Old 12-29-2013, 03:17 AM   #71
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
@DrDuquette, I didn't need to use a spring compressor when removing my stock top hats. Way I did that was I completely removed all 4 top nuts while my stock struts/springs were still loaded under my car. Then I jacked it up slowly unloading the springs, removed the shocks, and transferred the top hats.
Also, to the people having odd noises. I'm just making a guess that you might not have torqued the top nuts til you felt resistance/tension (likely push back from the helper spring)? Because I remember tightening the top nuts (with hex bit holding the strut rod) forever feeling like it wasn't getting any tighter but kept turning til I suddenly felt it almost seize then torqued those suckers to spec.
Old 12-29-2013, 07:19 AM   #72
TeamZleep
Drives: 2013 FRS/2011 TDI
I ended up with -1.8/-1.8 front and -2.5/-2.5 rear. Happy I didn't bother with my SPC camber bolts... If anyone wants some brand new one's, hit me up.
TeamZleep is offline   Reply With Quote
Old 12-31-2013, 02:23 AM   #73
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
This is what the car is looking like right now, it's in the shop wait for the turbo kit to go in.
Ny Brz is offline   Reply With Quote
The Following 5 Users Say Thank You to Ny Brz For This Useful Post:
*LongFella (12-31-2013), chanomatik (03-27-2014), hmong337 (02-10-2014), jflogerzi (01-01-2014), switchlanez (12-31-2013)
Old 12-31-2013, 11:50 AM   #74
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Was this stance/height straight out of the box or did you make adjustments?
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 12-31-2013, 05:20 PM   #75
Ny Brz
Hella Flush
Ny Brz's Avatar
I believe if I remember the front had 3 threads left and the rears had 5 I think. Only other thing install was crash camber bolt on the front and had alignment done.
The Following User Says Thank You to Ny Brz For This Useful Post:
*LongFella (01-10-2014)
Old 01-10-2014, 09:39 AM   #76
*LongFella
*LongFella's Avatar
What's your rim/tire setup?
Old 01-10-2014, 09:59 AM   #77
Ny Brz
Hella Flush
Ny Brz's Avatar
The current set up as of right now is XXR 527 on 235/45 18. That will prob get swapped out when it gets warmer.
Old 01-10-2014, 03:43 PM   #78
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
I thought it is require to have the SPC camber bolts to install with the ST suspension?
Old 01-10-2014, 04:42 PM   #79
TeamZleep
Nope. Not even in the slightest bit true. Besides, the ST upper spindle mount holes are slotted, so you can adjust front camber that way.
Old 01-10-2014, 05:33 PM   #80
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Oh..so you just use the stock bolts and stock camper plate. all you order just the ST suspension coilover kit? correct me if that is not right.
Old 01-10-2014, 07:34 PM   #81
TeamZleep
That's all I ordered. I used the factory bolts and adjusted the camber with the coilover slot. The rears *could* use something like the SPC rear lower control arms. I didn't use them, and lucked out with the camber being -2.5 degrees on both sides.
Old 01-10-2014, 08:19 PM   #82
*LongFella
*LongFella's Avatar
ST Coilovers *Review for the Begining*
That's all I ordered too. Just the ST Coilovers. I'm planning on installing them this weekend...
Old 01-16-2014, 01:54 AM   #83
*LongFella
*LongFella's Avatar
Installed tonight and it looks nice. I'm hoping the front settles a little more! I did 5 threads in the front and 7 in the rear. The rear is tucking, but the fronts are still off roading :-(
Old 01-16-2014, 09:57 PM   #84
*LongFella
*LongFella's Avatar
Question for the ST installed folks:
Where did you set you top bolt (camber bolt?) when you did your install? This is on the front strut...one of the bolts allows you to adjust camber I believe???
RS*R Sports-i coilovers - install & review ultra Suspension | Chassis | Brakes -- Sponsored by 949 Racing 50 07-27-2022 06:29 PM
Suspension Review: KW v3 Coilovers DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 07-10-2015 12:42 AM
Mann Engineering Coilovers review l8apexr CANADA 10 03-11-2014 01:11 PM
FR-S Coilovers Review sraggs42 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-14-2013 01:16 PM
Who likes blue? FT-86 SpeedFactory Review - Standard R3 Coilovers FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 04-27-2013 04:50 PM
