#253 | |
Drives: '13 black BRZ MT
#254 |
Drives: DGM BRZ 6MT
I had to pulsate my clutch petal in order to turn the rod. It only turned as I press down on the petal, so I kept pressing and releasing as I turned the rod.
I think I hear a metal rattling sound now at low RPM (<1.5k). Does anyone have any ideas what it could be? Edit: I meant between 1.5 and 2k.
#255 | |
Hail Magnet
#256 | |
Is there a tool like a plier that I can use to get a firmer grip? |
#257 | |
I Love custom Turbo kits
Drives: Limited BRZ
I had adjusted my clutch grab lower while stock and had to readjust it up yesterday after installing FX300 clutch. It was basically grabbing exactly as soon as I lifted the foot off the floor.
#258 | |
Drives: DGM BRZ 6MT
#259 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I did this tonight since I didn't have anything going on. I was weary on doing this as I figured my clutch was fine even though I didn't care for the long travel. All I have to say is after driving to the grocery store after doing this (mine is just below brake pedal height), my shifting is much smoother. I'm not jerking my head anymore from all the pedal travel and trying to catch the clutch grab point. Now with the pedal closer to the floor with less travel, my shifts are much smoother and I'm sure passengers will appreciate my driving more now.
Thank you for his mod. It's one of my favorites, plus it's free if you have a 12mm and 14mm wrench. ![]() Definitely telling all the PDX area guys and adding it to my build thread.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#260 |
OMOH O2
Drives: Midget Women Crazy!!
Just did this in the garage. Went even with the brake and all I can say is wow. Got rid of my one complaint about the car. After a test drive I can honestly say that the OP was correct. Ever so slightly below the brake is damn near perfect. I took it out and put it through the paces. I look at all adjustments like a penis tho. When your done messing with it ya gotta take it out and beat on it for a few. Thanks for the info on this!!
-Chuck
You don't need a parachute to skydive; you only need a parachute to skydive twice.
I calls her Mrs. Lohan LIKE A SIR!! |
| The Following User Says Thank You to Sgt.Beardface For This Useful Post: | Sensisnow (04-29-2013) |
#261 |
Drives: FR-S 6MT
I haven't done this mod yet... My car isn't a week old yet and I'm still getting used to it.. One thing concerns me.. There needs to be some free play in the pedal as it is adjusted from the factory.. Otherwise the throw out bearing is engaged which will cause premature wear..
Just as you are not supposed to put your foot lightly on the clutch say when your at a light in neutral... Cause that slight pressure causes wear on the throw out bearing.. So if you are taking up slack by this adjustment .. You might be actually causing the throw out bearing to be engaged.. Again.. I don't know the "feel" or have any hands on with this car... Just know how it works and what could be happening if adjusted incorrectly.. |
#262 | |
Drives: 2003 Camry Blue | 2013 FR-S White
You'll see in the procedure that you'll have to do this in order to raise or lower the clutch pedal anyway. |
#263 |
Drives: FR-S 6MT
I just did this mod.. Took literally 10 minutes..
I got the clutch pedal level with the brake pedal.. There is enough clutch play to where taking up the slack will Not affect pressure on the clutch assembly. It grabs lower now And is a bit easier to drive smoothly.. Like others have stated.. Thanks to the OP for getting this started and for the write up and vid. I also referenced the manual available on here before I started.. My first mod within 5 days of ownership. |
#264 | |
1337
Drives: 2013 BRZ WRB S/C
After you unscrew the nut with the 12mm wrench, make sure you unscrew it even further by hand. When you adjust the rod, you end up moving the nut back towards the bracket, effectively tightening it up again. If you back it off by hand by a generous amount, you should be able to twist the rod with some pulsing of the clutch pedal. Thanks Koji, and Jon Harrington for your video on youtube. I played with the position of mine, I ended up adjusting it 4 times before I found my personal sweet spot. At first I set it a bit under the brake pedal (~3-4mm), but found it strange that the throw of the clutch was so short. Then I moved it too far above the brake, then set it to even with the brake, and finally settled on just a hair under the brake pedal. Feels very natural now, and I don't tend to over-rev at stops.
| The Following 3 Users Say Thank You to djdnz For This Useful Post: |
#265 |
Drives: FT86 GTS
Took a lot longer than 10 mins but man was it worth it.
I have mine sitting just a few mm above the brake pedal. A tip for the RHD drivers out there. There is a white plastic/rubber stopper that gets in the way of the 12mm nut. To make it easy, pinch the back of the stopper and pop it off. That way you have enough space to loosen or tighten the nut. |
| The Following User Says Thank You to canon_spec For This Useful Post: | manonastick (03-04-2014) |
#266 |
Drives: FRS Whiteout
As a noob,
Can we get a video of the adjustment? I cant visualize the way to do it properly =( Thanks!! |
| Tags |
| clutch adjustment, clutch helper spring |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
| Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 02:17 PM |
| My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* | wanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-02-2012 01:41 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
