go_a_way1
Old 10-31-2014, 08:40 PM   #2059
ZionsWrath
Thanks
ZionsWrath's Avatar
P0351 code, how serious is this? Should I be worried? Can I do the second day of track event? Does this lead to DI seal issues or is it unrelated?
Old 10-31-2014, 09:05 PM   #2060
gramicci101
Off Topic
Originally Posted by DocWalt View Post
From Mike's comments in another thread... Anyone have any tips for foot placement on the BRZ? I've been trying a few different things over the past couple of days, but not finding much that's very comfortable that still allows me to be even remotely smooth with heavy braking. Heel-toe for normal street driving is still cake.
You don't crush the brake pedal during daily driving, so your technique will be slightly different. Sit still, put it in neutral, 100% brake like you would on a track, and figure out the best way to blip the throttle.
It's a bad ignition coil. It happens to tracked cars occasionally because it overheats. Read more about it here. As far as continuing to track it, I really wouldn't, but I'll leave that up to the track junkies to make the call. I know @ATL BRZ has been plagued by these things, and has resorted to bringing an extra coil or two with him to the track. It's a quick swap, and it's a shitty thing to have ruin your track plans.
Old 10-31-2014, 10:23 PM   #2061
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
That's exactly the problem, IMO the brake ends up too low vs the throttle and I keep releasing pressure off the brake by accident when I'm done blipping the throttle. If I'm not 100% on the brakes I'm fine, even up to 90% and I can keep it smooth. Guess I just need a lot more practice
Old 10-31-2014, 11:22 PM   #2062
troek
troek's Avatar
Drives: 2012 Toyota 86
you may need to put some new fluid in to get rid of the mushy pedal. i recommend project mu as it makes flushing so easy with the green color and turning clear when its bad.
Old 11-01-2014, 12:02 AM   #2063
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Not a bad idea. Might go with SS brake lines as well since it made a noticeable difference on my GTI. I know on my GTI a lot of the pedal feel was dependent on the pads. The street pads made the pedal feel like mush but as soon as I dropped my track pads in the pedal was easily firmer. Hmm.
I don't want to blame the car and I'd love to improve my technique
Old 11-01-2014, 12:02 AM   #2064
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Yep, as another has mentioned it's an ignition coil problem.
My dealer just cleared the code but next time on track it happened again so I ignored it. After a bit of rest and a few starts the CEL disappeared.
But, when it came on again I told dealer and they replaced the ignition coil under warranty even though I was using car on track.
nzer is offline   Reply With Quote
The Following User Says Thank You to nzer For This Useful Post:
ZionsWrath (11-01-2014)
Old 11-01-2014, 01:23 AM   #2065
Replace the coil pack for cylinder 1. Swap with another cylinder in a pinch (cyl 4 is easiest)
Old 11-01-2014, 01:24 AM   #2066
I literally heel-toe with my toe on the brake and heel on the pedal.
There's no "wrong" way. Some guys pivot their foot, others use the sides.
wparsons (11-01-2014), ZionsWrath (11-01-2014)
Old 11-01-2014, 07:20 AM   #2067
ZionsWrath
Thanks
ZionsWrath's Avatar
1 and 3 are on the left (passenger) 2 and 4 and on the right (driver)?
I'ts an $80 part I'll probably just buy than waste hours at the dealer.
Old 11-01-2014, 10:01 AM   #2068
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
You can find them for $80 on line but the part itself has already seen 2 revisions. Part # ending in 650...651.....now 652
Anyone's guess as to what was changed but I just ordered 2 and got 650's. I wrapped the stem and box with heat tape just as a precaution as it seems #1 fails most often and is located closest to the header collector which is unshielded on my car.
Mine started acting up at the track in August on Saturday morning, car would misfire at higher revs and the Track Off setting started allowing violent intervention in high G's. I parked it for the rest of the weekend.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 11-01-2014, 03:11 PM   #2069
Front passenger = 1, rear driver = 4.
Old 11-01-2014, 04:46 PM   #2070
ZionsWrath
Thanks
ZionsWrath's Avatar
Ugh cant reach either on driver side...
Old 11-01-2014, 04:59 PM   #2071
Helps a lot to have the right tools
Old 11-01-2014, 05:10 PM   #2072
ZionsWrath
Thanks
ZionsWrath's Avatar
Not sure what im missing i have a 10 mm socket and ratchet. I guess need a smaller one because its too big. Maybe a 1/4 inch ratchet?
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
