#15 |
Dude, I have ksport, I know people will disagree with me, but the adjustability is there, and it is greatly noticable, I actually like a stiffer ride, some might disagree, but with the right camber and the right drop, you might not have to spend 3000+ on suspension upgrades and adjustments. Yea you can pay 2500 for kw and the control arms, rear toe, bolts and not to mention install and alignment. Your choice bro
Just a clean BRZ |
#16 |
Junior
Drives: a car
First set of coilovers? Have you ridden on anything other than KSport or stock?
#17 |
Yessir, tein in the past, and my friends kw frs. Yes it's more comfortable and of course better quality. But again we are talking about under 2000 for the guy, I don't know if that's the total budget or just for coilovers. I can only give my feedback on products I've tested. So many on this forum would obviously say kw, and that's the most logical choice. I personally do not have a problem with ksport. It had held up great 5000 miles, no weird occurrences, it is aggressive when I would like it to and softer and still responsive when taking those long road trips. I'm currently almost maxed out with these ksport and for dd, I would recommend them. Speed bumps, horrible roads, tight corners, maneuverability, all have performed well with these coilovers, not everyone has 3000 to spend on coilovers installs, and not everyone is autox. And I know what most will say, "save up" yea sure let me save up for who know how long just to install some coil overs. But again this is my opinion.
Just a clean BRZ |
#18 |
Junior
Drives: a car
You can get a set of KW V3 for just under 2k new from fteightysix.com
#19 |
This is true, +install+lca+rear toe link+alignment.
Just a clean BRZ |
#20 |
Junior
Drives: a car
LCA's arent required on everything. Camber bolts/plates will do just fine in some cases.
#21 |
For the rear?? And the toe.? When o first lowered mine it required toe links also. But yea kw are good, go for it.
Just a clean BRZ |
#22 |
You really don't "need" any of those extra parts for daily status, but what you just stated is for every other coilover setup or even stock per say so that argument is invalid. Price mostly comes from purchasing damper quality, reliability, and consistency.
| The Following User Says Thank You to CSG David For This Useful Post: | cdrazic93 (04-14-2014) |
#23 |
Junior
Drives: a car
nope. I was told by some reputable shops and members on here that any drop less than an inch, the OEM rear control arms are fine, sure you can replace them. they cost hundreds for not much adjustment needed. Whereas there are cheaper options within that adjustment range.
#24 |
To each it's own, not bashing kw, they are by far one of the best, but as for me I have no complaints on mine for dd, and some twisty roads, not dissapointed. Not bouncy, comfortable depending on the settings, obviously it your building a race car neither kw or ksport are appropriate for and real track car, it's all about finding a median, and also ones future plans with the vehicle.
Just a clean BRZ |
#25 | |
#26 |
In terms of daily driving
Just a clean BRZ |
#27 |
#28 |
This is true, that's why it's important to dial everything in right. Make the proper adjustments and a lot of testing.
Just a clean BRZ |
| Coilover options, too many! | Ongor | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 01-21-2014 06:39 PM |
| Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 01:53 PM |
| Stiff coilover options? | YDNA | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 03-05-2013 10:33 AM |
| 86Drift Coilover Options for Australia | 86drift | Australia Classifieds | 8 | 02-27-2013 06:11 AM |
| Eibach Coilover Options - SEMA 2012 Coverage | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 01-25-2013 08:19 AM |
