but it was much easier that trying to spin the rod. Also the gear indicator and cruise worked without adjustment.
s0sl0w is offline   Reply With Quote
The Following 8 Users Say Thank You to s0sl0w For This Useful Post:
8987846 (11-02-2013), CandyFRS (08-15-2013), codesplice (03-21-2014), jcw99 (01-24-2015), ntron1 (07-02-2013), OctaneFRS (06-24-2015), SciOnDrifTtSlIdeR (03-09-2014), unsurety (04-01-2014)
Old 06-02-2013, 01:49 PM   #289
swilliams
swilliams's Avatar
Drives: 13 WRB BRZ
I adjusted mine level with the brake pedal and I agree with you. After only adjusting the clutch pedal (not the sensor), the first 1/2" of pedal movement (free play?) is very light/soft and was a little unsettling at first. It really does feel like the spring tension was reduced after this adjustment. Or maybe it's the initial spring tension when putting the clutch in that is now diminished?
No more over-revving at starts, and my 1>2 is much smoother!
swilliams is offline   Reply With Quote
Old 06-02-2013, 01:52 PM   #290
swilliams
swilliams's Avatar
Drives: 13 WRB BRZ
Originally Posted by Chinadian View Post
After setting the clutch level my previous concern about my rough shifting has been removed. It makes the shift soooo much smoother after adjusting the clutch.
I have not gotten the second part to adjust the sensor yet, but the clutch feels really loose, like if I just tap the clutch it moves around alot. I wondering if thats normal? and will that stiffen up after I complete part 2 of adjusting the sensor?
Did you fix the loose feeling?
Old 06-02-2013, 04:36 PM   #291
Chinadian
Chinadian's Avatar
Drives: FRS Whiteout
Yeah its fine now, I think its cuz I didnt do the second part and I hadn't tightened the bolt up enough for the first part of the mod.
Everything is going well, I might move it a bit lower sometime soon though to test it to see if it feels better.
Chinadian is offline   Reply With Quote
Old 06-02-2013, 07:49 PM   #292
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I ended up moving it back up a little bit. It's slightly easier to get into reverse now. I was probably a bit too low. I'd really like to raise the accelerator some.
Old 06-02-2013, 09:52 PM   #293
Jimp
No longer a lurker
Jimp's Avatar
Drives: 2013 6MT SWP BRZ LTD
Finally got around to this short project. Thanks to OP and all who helped for the info! Have't driven enough to say whether it makes shifting a lot easier or not, but everything seems great so far!
Note: I had to use one of my football receiver gloves to get enough grip to turn the threads into the bracket but pushing on the pedal a bit plus something to use for grip makes it 100x easier.
Jimp is offline   Reply With Quote
Old 06-04-2013, 10:55 AM   #294
Mikem53
Drives: FR-S 6MT
Lol.. So true..
Mikem53 is offline   Reply With Quote
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
