#253 |
That's unpossible!
Drives: 2013 Scion FR-S, 6 MT, Asphalt
Personally, I like to use Krylon Fusion Paint. It's practically made for an application like this. No primer, no sanding. Designed to fuse to finished plastic surfaces. I've used it on headlights in the past with the same success. It masks off well too, if you're thinking of leaving chrome accents.
#255 |
Drives: Strawberry Pie
#256 |
Drives: Raven Black FR-S
what LED's did you use? looks spectacular mate
#258 | |
Drives: sc00ter
#259 |
Drives: White Fr-S
You dont have to remove the side markers.
If you use a flat object ( i used the handle of a screwdriver) and put it on the top of the push pin you can undo the pin without removing the reflector. Doing it this way i didn brake anything and it reinstalled easily. |
#261 |
That's unpossible!
Correct. The stock reflector under the projector is still silver. But the rest is blacked out. They aren't as bright anymore, but they're just DRLs anyways. They still turn on with the high beams, but the bi-zenons are so good that they are unnecessary.
#262 |
Jedi Member
Drives: Scion Fr-s White out
Where did you get those led's ?
#263 |
In the middle of installing my leds now. Paint is going on as well. Body shop already had the bumper off so I had them give me the headlights.
Sent from my SCH-I535 using Tapatalk 2 |
| The Following User Says Thank You to Yruyur For This Useful Post: | SkAsphalt (03-05-2013) |
#264 |
#265 |
How did you wire them in, switch, highbeam, lowbeam? Thinking of having the dealer disable the drl and running these as them instead.
#266 |
Ill take a pic of them when I get home. Jist got them from an auto shop around here.
| HID Headlight Upgrade KIT - 1st MOD completed | SpecPer | Exterior Parts - The Rest | 76 | 08-03-2012 11:13 AM |
| Is Anyone Else Tired of SOA Information Blackout | geb2391 | BRZ First-Gen (2012+) — General Topics | 23 | 04-21-2012 10:37 PM |
| Headlight Swap Question | nogaroblues4 | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 02-07-2012 03:45 AM |
| headlight condensation | MRZ415 | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 01-23-2012 03:24 AM |
| TRS headlight mod | RRnold | Other Vehicles & General Automotive Discussions | 0 | 12-24-2011 05:20 PM |
