#15 |
Drives: 2013 FR-S whiteout
It's probably an aluminum hood thing. Both my NA and NB Miatas did this.
#16 | |
Keep calm and drive on
Drives: 2013 WRB BRZ Limited 6M
#17 |
Update: it worked! Raised the hood stops a but and the flutter is basically gone.
#19 |
Drives: 2013 DGM BRZ Ltd
I remember seeing another post about this issue and it turned out the owner had his bumper or headlights replaced.
There are rubber strips atop the headlights that the installer put in backwards, causing them to catch air and push the hood up. I suggest checking the rubber strips on your headlights to make sure they face the right way. |
#20 |
i'm sorry, what?
Drives: Canada
There are two rubber cylinders on the left and ride side of the front of the car along the radiator /headlight support rail.
You can twist these by hand and they will move up or down like any typical screw. Use them to adjust your hood play and alignment.
#21 |
OEDC
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Haven't seen it on mine, and I've almost maxed 6th gear, after going 130+ though you will start hearing your window seals at like 80, it's made DDing slightly annoying.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there. please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback |
| Hood lift at high speeds | Basti | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 97 | 02-15-2016 04:50 PM |
| Hood/Bonnet Lifting At Speed | Kefuddle | Issues | Warranty | Recalls / TSB | 14 | 06-14-2013 06:44 AM |
| Grimm speed hood strut review | BRAWL | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 02-28-2013 09:34 PM |
| Brakes unless at high speed - what to tackle? | empower-auto | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 44 | 10-12-2012 06:06 PM |
| Video: BRZ / FR-S High Speed Run to 124 MPH (200 km/h) | Levi | BRZ Photos, Videos, Wallpapers, Gallery Forum | 43 | 05-16-2012 01:37 AM |
