Old 12-19-2015, 04:37 AM   #379
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by celek View Post
Only downside is valve to piston clearance. The longer they are open more chance of interference. Stock pistons probably wont work on every cam. Even HKS says you can not use their cam with stock pistons, they say you should buy the high capacity kit.
Hey Chris
I was researching cams for my backup motor (yes another one) and found this . Excellent info on FA20 camshaft specs. It has piston to valve contact clearances.
I know it won't apply 100% because of your pistons but it might help if you decide to go with a custom set of cams like I am.
http://dsportmag.com/the-tech/tomei-...0-flat-four/3/
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-19-2015, 05:10 AM   #380
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by jarnojvv View Post
Just a question: how does weight reduction increase whp? It surely only improves response and feeling. It would be interesting to see how much focused mods can reduce the driveline friction to increase the real whp.
fuddbutter (10-06-2016)
Old 12-19-2015, 05:28 AM   #381
FRS Justin
Google is a wonderful thing....
http://www.w8ji.com/rotating_mass_acceleration.htm
copy and paste to browser
710whp
Old 12-19-2015, 11:11 AM   #382
celek
Resident Gear Head
celek's Avatar
If you roll a 200lb boulder up a hill it takes energy. Now if you reduce its mass to say 50lbs it takes less energy and can be rolled faster.
Same amount of power put behind it the less the person has to work same with the engine.
Still making 200HP stock but reduced weight especially in rotating assembly results in less power lost in the drive train. Less parasitic loss in the drive train interpolates to more WHP
celek is offline   Reply With Quote
Old 12-19-2015, 11:46 AM   #383
churchx
churchx's Avatar
Drives: 2014 GT86
celek: only losses in friction of gears/bearings and tire-road affect whp readings. And those are mostly same with or without lightened rotational components. Change of rotational mass affect only time at which certain speed is reached, not how much energy is needed once it gets up at said speed. In your example if you move it to dyno, then it's not the wheel of 200lb or 50lb weight, but rather that dyno brakes car wheels at four time the force, which is not the case. With same dyno "braking" readings should be same for both 200lb & 50lb wheels, with exception of how long heavier one was spun up/accelerated to max speed.
The Following 2 Users Say Thank You to churchx For This Useful Post:
celek (12-19-2015), scary alien (12-19-2015)
Old 12-19-2015, 01:32 PM   #384
celek
Resident Gear Head
celek's Avatar
Really depends on perception but I agree. One of the things in my build is REM polishing of the gears, technically not only lightening the gears by removing tiny bits of rough material including removing friction causing micro peaks. As friction generates heat removing them reflects prolonging transmission life.
Old 12-19-2015, 01:44 PM   #385
FRS Justin
Here is another article that should make everyone happy on the light weight subject please read. so we can get back on topic.
http://www.uucmotorwerks.com/flywhee...heel_works.htm
How does a lightweight flywheel work? Amongst the majority, there are two schools of thought concerning light flywheels. The first is that they do not contribute to power output. The second is that they do. Which thought is correct? In fact both, in a way, are correct.
710whp
The Following 2 Users Say Thank You to FRS Justin For This Useful Post:
Metabrz (12-19-2015), Spartarus (12-21-2015)
Old 12-19-2015, 03:19 PM   #386
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I recall seeing a peak 1~2whp gain from just changing the stock wheel and tires with a lighter RPF1/RS3 tires, all else equal.
Intent > Content
Old 12-19-2015, 03:40 PM   #387
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
A 1-2 hp "gain" is well within acceptable differences between runs. 1-2 hp on a dyno is literally not worth noting.
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
FRS Justin (12-19-2015), solidONE (12-19-2015)
Old 12-19-2015, 05:22 PM   #388
solidONE
solidONE's Avatar
This is true, I was skeptical of the gain I was seeing but it was consistent under multiple pulls. I even remounted the factory wheels to confirm what I was seeing, and it was consistent.
Intent > Content
Old 12-19-2015, 05:28 PM   #389
KoolBRZ
KoolBRZ's Avatar
Lighter weights would still show up on a dyno
They would show in the graph as a quicker ramp up to max HP. The low and mid-range HP would show improvements. There would be no difference to the final number however the drive-ability would be greatly improved.
If I say yes, will that make you think I understand?
Old 12-20-2015, 07:01 AM   #390
churchx
churchx's Avatar
Drives: 2014 GT86
KoolBRZ: was there in any dyno chart also time shown? In all were just whp/wtq at rpms. So how can it be shown in graph? Yes, acceleration would be quicker, yes one would notice that in driving .. but how would you see it in dyno graph?
Old 12-20-2015, 01:49 PM   #391
KoolBRZ
KoolBRZ's Avatar
The low and mid-range parts of the dyno graph aren't tested static. They are tested on-the-rise. In other words, acceleration is shown in the graph UP TO the peak. It alters the shape of the visible ramp. Low acceleration shows as a gradual incline with a steep part at the end, while high acceleration shows as a steep angle right at the start, leveling off to a gradual incline at the end.
Old 12-21-2015, 05:50 AM   #392
Tim Radley
Drives: None
Originally Posted by solidONE View Post
It would be nice to know how much gains yielded by the cams themselves. I've gained about 30whp on "other changes" with stock cams, so when you say +25bhp with cams and 'other mods' its not saying too much.
Problem is there are two major design flaws in the intake system that really hold it back in N/A form. I've seen it in the datalogging from both road and dyno. Might print a new intake manifold over Christmas to test out as I want to leave the car in N/A form whilst i set the Holinger up.
Tim Radley is offline   Reply With Quote
The Following 3 Users Say Thank You to Tim Radley For This Useful Post:
burdickjp (12-26-2015), FRS Justin (12-22-2015), solidONE (12-21-2015)
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
