Old 07-01-2015, 07:04 AM   #1
Calum
That Guy
Drives: 2013 asphalt FRS MT
Rigid Collars?
Ok, I'm starting another thread so I don't crash the party in the other thread.
Are these for real? This seems like snake oil to me. I've removed subframes and other than a witness mark from where the bolt head contacted there's no marks at all. If the subframe were moving, even slightly, there would be indications of that, wear patters in the paint. But there isn't. Every time I try to look for a review of these things it's always an overly detailed and long winded review, which leaves me wondering about the motivation of the reviewer.
Can any of the OG's on here attest to the effectiveness of these?
Old 07-01-2015, 07:31 AM   #2
Wyattkb
Drives: 2014 Whiteout FRS
Please see this thread http://www.ft86club.com/forums/showthread.php?t=90452
Lots of information there, as well as a video.
Wyattkb is offline   Reply With Quote
Old 07-01-2015, 09:26 AM   #3
endless_pain
Pissin off regressives
endless_pain's Avatar
Drives: They have engines.
I think that's the party he doesn't want to crash.
endless_pain is offline   Reply With Quote
The Following 5 Users Say Thank You to endless_pain For This Useful Post:
Calum (07-01-2015), Captain Snooze (07-01-2015), hmong337 (07-01-2015), Hyper4mance2k (07-01-2015), WhiteFRS69 (07-01-2015)
Old 07-01-2015, 09:31 AM   #4
Wyattkb
Ahhh
The info there looked pretty informative.
I believe the CSG guys use some sort of collar and could inform you with a somewhat unbiased opinion. They are very knowledgeable on everything ZN6 related.
Old 07-01-2015, 10:01 AM   #5
Calum
That Guy
Ahhh
Here's part of what makes me thing this might be bull shit:
Watch the video carefully it's pretty obvious that the cars were originally traveling at different speeds and the video speeds were adjusted to make them look the same. In the bottom image you can see a sort of ghost image as the tire is approaching the bump, but as the car drops off the car drops off the bump the ghosting slows and stops. Also, the two cars aren't perfectly lined up so it's hard to tell, but it looks like the bottom car starts to lag behind more at the end. To me, it looks like they sped the car up a little in the bottom image so it wouldn't come to a complete stop and used the brakes to prevent the rebound.
But I'm not a professional.
Old 07-01-2015, 12:23 PM   #6
fika84
fika84's Avatar
The subframe is moving because of the softer rubber bushings (you won't see "signs" of wear)... the idea is to remove the slop. I did the whiteline rear and you can ABSOLUTELY feel the difference when you go into a corner. The entire rear end is more planted and solid.
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
Old 07-01-2015, 01:17 PM   #7
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Apples & oranges. The front subframe doesn't have any bushings. That's what is in question here. It's clear that the rear subframe benefits from harder bushings rigid collars, what ever to prevent movement, but is the front subframe actually moving? I have no idea. I've dropped countless subframes in FB & FC Rx-7s -which are also hard mounted, and I've never seen signs of movement.
Will it make a difference? Probably. Is that difference quantifiable? Probably not.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following 3 Users Say Thank You to Hyper4mance2k For This Useful Post:
Calum (07-01-2015), fika84 (07-01-2015), wparsons (11-02-2015)
Old 07-01-2015, 01:25 PM   #8
fika84
fika84's Avatar
Gotcha.
Old 07-01-2015, 02:09 PM   #9
Mark@S
Mark@S's Avatar
Drives: 2015 Subaru BRZ - DGM 6MT
*We have not done any quantitative testing on these and this is not the view of STILLEN*
I have personally driven a BRZ before and after the rigid collar installation. I can definitely feel a difference. It is hard to describe completely, but the car does feel more solid with them and the front suspension felt a little more responsive.
SpeedHunters did a review on them as well. Can probably find it with the Googlez
Mark@S is offline   Reply With Quote
The Following 3 Users Say Thank You to Mark@S For This Useful Post:
Calum (07-01-2015), Hyper4mance2k (07-01-2015), mokinbird87 (11-02-2015)
Old 07-01-2015, 02:16 PM   #10
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
I don't think rigidity or prevention of movement are the goals of this product at all. From what i understood, the collars center the subframe on its mounting holes, and ensure that the subframe is parallel to the monocoque, which would add symmetry to the alignment. Rigidity would be helped a little bit by pre-stressing the mounting locations in the presence or absence of tolerance stack up.
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
The Following 3 Users Say Thank You to 200hp/tonne For This Useful Post:
Calum (07-01-2015), Hyper4mance2k (07-01-2015), Shankenstein (07-01-2015)
Old 07-01-2015, 04:43 PM   #11
CSG Mike
CSG Mike's Avatar
It absolutely is. It's so obviously different on a car with an exhaust that even someone who is not into cars at all will notice a difference. The giveaway is that because everything is now "attached", the harmonic resonance frequency of the entire car changes.
Every car has a resonance frequency where stuff just... vibrates, and an exhaust helps reveal this vibration. At a certain RPM, you'll notice vibrations. Once rigid collars are in, that RPM where stuff vibrates changes.
CSG David's had Rigid collars on his s2k before the FT86 was even around.
GT86_PRAGUE (07-02-2015), mokinbird87 (11-02-2015)
Old 07-01-2015, 04:56 PM   #12
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Well unless you can provide numbers which show the reduction in variation between L&R suspension movements before and after install, or an increase in chassis rigidity, or etc etc... then these are in fact not quantifiable. You can give all sorts of qualifying statements that these, without a doubt, increase handling feel and chassis response. I, with no doubt, believe that these work and will help change the way the car feels, but providing quantitative data that says so would prove to be difficult.
That being said, I want some, and I want them now. I'm supposed to get aligned on Friday for the event at Big Willow on 7/11. When can I come pick them up? LOL
Old 07-01-2015, 05:17 PM   #13
CSG Mike
CSG Mike's Avatar
That level of data is far, far beyond CSG's budget, so it won't be happening, at least, not from us.
The harmonic frequency analysis is so obvious that a quantified log isn't necessary. It's THAT obvious.
Old 07-01-2015, 05:25 PM   #14
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Well put!
It's not going to prevent your front subframe from sliding around, because it's not currently sliding around.
The front subframe is rigidly attached, but from people's pictures, it isn't always well-centered. Precisely aligning the mounting points will make your geometry more symmetric. That's a good thing (except for your alignment tech who can't use this as adjustment anymore). 1 mm can be a big distance when you're talking about finicky suspension points.
These collars are very unlikely to hurt performance... but there's no guarantee they will help significantly either. The value that a resonant frequency shift presents is up to you.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following User Says Thank You to Shankenstein For This Useful Post:
CSG Mike (07-01-2015)
SPOON rigid collars install mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 11-16-2015 04:24 PM
Need help removing collars off coilovers DonZilla Southern California 1 01-14-2015 08:00 PM
Fs: brand new pbm subframe collars Guildjs Brakes, Suspension, Chassis 3 10-16-2014 09:54 AM
T1R Differential Collars Mikepage Engine, Exhaust, Transmission 0 05-01-2014 10:18 PM
