#225 | |
Drives: 13' WRX
#226 | |
Drives: BRZ Limited
#227 | |
Hail Magnet
#228 | |
Drives: BRZ Limited
#229 | |
Hail Magnet
#230 | |
Drives: 2003 Camry Blue | 2013 FR-S White
"But if I'm in first gear, then I'm driving around, eventually I can left off the gas and it just coasts for a while with no pedals in or anything." Can you explain this part a bit more? If you're in 1st and you let everything go, it should coast around a bit before dying. Does it ever die eventually or does it just constantly go? |
#231 |
Drives: BRZ Limited
I'm going to test it when I get off work, but I adjusted it to a hair below the brake. I'm going to see if it would eventually die off, but I remember it just sitting at 1k RPM's on a seemingly flat piece of road for at least 30 seconds.
The exact procedure I did was Reverse ---> Turn to get out of driveway, stop, start to go right, make a right at the first right turn without stopping (no traffic), but sitting around 2,500-3,000 RPM's. Once I got there, I let off the gas and the rpms slowly dropped to 1,000 and then they just.... sat there and my car just moved along at like 1 MPH or something. It showed no sign of going below that RPM, but I didn't let it roll to a hill or anything. I am kind of surprised that even if it's a slight downhill, that it wouldn't just crap out almost immediately since there's zero gas. But this is my first manual and I don't know as much as I'd like to. My friend is a mechanic and he made the adjustment for me. |
| The Following User Says Thank You to Rinzler For This Useful Post: | CamryDS (04-11-2013) |
#232 |
Drives: 05 TSX & 13 BRZ
This sounds completely normal to me and has been the case with every manual car that I've ever owned. It would be different if this happened with the clutch pedal depressed, but if you're just coasting along in first gear with the clutch engaged, then it should coast along very slowly at around 1k RPM on a flat road. I do this in heavy traffic on the interstate all the time.
#233 | |
I was thinking the exact same thing -- reason why is if you let the clutch up slowly while the gear was in 1st, once the clutch engages it will slowly move you forward. If you're on an incline, it'll most likely stall if you just let it go. If you're on a flat surface, it wouldn't just die since it'll just keep going based on it's momentum and the way the clutch works. If you slowly apply your brakes then it will just die eventually and stall out. unless I have this thought process wrong, I think it's normal. |
| The Following User Says Thank You to CamryDS For This Useful Post: | Rinzler (04-24-2013) |
#234 | ||
Drives: BRZ Limited
![]() Edit!: Quote:
#235 |
Drives: 13 SWP BRZ Prem
It's normal. Your engine is "Idling" with minimal load, so it won't die. Your car will always try and keep the RPMs the same at idle. Actually, I found when learning to drive a manual, taking the vehicle on a flat surface and VERY VERY VERY slowly with the vehicle in gear and not giving any gas, release the clutch was a great way to get a feel for the clutch. If you are slow enough, you can get the car moving and eventually release the clutch fully.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice 191WHP/151 ft-lb on 92 |
#237 |
N7 Spectre
Drives: 2017 Toyota 86 (Ablaze - 6MT)
Good replies here! Yes this is definitely normal on all manual cars; the car will always try to keep your idle RPM; if you let out the clutch pedal really slowly in 1st (& on a flat or downhill surface) the car will be moving forward slowly with no additional gas input; as someone else stated on this page, this is exactly how I began to learn how to drive manual & understand how the clutch works; I actually still do this a couple times when getting ready to drive a new car & get acclimated to the grab point.
Actually, this whole process/ reasoning is why I was seeking a solution to the high clutch pedal engagement in our cars, as I like to have my cars grab at where I've always become comfortable with (and this DIY thread was made) Lol
GT 6/ Sport PSN: Koji_Online
| The Following User Says Thank You to Koji_Online For This Useful Post: | CamryDS (04-11-2013) |
#238 | |
| The Following User Says Thank You to CamryDS For This Useful Post: | Koji_Online (04-11-2013) |
| Tags |
| clutch adjustment, clutch helper spring |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
| Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 02:17 PM |
| My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* | wanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-02-2012 01:41 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
