#295 | |
Drives: '13 BRZ Ltd
I should have done this long ago! Worked like a charm. I only touched the ignition timing and MAF Corrections - didn't touch the idle targets. I think the ignition timing would have done the trick by itself, but it's perfect now, so I'm not touching it. -4 degrees (or whatever default value was closest to that) worked great. Now I can finally think about getting a real exhaust. |
#296 | |
#297 |
Drives: Toyota 86 Pegasus White
Just confirming I've done everything correctly:
#298 |
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Ive been running this set up for alittle while now and my car is an automatic. When its still not fully up to temperature and i put it in gear after 2 minutes idling it still holds at higher rpms until it warms up while im going down the road and sitting at lights first few minutes. After it warms up its all good. Is there something i can do to fix this?
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
#299 | |
Surprised you never got an answer, if you've done the edit that is what it achieves until the coolant temp reaches a proper level I believe around 194 degrees Fahrenheit or something around there with the way I did mine. The only way to get rid of that would be to lower the rpm in the idle control stuff or allow the car to warm up fully i.e. way at least 5-10 minutes of idling if it bothers you.
#300 |
Drives: whiteout fr-s
im running uel93 tune, ofh motiv catless to factory catback. i had to remove my mxp catback because of cold start up. my neighbors complained and threatened to call the police.they have never complained before until i started a new job that required me to leave home at 640 am. the cold start is brutal. i modified post ignition to .04 and changed tables A-F to 1200. this wasnt enough. the idle would go to almost 2K rpms on cold days and warm days begin ~1800 . to not cause bad blood i put on factory catback. i HATE it. i want the exhaust back on. i have the 700C. US 6MT 2013 FRS. to be honest im nervous that i may mess up adding on to the DEf files. anyone that can help me a bit. anyone have the DEF? i need the maf correction ... i read this whole thread. i have no issues editing on romraider nor using oft. i am just avoiding to brick my ecu and make a huge error. what holds me back is me making an error. Thank you for any and all help
#301 |
Drives: UK GT86
Latest OFT C series? If so, then you can use !one and will have all the tables. I'm not on my laptop but you should be able to find them on here somewhere:
http://www.ft86club.com/forums/showp...0&postcount=23
.: Stealth 86 :.
#302 | |
you need to do all three things set idle target to 1200 set post start timing to say -4 reduce maf offset after start tables both nueutral and in gear and with usa roms disable P050B cold start ignition performance else you will throw a cel after a while |
#303 | |
#304 | |
Drives: frs
#305 |
I actually do that from time to time. Its more when i am pulling out of my garage example. Sometimes I have to go back forth and back forth again to get out of the way of another car of mine. While doing this whole time its trying to go. Just have worries about the transmission.
#306 | |
i dont have the tables for maf ofset and im nervous to add it on my XMLS thats my issue i dont want to brick my ECU and im using the newest DEF from open flash |
#307 |
#308 | |
Mine does the same it's the side effect of the extra rpms just allow it to warm up more or lower the rpms....
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 03:14 PM |
| Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-13-2015 12:53 AM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 07:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 06:05 PM |
| Loud cold start and mpg drop since new | be6sti | Issues | Warranty | Recalls / TSB | 7 | 11-28-2012 02:35 PM |
