Old 01-12-2013, 11:13 PM   #43
Scaldy
Scaldy's Avatar
Drives: 2013 red FR-S mt
Installed mine today. Then I ordered a second one later
Scaldy is offline   Reply With Quote
Old 01-12-2013, 11:29 PM   #44
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
i'm still a little scared to drill on my car :/
chenshuo is offline   Reply With Quote
Old 01-30-2013, 08:55 AM   #45
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
Originally Posted by FRSowner View Post
I didn't feel like drilling holes in the car, so I zip tied it using existing holes in the trunk frame. I placed a thick piece of rubber gasket material between it and the car body to avoid and rattles or paint wear from vibration.
Good idea.
Mine came with only one bolt and was missing the little square brackets. I have fairly suitable equivalents, but instead I'll try the zip-tie approach.
Deslock is offline   Reply With Quote
Old 01-30-2013, 09:44 AM   #46
NetMagi
NetMagi's Avatar
Drives: 13 Firestorm FR-S
Looks like these are avail on Amazon as well now. .
http://goo.gl/OlND8
I didn't cart it to check shipping, but the price looked good.
-Rich H.
Current: 16 Porsche Cayman, 09 Tacoma 4WD, 13 Highlander 4WD, 12 Yamaha WR250R
Past: 13 10-Series FR-S, 13 FR-S, 11 S4, 07 Corolla, 98 Tacoma 4WD, 03 Corolla, 89 Camry, 90 Celica GT-S, 87 Celica GT-S
NetMagi is offline   Reply With Quote
Old 01-30-2013, 10:41 AM   #47
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
I just got mine today (two weeks from China for a German part. Hmmmm). I didn't feel like drilling holes in the car, so I zip tied it using existing holes in the trunk frame. I placed a thick piece of rubber gasket material between it and the car body to avoid and rattles or paint wear from vibration. It wiggles around a little but it is more than strong enough to hold several bags of groceries - the bags will tear before this breaks.
you sir, are a smart man. The only reason that prevented me from installing one of these in the first place was that i didn't want to drill any holes, but now you gave me the reason to proceed. I'll buy you a beer.
Old 01-30-2013, 11:59 AM   #48
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
Great idea.. I just ordered two of the hooks on ebay and was thinking about how I was going to attach them without drilling.. was thinking double sided tape but I know that's not going to work. When all else fails, zip-ties!! Thanks!
Superfast Jellyfish
overlookedx is offline   Reply With Quote
Old 01-30-2013, 12:35 PM   #49
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
If you don't want your groceries to spill, you could also tie the handles of the bag together.
campy is offline   Reply With Quote
Old 01-30-2013, 01:57 PM   #50
Ingen
Drives: Ultramarine FR-S 6MT
I got this from my GF for christmas and it is awesome:
http://www.sierratradingpost.com/mou...colorFamily=70
You can load the smaller bags up with groceries, or the big over-bag can be loaded directly and carried. It'll turn 100 bucks of groceries into a single trip up the stairs! Also fits just right in the trunk, and doesn't seem to slide around at all. I used it the other day for a picnic at the end of a wonderful mountain road. No sweat, and nothing spilled.
Get one - you'll thank me later
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 04-13-2013, 06:42 AM   #51
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
Instead of drilling holes through the boot, i just slid a bar of metal in behind the existing hole gaps, lined it up, predrilled it and then secured onto that. As you tighten the tow hook and metal bar they secure against the car body.
blue cat is offline   Reply With Quote
Old 04-13-2013, 04:42 PM   #52
Sasquachulator
Pavement Grey
isn't there like a cargo net accessory you could have gotten?
Old 04-13-2013, 04:55 PM   #53
shawnperolis
shawnperolis's Avatar
Drives: 2013 Scion FR-S MT "Panda"
I just practice drifting with a cup of water in my car.
shawnperolis is offline   Reply With Quote
Old 04-19-2013, 01:27 AM   #54
ub78
ub78's Avatar
Drives: Nissan
Hi Mate, I'm trying to do it this way, are you able to take some pictures of your Hook. I'm trying to work out which holes are easiest to slide the metal bar through & did you create the thread for screw in the hole on metal piece itself or is there enough room for finger to get in to hold a nut in place? Cheers.
ub78 is offline   Reply With Quote
Old 04-19-2013, 02:02 AM   #55
blue cat
blue cat's Avatar
As usual i didn't have the foresight to take a photo while i was doing it.
It's a pretty simple process, but the metal bar needs to be fairly thin, it took alot of prying and twisting to get it through the gap because there's not much clearance behind the holes.
Last pic is the bar i used to cut the piece, it was just lying around. The metal is 3mm thick, and 25mm wide. The length i don't remember, i just made it flush with the little metal things provided to screw into. By which i mean the two little pieces in this pic, it fits over an edge and has a thread for the screwd to tighten onto, obviously needs to be predrilled. If you don't have this piece then yes you'll need to do some finger gymnastics to balance the nut through the gaps
Here's snapshots of the inside of the boot.
The Following 2 Users Say Thank You to blue cat For This Useful Post:
Retro86 (04-19-2013), ub78 (04-19-2013)
Old 04-19-2013, 03:07 AM   #56
ub78
ub78's Avatar
Drives: Nissan
Thank you very much. This makes it all very clear now. Cheers.
bag, grocery, hook, luggage, trunk
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? 07stealth350z DIY (Do-It-Yourself) Guides 8 08-27-2020 04:27 PM
WTB/WTT : black brz trunk spoiler or trunk swap ph0en1xtk Exterior Parts (Aero, Lighting, Etc.) 1 03-19-2013 12:03 PM
WTT: My WR blue spoiler/trunk for your trunk (SoCal) itisthumper Exterior Parts (Aero, Lighting, Etc.) 0 10-23-2012 04:27 PM
WTT: DGM BRZ Limited trunk w/ spoiler for wingless DGM trunk No Limit Motorsport Exterior Parts (Aero, Lighting, Etc.) 5 10-03-2012 10:03 PM
WTT: DGM BRZ Limited trunk w/ spoiler for wingless DGM trunk No Limit Motorsport NY / NJ / CT / PA 6 09-27-2012 11:14 AM
