#365 |
Panda Trueno
Drives: No twin now.
I am really interested in these cams and what people truly gain.
#366 |
Resident Gear Head
A lot of companies are hush hush on results, or do not bother reporting to the manufacture when using a product as they fine tune it. Unlike myself I will post numbers.
Subaru BRZ/FRS Facebook News and Tech Page
My FB Build page CLICK AND LIKE! Twitter and Instagram @misairubrz |
| The Following 2 Users Say Thank You to celek For This Useful Post: | BatStig (12-16-2015), GT86_PRAGUE (12-17-2015) |
#367 |
Resident Gear Head
Won't make as much power without the DI. Would lose the high end timing. Also not customizing the fuel pump setup for lower pressures.
#368 |
Drives: None
I tried an early soft version and with other changes gained 25bhp.
Have got a hotter set to try but just not had time to fit them. I'll most likely wait until I fit a turbo to be fair as my time with the car is very limited. |
#369 | |
Drives: Dodge Patitas
I know there are four cams instead of two, but wow Sent using tapatalk |
#370 |
Drives: '22 BRZ
Seems like a reasonable price for cams IMO, especially if manufactured in a similar fashion to OEM with the hollow shafts and pressed on lobes.
| The Following User Says Thank You to DocWalt For This Useful Post: | sato (12-16-2015) |
#371 | |
Drives: Red Toaster(Dodge Nitro)
I mostly lurk, still don't own an 86...
#372 |
Panda Trueno
Pretty much, just two cylinders next to each other instead of four.
Unfortunately, coming from the "LSx" community.... 1000+ for cams is rediculous, lol. |
#373 |
Resident Gear Head
Much better option than HKS at $1800 though
| The Following User Says Thank You to celek For This Useful Post: | Summerwolf (12-17-2015) |
#374 |
Drives: FR-S Whiteout
It would be nice to know how much gains yielded by the cams themselves. I've gained about 30whp on "other changes" with stock cams, so when you say +25bhp with cams and 'other mods' its not saying too much.
Intent > Content
cowardice is the mother of cruelty. |
#375 | |
Resident Gear Head
This is the power output of any engine measured at the engine's flywheel. (A flywheel is a disc with teeth on it. It's connected to the rear of the engine and its purpose is for the smooth transfer of power to the transmission from the engine.) 2. Wheel Horse Power Unlike bhp, whp is the power output measured at the wheels. This is the information a dyno run provides and usually reads around *15 per cent less than the power measured at the engine (bhp) - this is because power is lost in the driveline (including clutch and transmission). *Four-wheel drive cars lose between 20-25 percent of their quoted bhp figure because of the increased friction. Advanced info The term brake horsepower (bhp) refers to a device called ‘Prony Brake’ (invented by Gaspard de Prony), which was used to measure engine power in the early 1900s. 2. You don't need to increase an engine's bhp to get an increase in a vehicle's whp. You can achieve higher whp by reducing the rotational mass in your drivetrain, such as the wheels, tyres, brakes, clutch, flywheel, etc. In short BHP is an actual increase of output at the engine, whereas WHP can be changed not only by BHP but also mass reduction.
| The Following User Says Thank You to celek For This Useful Post: | solidONE (12-18-2015) |
#376 |
Drives: 2014 BRZ SCCA STU endurance car
The other nice benefit is being able really ring the motor out without losing efficiency. Being able to stay in gear 1000 rpm longer than your competition is a nice plus.
#377 | |
The WHP I yielded form "other changes" over baseline use the same or similar drive-line components. Same model clutch, flywheel, driveshaft, diff, halfshaft, hubs, studs etc. Tire and wheels were slightly different. 17x8 RPF1 with 225 tires for baseline, 17x9 RPF1 with 255 tires used when measuring WHP gained from (other mods). I'm sure if BHP was measured with the baseline and after my "other mods" on stock cams it would still be more than +25bhp. Point is I'd like to see the gains from the cams alone, with all else the same or with only cams and tune being different.
Intent > Content
#378 |
Drives: 86|Fortuner|FJ|Mustang|SwiftSport
Just a question: how does weight reduction increase whp? It surely only improves response and feeling. It would be interesting to see how much focused mods can reduce the driveline friction to increase the real whp.
-JvV-
| Tags |
| 2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
| Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! | THMotorsports.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-11-2013 05:25 PM |
| The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! | AJ@ECSMotorsports | Engine, Exhaust, Bolt-Ons | 27 | 09-05-2013 09:14 AM |
| *--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping | FT-86 SpeedFactory | Brakes, Suspension, Chassis | 95 | 01-30-2013 07:48 PM |
| Who's in for the long haul? | Laika | BRZ First-Gen (2012+) — General Topics | 47 | 07-09-2012 09:48 AM |
