Old 10-16-2011, 02:48 AM   #29
Type[R]+
Type[R]+'s Avatar
Drives: Lexus IS-F
Supra (MkIV) had shortest braking for longer time than Porsche (til '04) and Supra had a plain rotor
sorry, but what are you trying to say? Supra took the longest to stop the quickest? Lol!
Type[R]+ is offline   Reply With Quote
Old 10-16-2011, 02:57 AM   #30
Type[R]+
Type[R]+'s Avatar
Drives: Lexus IS-F
Lol @ this thread. Everyone's a brake expert now.....
Old 10-16-2011, 04:00 AM   #31
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
Plain brakes are the best.
money should be invested on brake lines, brake fluids, pads....and maybe calipers. But the first 3 should give Lock wheel result as well as better brake feel.
CyberFormula is offline   Reply With Quote
Old 10-16-2011, 05:16 AM   #32
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
He was trying to say that for a long time Supras stopped in shorter distances than P-Cars.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-16-2011, 05:49 AM   #33
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Well your arguement fails on physics alone.. but here are what some brake experts say (heck they even make and sell swiss cheese rotors! These companies use to take an even stronger stance against them, but I guess when you can remove material from a blank and sell it for 3-5x as much money....):
Originally Posted by wilwood
PSlots or grooves in rotor faces are partly a carryover from the days of asbestos pads. Asbestos and other organic pads were prone to “glazing” and the slots tended to help “scrape or de-glaze” them. Also, cross-drilling and/or slotting the rotor for racing purposes was beneficial by providing a way to expel the gasses created when the bonding agents employed to manufacture the pads began to break down at extreme temperatures. This condition is often referred to as “outgassing.” When it does occur, the driver still has a good firm brake pedal, but a significant reduction in friction. Normally this only happens at temperatures witnessed in racing. However, with today’s race pad technology, “outgassing” is no longer a concern with pads designed for racing.
So in the final analysis, drilling and slotting rotors has become popular in street applications for their pure aesthetic value. Wilwood provides rotors slotted, drilled or plain. For most performance applications, slotted is the preferred choice. With certain pad material, slotting can help wipe away debris from between the pad and rotor as well as increasing the coefficient of friction between the rotor and the pad. A drilled rotor provides the same type of benefit, but is more susceptible to cracking under severe usage; however, for street and occasional light duty track use, they will work fine. For more severe applications, we recommend slotted rotors.
Originally Posted by stoptech
For many years most racing rotors were drilled. There were two reasons - the holes gave the "fireband" boundary layer of gasses and particulate matter someplace to go and the edges of the holes gave the pad a better "bite".
Unfortunately the drilled holes also reduced the thermal capacity of the discs and served as very effective "stress raisers" significantly decreasing disc life. Improvements in friction materials have pretty much made the drilled rotor a thing of the past in racing. Most racing rotors currently feature a series of tangential slots or channels that serve the same purpose without the attendant disadvantages.
Originally Posted by Baer
What are the benefits to Crossdrilling, Slotting, and Zinc-Washing my rotors?
In years past, crossdrilling and/or Slotting the rotor for racing purposes was beneficial by providing a way to expel the gasses created when the bonding agents employed to manufacture the pads...However, with today’s race pad technology, ‘outgassing’ is no longer much of a concern...Slotted surfaces are what Baer recommends for track only use. Slotted only rotors are offered as an option for any of Baer’s offerings.
Originally Posted by GRM-Not as expert but...
Crossdrilling your rotors might look neat, but what is it really doing for you? Well, unless your car is using brake pads from the '40s and 50s, not a whole lot. Rotors were first drilled because early brake pad materials gave off gasses when heated to racing temperatures, a process known as "gassing out." ...It was an effective solution, but today's friction materials do not exhibit the some gassing out phenomenon as the early pads. Contrary to popular belief, they don't lower temperatures. (In fact, by removing weight from the rotor, they can actually cause temperatures to increase a little.) These holes create stress risers that allow the rotor to crack sooner, and make a mess of brake pads--sort of like a cheese grater rubbing against them at every stop. Want more evidence? Look at NASCAR or F1. You would think that if drilling holes in the rotor was the hot ticket, these teams would be doing it...Slotting rotors, on the other hand, might be a consideration if your sanctioning body allows for it. Cutting thin slots across the face of the rotor can actually help to clean the face of the brake pads over time, helping to reduce the glazing often found during high-speed use which can lower the coefficient of friction. While there may still be a small concern over creating stress risers in the face of the rotor, if the slots are shallow and cut properly, the trade-off appears to be worth the risk.
And note that lots of slotted rotors and just cut into the rotor, unlike the rounded edges on NASCAR rotors (the NASCAR way is proper).
This isn't rocket science. The friction generates a TON of heat, you want a large solid heatsink to take that heat from the pads and calipers and then remove it through the air (the rotors job after generating friction with the pad AND dissipating heat from the pads/caliper).
Do you also believe that in a properly balanced brake system that switching to rotors 2-3" larger and huge calipers actually stop braking distances too with no regard for brake bias/balance?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-16-2011, 06:17 AM   #34
Type[R]+
Type[R]+'s Avatar
Drives: Lexus IS-F
Don't have to worry about that at all.....
My stock brakes on the F (360mm x 30mm F / 345mm x 28mm R) :
I guess Brembo and Lexus got it wrong, huh.......
Old 10-16-2011, 11:33 AM   #35
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
those are probably magical holes or something lol
VenomRush is offline   Reply With Quote
Old 10-16-2011, 12:37 PM   #36
Matador
hashiryu
Drives: Mk4 Supra
This is FT86Club. Every member is and expert on everything. Fuck your logic.
There is a lot more science to braking than what we are glossing over here and I'm sure you know this. However, I just felt I needed to mention that you failed to highlight in your quotes that they did in fact mention that there are benefits to grooved and slotted rotors. Just trying to be objective here.
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
Old 10-16-2011, 08:54 PM   #37
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
what makes you more of an expert than anyone else in here? please enlighten us all with your wisdom...
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 10-16-2011, 10:12 PM   #38
Type[R]+
Type[R]+'s Avatar
Drives: Lexus IS-F
I'm not, AND I DON'T PRETEND TO BE lol!
I'll trust the engineers, not your 5 min searching on google....
Old 10-16-2011, 11:26 PM   #39
LionZoo
Drives: 2006 Mazda RX-8
In that case, would you trust this former engineer?
Keep in mind that, ultimately, the indicator of success of a production car is how much money the model makes. Engineering is not about giving the best performance solution; it's about giving the solution that leads to optimal profits. If automakers would make more profit by embossing Hello Kitty onto their brake rotors, they'd do it. It's easier for them to charge you $500 for your Hello Kitty rotors that costs an extra $10 to make, rather than spend money trying to educate you by doing an ad campaign about how Hello Kitty rotors don't actually help performance. This thought process applies to everything from the most basic Hyundais all the way to the highest end exotics. In fact, I'd say it applies more to expensive cars since the customers are demanding, but are willing to pay and generally won't take no for an answer.
A better indicator of the pure performance potential of a design is in racing. The bullshit stops in racing as the timing clock is key. Racing is still imperfect because rules often govern how the cars are designed, and so many design elements aren't used on racecar because the rules do not allow it. However, to the best of my knowledge, no racing series prohibits cross-drilled rotors, yet they do not appear on any major league racing car.
I can expound on why cross-drilled rotors are not a useful design element, but to do a good job would require a lengthy post. The cliff notes version is that rotors are cooled by drawing air in from the hat of the rotor and expelling them out of their major diameter; the outside of the rotor. The centrifugal force of the spinning rotor drives this air movement, resulting in air that wants to move towards the outside of the rotor. What the air (and by extension, all fluids) does not want to do is make a hard 90 degree turn and exit on the rotor face.
LionZoo is offline   Reply With Quote
Old 10-17-2011, 12:42 AM   #40
Marrk
Drives: Honda Fit
^^ I think I just learned something. Thanks.
Marrk is offline   Reply With Quote
Old 10-17-2011, 01:00 AM   #41
Type[R]+
Type[R]+'s Avatar
Drives: Lexus IS-F
And yet they use cross drilled rotors on the best braking car in the world..... and other high performance cars. They must not be that bad.....
Old 10-17-2011, 01:07 AM   #42
LionZoo
The best braking cars in the world are Formula One cars, which all use blank rotors.
Inside Line's Predictions (Subie Version) GT Engine, Exhaust, Transmission 13 05-23-2014 09:32 AM
PTuning Spec RS *pics inside* Dragonitti Other Vehicles & General Automotive Discussions 121 11-19-2011 11:52 PM
Heritage....inside? Maxim Scion FR-S / Toyota 86 GT86 General Forum 10 01-03-2011 08:17 PM
FT86 concept with a guy inside 4agze Scion FR-S / Toyota 86 GT86 General Forum 2 11-12-2010 03:16 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
