#183 |
Drives: 2012 Toyota GT86
Did this today, procedure was the same although a little awkward due to right hand drive, the clutch pedal isn't on a cam, the cylinder is directly above the pedal and kind of has like a housing around it. It was pretty slippery too, had to wipe it with a rag before I could get grip with just my fingers.
As per the rest of the post, once the small 12mm hex was loosened, I simply pushed clutch in and out until the master cylinder rod would twist, and gave it two and a half full turns (or so) until it was 1mm below the brake pedal, then adjusted the 14mm bolts for the sensor. Thanks to OP! Cheers! |
#184 |
Drives: 2013 Subaru BRZ
This mod is so easy and so crucial. I had the same problem as everyone else, low gear shifts were not smooth at all. I only adjusted it where the clutch is a little higher than the brake pedal. Have to do more testing, but it feels a lot better. Thanks OP.
#185 |
Drives: argento frs; 90 mustang gt
tried this when i got my car, but the play before friction point bothered me. will need to revisit this little mod again..
#186 |
Drives: 2020 BRZ tS #54
need to do this.. i stalled on a 4 way stop i was on a life time mission to let that never happen did stall in the driveway but i was already park so it didnt count
#187 |
Drives: '13 Whiteout FR-S 6MT
I know it's already been discussed, but I just want to confirm that this mod moves the pedal start/finish position, and not just the pedal itself? If that doesn't make any sense, what I originally thought is that this would simply push in the clutch a little bit, so you'd essentially be riding the clutch forever.
#188 | |
Drives: 2013 Hot Lava FRS M/T
In other words, original factory setting you have to let the clutch go quite a bit before you can start pushing the gas pedal. With this DIY adjustment, you can literally lift the clutch just a bit and start to push the gas pedal right away. Hope that make some sense
#189 | |
Drives: 2013 Scion FRS MT / Argento
Check these links out. Hope this will help. [ame="http://www.youtube.com/watch?feature=player_embedded&v=1EkJKjfIQ9A"]How to Adjust the Clutch on a Dodge Stealth or Mitsubishi 3000GT Non-Turbo: HD Video Tutorial - YouTube[/ame] http://www.nicoclub.com/archives/how...ssan-370z.html |
| The Following User Says Thank You to smokeyFRS For This Useful Post: | MmmDieselFumes (03-08-2013) |
#190 |
Awesome, thanks to the two above ^^. I can't figure out how to actually "thank" you, but if I do I will haha. Anyway, didn't wait for an answer, I got antsy and did it a few days ago lol, sure makes a big difference!
#191 |
Can't believe I waited so long to do this adjustment!! It's SO MUCH better to drive now.. and I make smoother shifts as a result! Thanks to Koji & to JohnnyRocket for the video.
Just another tip on "turning the rod"... Not sure how much others had to press their clutch in to turn the rod, but mine's was REALLY easy to turn with just a tiny nudge down on the clutch (like 2-3mm). If I pressed it in more (or didn't press it at all), it was impossible to turn. |
| The Following User Says Thank You to reeves For This Useful Post: | Zgrinch (03-03-2013) |
#192 |
Drives: 2013 FR-S Asphalt
Does anyone know if doing this adjustment would void the warranty?
#193 |
Drives: Raven FR-S 6MT
#194 | |
Drives: Whiteout FR-S
I adjusted mine slightly lower than brake pedal. From what I've noticed though is that it's much easier to burn the clutch with boots on.
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#195 |
"New hotness"
Drives: WRB Limited MT BRZ
This adjustment is akin to sliding your seat closer, or adjusting your seat back. There's no reason it should void your warranty.
#196 |
Drives: .
| Tags |
| clutch adjustment, clutch helper spring |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
| Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 02:17 PM |
| My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* | wanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-02-2012 01:41 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
