#267 | |
not playing cards
#268 |
Drives: swp mt '14 brz premium
Went up to my buddy's on Tuesday and adjusted the clutch rod maybe 2 turns ? Then we installed the slave cylinder. It was getting dark when we finished and I felt better about the clutch but was in a hurry to pick up my daughter so didn't notice it that much at first. Got in the car on Wednesday morning and noticed the difference in the resistance of the pedal immediately. Also, I noticed the engagement point was closer to the floor and much more predictable. I can now adjust my seat the way I want to instead of having it way back in order to accommodate the long throw of the factory adjustment. What an improvement
I think I'm going to turn the rod just a wee bit more today. Thanx to everybody who's posted on all these clutch-related threads, especially Ultramaroon, Koji, and Jonnyrocket. Next week we're going to install the MTEC clutch spring. I'll post back with the results.
| The Following User Says Thank You to jcw99 For This Useful Post: | Ultramaroon (11-28-2015) |
#269 | |
Drives: 2014 WRB BRZ Limited
| The Following User Says Thank You to xxBrun0xx For This Useful Post: | Ultramaroon (11-28-2015) |
#270 |
I'll drive it without the spring and then install it later and let you know the difference.
| The Following User Says Thank You to jcw99 For This Useful Post: | xxBrun0xx (11-30-2015) |
#271 |
Drives: 2016 Hyperblue Brz
hmm, just tried to order the part from Autozone, but upon checkout it seemed to be unavailable to purchase anymore...
#272 | |
not playing cards
Or, *cough* you could just use the older wrong part number like the one I have installed. Works just fine.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Cybmx (11-30-2015) |
#273 |
Drives: 2013 Firestorm FRS
| The Following User Says Thank You to continuecrushing For This Useful Post: | Ultramaroon (11-30-2015) |
#274 |
not playing cards
Yeah, It's a smidge shorter and the banjo fitting has to be oriented outside the guide. I watched it for a couple months. No worries.
#275 |
Drives: 2015 FR-S
Hey guys, I recently did this swap. After a little over a week of driving I can say that this new slave is exactly what the car needed. Shorter and stiffer throw on the clutch with a decisive engagement point. I highly recommend this swap to anyone considering it. The only change I would offer is that you use a rubber hose fitted on the bleeder nipple, and bottle filled with brake fluid when bleeding the clutch. It will make it much more difficult to reintroduce air into the line if you are new to bleeding hydraulic lines. Using a flare nut wrench will also help as it won’t fall off in the tight space.
Much thanks to Ultramaroon and everyone else in this thread for the research. |
| The Following 3 Users Say Thank You to dalton328 For This Useful Post: |
#276 | |
#277 |
not playing cards
#278 |
Drives: 2015 FR-S
Thanks for the warm welcome. I'm hoping to try the Mtec clutch spring like most others suggest in this thread soon. Maybe after my wallet recovers from Christmas lol
#279 |
Drives: BRZ Limited
Just ordered the slave cylinder at Napa, they said they will have it by 9am tomorrow. They couldn't seem to locate the washers using the subaru number or find anything equivalent. Any suggestions? Is it just a generic washer?
Is there any reason to swap the clutch line other than aesthetics? I could hold off a few days while I wait for a steel braided clutch line from amazon I guess if it's just for looks. Otherwise I could have the cylinder installed tomorrow night if I pick it up after work... |
#280 | |
Drives: 2015 FR-S
http://www.autozone.com/brake-system...er/773866_0_0/ |
| Tags |
| clutch line, slave cylinder |
| Clutch Engagement Improved! | enjoyminutemaid | Engine, Exhaust, Transmission | 53 | 11-07-2018 07:31 PM |
| Can steering feel, tactility, be improved? Without sacrificing adjustability? | Trettiosjuan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 101 | 08-16-2016 09:14 PM |
| Aftermarket Clutch Master and Slave? | Yruyur | Engine, Exhaust, Transmission | 5 | 07-27-2013 11:22 AM |
| Hate the feel of the clutch | FRSGeek | Engine, Exhaust, Transmission | 18 | 07-10-2013 02:24 PM |
| Clutch feel? | Shit Luck | Engine, Exhaust, Transmission | 5 | 04-21-2013 06:32 PM |
