Old 11-24-2015, 07:41 AM   #155
retrofit
Drives: Toyota 86
Originally Posted by moto-mike View Post
After driving the car above with this kit, I have to say it was quite impressive for pump gas, and even better on e85.
We are in the process of importing the kit and will have it added to the online store in not too long. While many of the SC kits out there are good in their own right, this setup is pretty unique and has a lot of good points that you'd only appreciate when you're working on it (uses stock airbox, easy to assemble, dual laminova cores...) For the price its at given today's exchange rate, it is very competitive with Edelbrock and the rest.
@moto-mike I'm curious how you guys came up the tune for this kit?
Did you start from scratch, from your own base tune, or a base tune provided by Harrop?
Also what type of sensors are attached to the intake manifold post supercharger?
There's two wires which I assume might be for manifold pressure and air temp. I've been looking at my ecutek logs, trying to work out if it's possible to monitor pre and post supercharger air temps, but not sure where to look.
In terms of weight does the kit feel heavier, lighter, or the same compared to the Edelbrock?
retrofit is offline   Reply With Quote
Old 11-24-2015, 09:26 AM   #156
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'd guess it's similar to the Edelbrock and have IAT sensor combined with the MAP. This will still be logged in ECUtek as Intake Air Temp. Pre-Charger you may as well just log ambient temperature, it uses the OEM airbox so the IAT sensor in that should read around ambient as long as you're not in traffic.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-24-2015, 09:42 AM   #157
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
I really like the look of this kit! I would be curious to see a comparison of this and the Edelbrock.
NotSoJDM is offline   Reply With Quote
Old 11-24-2015, 01:12 PM   #158
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Me too!
I like driving!
86 South Africa is offline   Reply With Quote
Old 11-24-2015, 02:14 PM   #159
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We use EcuTek RaceROM custom maps for timing, and MAF/hybrid SD for fueling. Since our timing map is a high resolution pressure based map, it isn't subject to airflow calculation errors (i.e. stock load based mapping). From an OEM standpoint that works well, but the pressure based timing maps at high loads works much better for custom setups with forced induction. Then it is a matter of altering the timing and cam timing curves to suit the application. Because we've worked with every combo of SC out there, we know with a good degree of accuracy what it will need without ever touching it. This kit we were done in under 2 hours on the dyno from what I recall, that included doing it on both pump and e60. But once we set the MAF scaling it was 90% of the way there.
FYI we added this kit to the online store: http://www.moto-east.com/store/harro...6-brz-frs.html and the pricing after AUD conversion is insanely good.
VS Edelbrock? VS xyz SC? I really don't want to comment there, but we have found nothing about this SC kit that was anything but excellent. They dyno charts and the price can do the talking here. Even came in a plastic crate to ensure the freight company couldn't mess it up.
Xero-Limit is offline   Reply With Quote
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
Jmonty (11-24-2015), Toyota86.ir (02-09-2016)
Old 11-30-2015, 04:08 PM   #160
86 South Africa
So I thought I wanted the Edelbrock kit, but having just checked the the exchange rate between US$ and Aus$ it is around $575 cheaper for me
I am also assuming shipping will be similar for both, and import duties will definitely be similar.
(Cosworth's price just takes it out the running).
Wondering if there is any reason to still consider the Edelbrock unit - I don't care about CARB or emissions
I like driving!
Old 11-30-2015, 04:56 PM   #161
bfrank1972
Drives: 2013 FR-S Argento
Side note: Mike how does this thing compare to the big Sprintex blower you've been toying with? (Both quality and power delivery)
bfrank1972 is offline   Reply With Quote
The Following User Says Thank You to bfrank1972 For This Useful Post:
Freeman (11-30-2015)
Old 11-30-2015, 05:32 PM   #162
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Any chance you guys could post up some installation manuals from this kit? Possibly a pdf? I'm interested in how the install compares with the edelbrock. Both seem super clean and simple but a peek under the hood would be much appreciated.
Are you the only guys in the US importing this kit? Haven't seen anyone else on this yet which is crazy cuz it's amazing!
kuczynskika is offline   Reply With Quote
Old 11-30-2015, 06:27 PM   #163
Xero-Limit
Xero-Limit's Avatar
It's a different kit so hard to compare, nor did we put the smallest pulley on the harrop kit to see what it'll do. Either way you'll need a built motor to get the most out of each blower.
We don't have any pdfs to reference, but it is pretty straight forward and the instructions are good. I'd say it is pretty similar as the other kits.
bfrank1972 (11-30-2015), kuczynskika (11-30-2015)
Old 12-17-2015, 04:29 PM   #164
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Just saw some results on the new Harrop Supercharger for 86/BRZ
Tuned at LK Motors in Cairns Australia
227rwhp/170rwkw
https://www.facebook.com/lkmotors/?fref=ts
Toyota 86 test driver
Tradewind is offline   Reply With Quote
The Following User Says Thank You to Tradewind For This Useful Post:
Freeman (12-17-2015)
Old 01-02-2016, 04:05 PM   #165
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
I've been seriously considering the Edelbrock kit, but this is there too, would love to see some real comparisons, on similar dynos/conditions/supporting mods, etc, also the install process. Do these have a warranty like the Edelbrock?
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 01-21-2016, 03:30 PM   #166
Kodename47
Kodename47's Avatar
Drives: UK GT86
Today Abbey Motorsport have got their base tune done and dynoed.
Standard exhaust fitted and lower line is the car in standard form. UK 98/99 RON fuel.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
Freeman (01-21-2016), keen as (01-27-2016)
Old 02-23-2016, 02:11 AM   #167
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
Originally Posted by nelsmar View Post
I just emailed Harrop asking if they will be distributing this in the US
I like to know your idea about harrop vs edelbrock ?
Toyota86.ir is offline   Reply With Quote
Old 02-23-2016, 03:05 AM   #168
Irace86
Drives: BRZ + Ducati M796
In terms of looks, this one wins in how low the charger sits and in the shape; it almost looks like a v6/v8 and just clean; and the low height makes it look like strut towers will work. But it has those ugly tubes running from the front, and I just have a feeling that the Edelbrock kit is a better design.
The Edelbrock kit looks clean too, but sits high so strut towers don't seem to be an option, and because it sits high, it isn't a tight package, but it does have a cleaner look without having those cooling lines, also cleaner with the straight intake pipe and the larger filter. Overall, the Edelbrock has the better setup, in terms of looks and cleanliness, again, IMO.
I have modest goals for when I finally go FI, but when I do I will need to go CARB legal, so this kit is out. If I wasn't going CARB legal then TURBO! because TURBO! I was a Supra owner at one point, so I feel TURBO! biased. I know there is a CARB legal turbo kit, but I don't like the rear mount turbo and top mount cooler, and in general I am not a fan of the front mount kits that are not CARB legal; I like something that looks clean too.
But...if this kit was CARB legal, and if it had a clean large intake like the Edelbrock kit and if the cooling lines were fixed then this would be the kit of kits. Probably the cleanest looking, and one of the best performing.
My solution would be to make a bracket that goes in the front of the cooler lines and essentially ''L'' routes the lines cleanly off the side, so it hides their existence. Essentially it funnels the fluid inside a chamber versus running hoses across the top of the engine. Seems like an aesthetic no brainer.
Irace86 is offline   Reply With Quote
Color difference between Satin White Pearl (Pre-2015) and Halo White (Post-2015)? LucidMomentum Scion FR-S / Toyota 86 GT86 General Forum 3 10-15-2014 12:29 PM
To build something better in our own self image Rocket.BRZ Off-Topic Lounge [WARNING: NO POLITICS] 29 07-07-2014 05:56 PM
Nissan to enter 2015 24 Hours of Le Mans + 2015 FIA WEC mav1178 Other Vehicles & General Automotive Discussions 1 05-23-2014 11:47 PM
looking for silhouette frs image subaruferrucci FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 01-29-2013 07:00 PM
Image resizing blalor Site Announcements / Questions / Issues 28 11-03-2012 09:46 PM
