#4943 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Opie (11-26-2019) |
#4944 | |
JHerbert Racing
Drives: 2013 Scion FRS
Also the electric power steering stops working when it is stressed too much. It happens to me going into turn 7 at the glen every time. I just muscle through it.
#4945 |
Drives: '14 BRZ Limited
#4946 | |
Most power steering systems provide a lot of assist at low speed, and then add resistance at high speed, to help stabilize the car. |
#4947 |
Drives: Jeep
I am wondering if anyone here removed dust shields behind the rotors. Does this help keep brakes cooler? Any downsides?
| The Following User Says Thank You to Apelsin For This Useful Post: | timurrrr (11-25-2019) |
#4948 | |
Drives: 2015 Subaru BRZ Limited DGM
I have. They were rubbing a bit and making a nasty squealing noise. Hard to say definitively if cooling is better, but maybe a little? No specific downsides to mention so far. |
#4949 |
Drives: Jeep
#4950 |
Drives: 2013 BRZ Limited 6MT
I thought these cars have a pretty well known issue with high steering effort under high load situations, like on tracks that have a carousel or similar?
It happens in my car every time at the carousel at NCM, and I know I'm not bottoming out. |
#4951 |
JHerbert Racing
Its your power steering. It is a known issue. I went though all of this a year or two ago. I was bottoming out. So I raised the car, now I am not bottoming out but still have the same turning issue. There are a bunch of other threads on this. I choose to ignore it bc it is pretty easy to muscle through.
| The Following 2 Users Say Thank You to Takumi788 For This Useful Post: | CSG Mike (11-26-2019), Icecreamtruk (11-26-2019) |
#4952 | |
Drives: 17 BRZ Series.Yellow
The main point of the dust shield is to do exactly like the description, keep dust from components that reside behind it. The other main function is to help keep heat from the brakes off things like ball joints. A combination of corrosive brake dust and heat means that it'll eventually destroy the dust boots of suspension related components. |
#4953 | |
Drives: 2022 GR86 (was 2013 BRZ)
I figured it could also be attributed to g high loads and the self centering forces due to caster angle. Usually the more load the front wheels see, the heavier the steering effort. It doesn't interfere w/ my driving, so I just muscle through it. No harm, no foul. Now I would really get worried if the steering wheel got light during a high g turn!!!
#4954 | ||
I also installed Porsche brake ducts that attach to the lower control arms. On my stock car w/ SX2's (TW260 tires), it helps, but I can't say by how much. The inner brake pad wears more slowly than the outers and there is less heat checking (cracking) on the inner surface of the rotor. I wrapped my lower ball joint and abs sensors w/ reflective heat tape to help protect them from the heat w/out the dust shield.
#4955 | |
#4956 |
Drives: Jeep
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 10:54 AM |
