Old 10-29-2015, 10:11 PM   #1
Brooklyn
Brooklyn's Avatar
Drives: 2014 DGM BRZ
Exhaust Tip - broken bolts
So I bought some GT86 exhaust tips and when I tried loosening the 10mm bolts on my existing ones, they felt seized. So I PB blasted them and tried again, and when I did, the bolts broke.
So...what do I do now? There is no exposed piece or part of the bolt I can grab onto on the exhaust tip.
Brooklyn is offline   Reply With Quote
Old 10-30-2015, 12:20 AM   #2
red18
EasyOut? Or maybe a Dremel and just cut a slot around the bolt to slide the tip off?
red18 is offline   Reply With Quote
Old 10-30-2015, 12:25 AM   #3
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Or you can cut a slot in it with a dremel and use a flat head to unscrew it further.
jawn is offline   Reply With Quote
Old 10-30-2015, 12:54 AM   #4
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Try pulling on them and see if they'll slide out.
N1rve
Old 10-30-2015, 09:09 AM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
What we do at work is drill out the remaining bolt then use the next size up tap/bolt.
But in this case I would use a dead blow mallet and make the bastard come out. Sure it would gouge the pipe but you'll never see it nor any one else if you put another tip on.
The Following User Says Thank You to Mr.ac For This Useful Post:
jbailey8748 (10-31-2015)
Old 10-30-2015, 09:15 AM   #6
jvincent
jvincent's Avatar
I had this happen to me as well. I opted for the brute force approach and just used the claw of a hammer and beat the shit out of it until it slid off the pipe.
A more rationale approach would have been to use a cut-off wheel on a dremel or drill and cut the bolt off between the pipe and the old tip. More sparks, less banging.
Old 10-30-2015, 10:24 AM   #7
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Honestly even if the bolt came out cleanly I found the tips really difficult to remove. They are sort of crimped on there. I had to seriously fight with mine for an hour to get them off.
ajcarson11 is offline   Reply With Quote
Old 10-30-2015, 11:03 AM   #8
starbot
Drives: Beep Beep
This happened to me when I over-torqued my bolts. I was lucky and was able to use pliers to grab the threaded-side of the bolt to loosen it from there.
If I remember correctly, I slid under the car head-first, so I was looking at the opposite side of the exhaust tip (the part that faces the front of the car). If you shine a light, you should see the threaded bolt that some pliers can reach to.
starbot is offline   Reply With Quote
Old 11-03-2015, 09:27 PM   #9
BRZnut
Drives: BRZ DGM Limited
I had this happen when I replaced the small stock tips with some nicer looking ones from Perrin. What I did was get behind the lower edge of the tip with a screw driver and then pulled down and back at the same time. The lower bottom of the old tip bent and allowed the broken screw to come clear of the pipe. Then I just slide them off. Took some force pulling down with the screw driver, but it worked
Old 11-03-2015, 09:30 PM   #10
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Good on you, I just swapped mufflers with the guy I sold the tips to
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
Old 11-04-2015, 12:40 PM   #11
Crows
Drives: 2014 BRZ Limited
Mine just twisted off when trying to take them out. Looks exactly like yours. I took my new tips into a garage, and they put them on for $20
Crows is offline   Reply With Quote
Exhaust bolts working off over time? frosty288 Engine, Exhaust, Transmission 4 09-28-2015 10:55 AM
Broken Exhaust Stud During FP Install EvoPrecision8 Engine, Exhaust, Transmission 28 03-31-2015 03:21 PM
DIY Video - Perrin Exhaust Tip Install! (and how I dealt with broken OEM tip bolts) CruiseControl DIY (Do-It-Yourself) Guides 3 06-25-2014 09:05 PM
Broken Bolts changing control arm! benlevy3 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 10-29-2012 04:07 PM
Exhaust Tips & Broken Bolt eriktherod Cosmetic Modification (Interior/Exterior/Lighting) 0 08-07-2012 12:48 AM
