#2241 | |
#2242 |
Here's another.
#2243 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
#2244 |
#2245 |
#2246 | |
The difference is that the cost of entry is higher, so it filters out some people. |
#2247 |
Drives:
Hey @CSG Mike, we may be selling our streetbikes and investing more into the FRS to keep heading towards our long-range goal of NASA TT.
Right now we are tuned on e85 with an air filter and a muffler delete - power is fine for now. We have an auto, so our next two items will be oil and tranny coolers. Our only suspension change is the factory crash bolts to get a little negative camber. My question is this: What coilover setup would you recommend that is 2 way adjustable (comp and rebound), has spring rate options so we can experiment, is rebuildable so it will last, and is somewhere between $2-3k? I prefer a car that tends toward overstear and will rotate easily. Are there just too many options to even recommend something, or is my price range off kilter for my requirements? I've pretty much left suspension to be my last upgrade as I've learned the car, and want something that can grow with me as I get better with seat time - keeping in mind a goal of joining NASA TT in a year or so. *edit* - I forgot to mention we're trying to avoid too many points against us in TTD, so we're trying to avoid anything with remote reservoirs. And we of course need camber adjustability... Thanks!
"Fuck, you've gone completely sideways, man."
~Raoul Duke Gas is pretty cheap considering you're buying liquid explosive dinosaurs. ![]() Last edited by Campo; 12-10-2014 at 06:44 PM. Reason: points, points, points |
#2248 |
Drives: Neptune GR86
I'm not really sure how this pertains to the original question/suggestion of if the OFT is safe for track use.
![]() Last edited by Andrew025; 12-10-2014 at 08:39 PM. |
#2249 | |
Realistically, you need to be looking at the 4-6k price range for a competitive 2 way damper. It sounds odd to most when you're talking about KW, but do you normally buy the *cheapest* option available? That's what the KW/RCE is. The options I'd lean toward are JRZ RS/RS-Pro, or the Tein SRC. The JRZ RS has no reservoir, while the RS-Pro has a remote external. The Tein SRC has an attached reservoir, which doesn't cost as many points as a remote external. All 3 include camber plates, and rear top mounts, and have a WIDE range in spring rate. You'll also probably want rear LCAs for camber adjustment in the back, and a LSD to put the power down (and promote controllable rotation, as per your preference, beyond what the spring rates do). |
#2250 | |
Drives:
This may be the single most helpful suspension post I've ever read. Thanks Mike! Sent from Tapatalk
~Raoul Duke Gas is pretty cheap considering you're buying liquid explosive dinosaurs. ![]() |
#2251 | |
Drives: 2004 Toyota RAV-4 5M
I was on the OEM Ohlins spring rates (~343lbs all around) with 225 Hoosier R6's, AP Sprint BBK, and a 93 tune. For next year I am getting the Ohlins revalved and going to 650lbs in the front and 750 in the rear. Also going for an intake, header/overpipe/HFC frontpipe, and an LSD as well while also switching to 225 Maxxis tires. I'd like to keep running the Hoosiers, but I won't have the points unless I can get a dyno reclass (unlikely). I'm interested in seeing if I can at least somewhat maintain grip levels through the suspension and LSD upgrades while also dramatically increasing power (hopefully). |
#2252 | |
For example, the CSG-Spec Tein SRC allows for spring rates of 7-13k in the front, and 9-15k in the rear. 7k ~~ 500lbs, 15k ~~ 840lbs. Our default 10k/12k is about 560lbs and 670lbs. |
#2253 | |
Drives:
That's not a bad idea, but I'm afraid that like you, I'll want to make changes in the future that a single adjustable won't allow. I know I'm not good enough yet, but the idea is to grow as a driver and car together. It sounds like you're doin great! I wish I had the points available for Hoosiers, but we're starting with a 6 point car because it's auto. Technically it was a 10 point car when we drove it off the lot because we have a factory spoiler that adds 4 points too, but we'll probably remove that in favor of a diffuser or just nothing or a big wing that's worth the points. Sent from Tapatalk
#2254 |
Drives: AP2
Hi all,
I am a new FRS owner. I'd like to know a recommended alignment for a stock FRS with TRD springs. If I am going to get the alignment bolts and plates, where should i start with alignment? Thanks for your input! |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
