#421 |
Resident Gear Head
Well still working off things on the To Do list. I finally decided on a Tuner and Flex fuel system to finish up the build. I am Going with Moto East. I spoke with them on the Phone today about mid summer tuning. So I need to finish up this engine.
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
| The Following User Says Thank You to celek For This Useful Post: | sato (02-04-2016) |
#422 |
Resident Gear Head
While waiting to build up funds for Valve train I spent a little on some R&D for a new Oil Pan Baffle. More parts inbound but I have the main template made. Need to create the walls for trapping around the pickup as well.
| The Following User Says Thank You to celek For This Useful Post: | radroach (02-08-2016) |
#423 | |
...Just add nauseum
Drives: 2003 (AP1) S2000
Balance them individually on a flow bench. Run a hybrid alpha-N tune. Use a vacuum block, and use MAP for idle control, and nothing else. Install an IAT sensor. Keep it simple. The key to driveability on ITB's is keeping it simple. You will need to tweak your tuning for major changes in temp and pressure. I have no doubt that ECUTEK can make alpha-N work. Forget hybrid controllers, multiple motors, etc. I have never seen an ITB setup that didn't use a common linkage... Strike that, I've seen a v8 with 1 motor per bank.
There are many ways to displace.
-Spartarus |
| The Following User Says Thank You to Spartarus For This Useful Post: | celek (02-09-2016) |
#424 |
Drives: 2013 ultramarine Scion FR-S
Run a plenum and keep the maf.
Sent from my SM-G900M using Tapatalk |
| The Following User Says Thank You to burdickjp For This Useful Post: | celek (02-09-2016) |
#425 |
Drives: 2014 Toyota 86
#426 |
Resident Gear Head
Waiting on parts ETA tomorrow
A little work with a contour gauge I had laying around.
#427 |
Resident Gear Head
It is official,
The 2nd most expensive part of the build purchased. In 304dur @ 13.00mm lift Ex 292dur @ 12.55mm lift For comparison Stock numbers In 255dur @ 11.00mm lift Ex 252dur @ 11.00mm lift
| The Following 3 Users Say Thank You to celek For This Useful Post: |
#428 |
Drives: Raven Fr-S
Sweeeet!
Piper cams?
FR-S Mod target: 200 BHp / Tonne 4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff |
#429 |
Drives: Subaru BRZ Limited
Will be interesting to see how she idles. Or not.
More importantly, will you be the one who finally figures out how to make NA power above 7400rpm?!? I can't wait to see the results. Sent from my iPhone using Tapatalk |
| The Following 4 Users Say Thank You to Traktor For This Useful Post: |
#430 |
Resident Gear Head
Idle is like a warranty I am good at ruining them both. Neighbors definitely not going to be happy
#431 |
Resident Gear Head
A little present in the mail. I can't find my damn calipers.... It will be off to the laser CNC monday for final pieces to be made. Then welded together
#becosworthit
#432 | |
Drives: White 2014 BRZ
JDL Turbo kit - Ecutek, HRI tuned.
| The Following User Says Thank You to stevo585 For This Useful Post: | CSG Mike (02-16-2016) |
#433 |
Resident Gear Head
Well baffle setup sent off too the laser cutter. Maybe done by this weekend it will be back, but I am headed to the Great Lakes Racing Expo.
If you are near Cincinnati come visit the show is free, Also bringing along the Short block for display. https://www.facebook.com/events/1619534554962832/
#434 |
Señor Member
Those are some big cams, I am looking forward to see how well they go and how well the AVCS copes with them. @celek how much adjustment you will have left with these cam specs?
1974 TA22 Celica
2013 86 GT |
| Tags |
| 2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
| Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! | THMotorsports.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-11-2013 05:25 PM |
| The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! | AJ@ECSMotorsports | Engine, Exhaust, Bolt-Ons | 27 | 09-05-2013 09:14 AM |
| *--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping | FT-86 SpeedFactory | Brakes, Suspension, Chassis | 95 | 01-30-2013 07:48 PM |
| Who's in for the long haul? | Laika | BRZ First-Gen (2012+) — General Topics | 47 | 07-09-2012 09:48 AM |
