#141 |
Drives: 2012 Toyota 86
you have to use an definition file (XML) that has that table available. try here: https://github.com/TD-D/SubaruDefs/t...20standard/BRZ
if you are editing the new 2.0X roms, id make sure those definitions are compatible before messing with it. |
#142 |
Drives: 13' BRZ
How do you determine if they are compatible?
sent from HTC one M8 while driving |
#143 |
are you using the 2.0x version tunes? shiv makes it a point not to use any definition files, other than the ones included.
im using the XML he included with 2.0X and it has those tables. maybe he forgot to add them to some rom types? Also, im using +8 ignition timing post start now, and it seems to be even quieter and smoother. no crazy fuel trims, everyting seems daijoobu. |
#144 |
Drives: 13' BRZ
Yeah. That's why I haven't done anything yet. Just trying to determine if it can be done without waiting for him to make new xml's.
#145 |
@Td-d would be the best one to ask, i tried to see if i could figure out how to add those tables to other definition files, but im a bit out of my league im afraid.
UPDATE: i figured it out. Last edited by troek; 08-24-2014 at 11:37 AM. |
#146 |
Drives: brz
Thank you @troek for helping me get the tables to work. I attached a screenshot of all the changes I made, how does it look? I wasn't sure if I was suppose to use -8 or +8 for the "Ignition Timing Post Start" table.
#147 |
i typed in +8 on accident, and didnt notice it until i flashed, but it seems to work even better, and idles smooth. also did it at the same time as flashing to 2.0 map, and also a new version, so i cant say for sure.
| The Following User Says Thank You to troek For This Useful Post: | BoostedWrbBrz (09-13-2014) |
#148 |
Drives: 2014 Wrb Brz limited 6m
yeah im stuck here, ive changed the post cold start ignition timing to .04 like that screen shot, however im not seeing the maf correction in gear and in neutral on my file in rom raider. im on the flash 2.06
#149 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
| The Following User Says Thank You to Td-d For This Useful Post: | BoostedWrbBrz (09-14-2014) |
#150 |
#151 |
Tables are there - maybe Shiv hasn't bundled the latest definitions in on the OFT site - that's why it's a better idea to pull the defs off Github. Always the latest. https://github.com/TD-D/SubaruDefs/r...R_ZA1JB01C.xml
Code:
<table name="MAF Correction After Start (Neutral)" storageaddress="11C868"> <table type="X Axis" storageaddress="11C81C" /> <table type="Y Axis" storageaddress="11C848" /> </table> <table name="MAF Correction After Start (In Gear)" storageaddress="11C964"> <table type="X Axis" storageaddress="11C918" /> <table type="Y Axis" storageaddress="11C944" /> </table> |
#152 | |
#153 |
Right click on the link and save as - it's a full definition for Romraider.
#154 | |
Oft guys just be carefull using defs off github as the oft roms can have the calid changed and hence need thecmatching defs from the openflash site. eg an oft 700C rom is exactly the same cas a 900C or an A01C just with calid changed. the oft guys alter the defs to match if you get github defs and your oft rom has been calid changed its not going to work and the tables will be all screwed up. it will work if the rom yo have is the native rom the series was created wiith ie the latest rom in series |
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 03:14 PM |
| Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-13-2015 12:53 AM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 07:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 06:05 PM |
| Loud cold start and mpg drop since new | be6sti | Issues | Warranty | Recalls / TSB | 7 | 11-28-2012 02:35 PM |
