#337 |
Drives: 2013 MT Asphalt FRS
So many different different aftermarket coilovers to choose from. I'm looking to get into autocross this summer. For a begginer like me, which coilovers would work best for me in autocross?
#338 |
#339 |
Don't worry about scrub radius or aerodynamic consequences of lower wheel offset. You'll know if you need to worry about it.
#340 | |
If anything, get yourself a front sway bar, and ONLY the front sway bar, for now. Also, AutoX modding is typically mutually exclusive with track modding, when it comes to times. |
#341 | |
Stock tires, race pads [ame="http://www.youtube.com/watch?v=-r7EgQGxA4g"]Jackson Racing Supercharged BRZ Track Shakedown - YouTube[/ame] |
#342 |
Mike,
I am planning to take my BRZ to the track for the first time. I want to keep the car stock for a while and get familiar with it before serious mods come in. The only thing I'm planning to change for the track is: Hankook RS3 Brake pads Brake Fluid Will this be efficient? Would the stock rotors be fine? or would you suggest changing them too? Also can you (or anyone here) suggest what pads and fluid would be good for a first time track session. Thanks a lot! |
#343 | |
YGPM. |
#344 |
Anorexic
Drives: 2003 Honda S2000 Suzuka Blue
#345 |
Anorexic
#346 |
#347 |
I plan to AX and track my car occasionally.
So far I've added ST coilovers, lowered 1.5'', Michelin PSS 245/265 on Enkei Raijins 18x8.5 and 18x9.5. Car should hopefully have around 300whp this week after turbo and tune. I know going staggered with big rubber will cause more understeer, so I added a thicker rear swaybar (Perrin 19mm) to help (hopefully) neutralize the car. Is my thinking correct? I haven't pushed the car to the edge yet, but I'm expecting understeer with my particular setup. |
#348 |
Drives: '13 BRZ
Got a track related question? I'll try to answer.
I just found out that I made standby at TWS this weekend, which I didn't really expect...I have ~1200 miles on the car, factory engine oil/brake fluid and a set of 17x9 +38 255/40 rs3 sitting in my garage that are begging to go.
I hate the Prius tires, but the other set seems like serious overkill for 160 hp car at a fast track. WWYD? I thought I read in the manual that I shouldn't change the factory oil until 5k miles, but I don't feel right about leaving it in. WWYD? Last edited by T-dub; 01-22-2014 at 11:13 PM. |
#349 | |
Drives: Scion FR-S
Sent from my Q10 |
#350 | |
I'd recommend you go to a square setup, and run a FRONT sway bar for faster transitions. It'll understeer through sweepers, but you'll make up the time in slaloms and then some. |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
