Koji_Online
Old 06-15-2012, 09:54 PM   #15
Julio86
Julio86's Avatar
Drives: 2013 Scion FR-S 6MT
Got it. It really was a piece of cake. Now I want to eat some cake lol thnx koji
I don't always drift every corner, but when I do, I drift FRS . Stay drifty my friends
2013 Scion FRS Whiteout 6MT
Julio86 is offline   Reply With Quote
The Following User Says Thank You to Julio86 For This Useful Post:
Gimagination (04-21-2013)
Old 06-16-2012, 12:10 AM   #16
|-Goku-|
|-Goku-|'s Avatar
Drives: 2011 Civic Si
So when adjusting the clutch pedal, do you just need to make sure that the pedal sits and pushes that pin?
|-Goku-| is offline   Reply With Quote
Old 06-16-2012, 04:07 AM   #17
Koji_Online
N7 Spectre
Koji_Online's Avatar
Drives: 2017 Toyota 86 (Ablaze - 6MT)
Smile
Thanks everyone for posting back with positive results =D
Do you mean the cruise control switch? well if you adjust the clutch down far enough it may not come up far enough to rest on the switch & allow proper use of cruise control or gear indicator;
So when you're done adjusting the clutch pedal the way you want, you have to make sure the white switch on the cruise sensor presses against the pedal;
though also note that you don't want the sensor pushed up far enough to force pressure on the pedal or you will wear your clutch; Use one hand to pull the clutch pedal up while you push in the sensor with the other =D
Another member on here said even after his own adjustment; the pedal still came up to the switch on the sensor; that just means the level you are most comfortable with might not be far down enough to affect it; just double check & let me know how it turns out!
GT 6/ Sport PSN: Koji_Online
Koji_Online is offline   Reply With Quote
The Following User Says Thank You to Koji_Online For This Useful Post:
|-Goku-| (06-16-2012)
Old 06-16-2012, 04:34 AM   #18
|-Goku-|
|-Goku-|'s Avatar
thanks for the info! So I just need to make sure the the pedal rests on the switch, but not far enough where it is pushing back on the pedal, correct?
Old 06-16-2012, 04:47 AM   #19
Koji_Online
N7 Spectre
^ definitely correct =D
Old 06-16-2012, 02:55 PM   #20
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
Starscream15 is offline   Reply With Quote
The Following 2 Users Say Thank You to Starscream15 For This Useful Post:
SirBrass (11-10-2013), |-Goku-| (06-16-2012)
Old 06-17-2012, 06:19 PM   #21
elenien
elenien's Avatar
Drives: Raven Scion FR-S MT
Adjustment done. Turning the rod nearly defeated me, but once I found a good position and put on some grippy gloves things improved.
I put it at the same height as the break. I need to drive it more to decide if it needs further adjustment. I was starting to get used to the height, so it feels odd at the moment
elenien is offline   Reply With Quote
The Following User Says Thank You to elenien For This Useful Post:
Nate219BRZ (06-21-2012)
Old 06-19-2012, 05:42 PM   #22
syelenik
Drives: Premium Red Manual
A few tips
A few tips in addition to the great advice and post above.
1. You may have to get the 12mm wrench at the nut from a weird direction/rotational position to get the open end to mesh on the nut and have room to loosen and later to tighten. When you get up there while upside down with the door sill piercing into your back it should be clear.
2. Small adjustments make a big difference.
3. The rod is tough to turn and someone mentioned putting a pair of gloves on, another suggestion is to wiggle the clutch pedal up and down and inch or so and keep wiggling it while you turn the threaded rod. Again you don't have to turn the rod much. And it turns real easy while wiggling the clutch pedal. Watch the clutch pedal position while you turn the rod and you will see it moves quick.
syelenik is offline   Reply With Quote
The Following User Says Thank You to syelenik For This Useful Post:
jcw99 (12-12-2015)
Old 06-19-2012, 06:36 PM   #23
Koji_Online
N7 Spectre
I'm glad my guide helped! Lmao the techs couldn't figure out how to adjust clutch pedal height; they've probably never done a clutch disc & hydraulic system swap before; that's comforting =P
Old 06-19-2012, 06:40 PM   #24
DYOLF26
Is it just me or am I the only one that is worried that adjusting the height of the clutch pedal could possibly leave the clutch slightly engaged when your foot is completely off the pedal? I feel like you could mess with this slightly but not to the extent that some people are doing it, it seems like a likely possibility.
DYOLF26 is offline   Reply With Quote
Old 06-20-2012, 05:13 PM   #25
syelenik
No Worries
As I understand this you are adjusting the pedal position, not the clutch itself. The free play at the top that is required hasn't changed. If you go too far you could get to a point where the clutch won't fully release which would give you grinding going into reverse or first. You don't want that. And with that and a .2 inch or so freeplay when first pushing the clutch pedal in and all should be fine. As I understand it. We are talking small adjustment goes a long way here.
Old 06-20-2012, 05:21 PM   #26
Koji_Online
N7 Spectre
Smile
Thank you syelenik, that is the right answer; to supplement that, DYOLF26; the last bolded part of my guide that talks about properly adjusting the cruise sensor that sits in front of the clutch pedal is where you need to watch; in that when you adjust the switch to contact the pedal, make sure to pull up on the pedal so that the sensor isn't applying pressure while at rest; this will ensure you aren't partially engaging or 'riding' the clutch =D
To emphasize part of syelenik's post; another part of my guide near the end states the proper way to test & make sure your gears engage correctly with the adjustment made; so that you do not get any grinds or hesitation
Old 06-24-2012, 11:45 PM   #27
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
This is so awesome; stuff I thought I'd be paying the dealer I can do with pictures. Thx all you mechanically inclined owners!
Khyron686 is offline   Reply With Quote
Old 06-25-2012, 06:34 AM   #28
driver01
Drives: brz 13
Looking at the repair manual, the spec for clutch pedal travel is 110 to 115mm.
driver01 is offline   Reply With Quote
The Following User Says Thank You to driver01 For This Useful Post:
Brzce (09-16-2012)
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
