#155 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Ah, yes, of course (that's the problem with that strategy!).
What you could do then is just copy the above code into the xml that you are using for romraider. |
| The Following User Says Thank You to Td-d For This Useful Post: | steve99 (09-15-2014) |
#156 | |
Drives: 86 GTS
#157 |
I'm not sure if I added those to the 32bitbase for Ecuflash, can't recall - I'll check.
| The Following User Says Thank You to Td-d For This Useful Post: | tech86 (09-25-2014) |
#158 |
Drives: 86 GTS
#159 |
#160 |
Drives: 86 GTS
#161 |
#162 |
Drives: 2014 Monogram Raven 86
@Shiv@Openflash is it possible to add these tables to the v2.0 ots xmls?
#163 | |
its mainly the amount of ignition retard applied that increases the noise levels. reduce that from -15 to -4 or even 0 and the noise is gone. |
#164 |
Drives: 86 GTS
Yeah we established that but since I edit/write from ecuflash, I like to be able to see all the tables there rather than have to open RR.
The amount of work for maintaining the def's has grown exponentially so I can see why it is no easy feat to keep them all aligned. |
#165 | |
#166 | |
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
I've checked my Idle Speed Target A and B tables and they have a max value of only 1400, so I'm not sure why it idles so high. Have you got any advice for me that might prevent my neighbors from burning my house down? |
#167 | |
you can probably reduce the retard from -4 to Zero as well. |
#168 |
Drives: 2012 Toyota 86
for the the biggest difference was the maf correcction after start tables. if you dont have those in romraider, shoot me a pm with your email address, and what cal rom you use.
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 03:14 PM |
| Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-13-2015 12:53 AM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 07:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 06:05 PM |
| Loud cold start and mpg drop since new | be6sti | Issues | Warranty | Recalls / TSB | 7 | 11-28-2012 02:35 PM |
