Old 01-11-2015, 10:23 PM   #113
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
May 2013 build frs here with over 10 070 km and still no leak on original cam plate
Knock on wood
Also what causes the cam plate to leak?
Young_makaveli is offline   Reply With Quote
Old 11-12-2015, 07:47 PM   #114
Astroboy
Astroboy's Avatar
Drives: None
does anybody know exactly where the oil passage way that the cam plate covers, go to? does it go down to the oil sump?
Astroboy is offline   Reply With Quote
Old 11-12-2015, 08:02 PM   #115
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Well, as I've written in a few other posts a week or two ago, I,too, have experienced the burning oil smell when the car sits at idle after a drive. The leak was too small to be noticeable, and the dealership missed it even though I asked them to look for it when they did an inspection for me last week, but, lo and behold, the leak was there, painfully obvious, today, just as you've all described.
Sooo.. the job is so small it ain't hardly worth humpin' to the dealership, other than to make them aware that this is an ongoing problem with the design. I probably won't bother. The question is...
Remove, clean it up, and black RTV it, or spend the bucks on the replacement part mentioned in this thread? I don't mind spending money for obvious improvement, but if a good reinstall works just as well, then I'd just as soon save the bucks.
Opinions?
Thanks..
Barry
MuseChaser is offline   Reply With Quote
Old 11-13-2015, 02:19 PM   #116
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
While there have been posts of people successfully re-sealing the stock plate, there have been others that tried that only to have a leak occur again in the future. Resealing won't help the fact that the metals are of different consistency and heat up & contract at different rates.
The main advantage of the Raceseng part is the correct material, as well as the rubber o-ring. Combined with the gray gasket maker applied to small seam it seems to be a win-win.
Might be one of those situations like "do it right, do it once".
Side note: too bad all my images aren't showing up anymore in the first post. I don't think I still even have them or I would re-upload them. Sorry about that.
Originally Posted by humfrz
I'm old and lazy
The Following 4 Users Say Thank You to Clipdat For This Useful Post:
Astroboy (11-13-2015), iamhubert (11-14-2015), MuseChaser (11-13-2015), Raceseng (11-13-2015)
Old 12-01-2015, 08:56 PM   #117
Albaro08
Albaro08's Avatar
Drives: Frs asphalt Grey
Is the leak the same if it's from here
Sent from my SM-G928T using Tapatalk
Albaro08 is offline   Reply With Quote
Old 12-02-2015, 12:35 PM   #118
Clipdat
Proud of BOXER
Clipdat's Avatar
Nope, that looks like it's your actual timing/valve cover which definitely seems worse/more severe. Someone correct me if I'm wrong
I'm old and lazy
Old 12-02-2015, 12:39 PM   #119
Albaro08
Albaro08's Avatar
A friend of mine on mid Atlantic fb says timing chain cover
Old 12-02-2015, 01:45 PM   #120
Gringosteve
Drives: UK Spec GT86
Oil leak solved - Raceseng billet aluminum cam plate
I have had both the cam plate and the timing cover sealed for this same issue
Gringosteve is offline   Reply With Quote
Old 12-02-2015, 01:49 PM   #121
Albaro08
Albaro08's Avatar
I have a feeling toyota is going to go with a big fuck no we aren't going to warranty your car
Old 12-02-2015, 02:40 PM   #122
Gringosteve
Mine was fixed under warranty. They fitted an improved plate design also
Old 12-02-2015, 02:46 PM   #123
Albaro08
Albaro08's Avatar
Did they make a tsb for it and also if they did can you tell what was the service they did becuase my dealer is lost in space with this one. So I'm wondering if toyota knows about it
Old 12-02-2015, 02:50 PM   #124
Gringosteve
Not sure if there is a TSB. They first changed the plate and reseal but I still had a leak. It was tracked to the cam cover. When my car was new it had a variable timing part replaced to fix the idle issues (ended up being an ECU fix). Seems they did a crap job of sealing it when the job was carried out
Old 12-02-2015, 02:52 PM   #125
Albaro08
Albaro08's Avatar
Ok ok so maybe toyota might have something on file for what's going on but no tsb but I know that they are going to fix this becuase I don't play to many bs games I'll just go through the right channels and get it done by them especially that I'm bare bone stalk
Old 12-02-2015, 02:55 PM   #126
Albaro08
Albaro08's Avatar
I say that becuase yesterday a service advisor next to the my service advisor was like toyota doesn't consider it being a leak unless it's dripping and he was like what will you do then trying to egg me on and just ignored hem becuase I wanted to say all hell Will break lose and I'll be this dealers nightmare. Legally obviously
The Following User Says Thank You to Albaro08 For This Useful Post:
FRSek (06-08-2016)
Raceseng | Billet Aluminum Caster Camber Plates Raceseng Suspension | Chassis | Brakes -- Sponsored by 949 Racing 162 12-29-2014 11:32 AM
Raceseng | Billet Aluminum Engine Pulleys Raceseng Engine, Exhaust, Transmission 174 07-24-2014 01:24 AM
Raceseng | Lightweight Billet Aluminum Tow Hook Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 13 08-27-2013 02:48 PM
SRP Billet Aluminum Door Sills pedalpusher Interior Parts (Incl. Lighting) 2 09-20-2012 11:25 PM
SRP Billet Aluminum Door Sills pedalpusher Cosmetic Modification (Interior/Exterior/Lighting) 2 09-20-2012 07:44 PM
