Old 02-17-2016, 05:39 PM   #1
Fricke
Drives: Toyota GT86
Stock pistons "rate ore hate" ?
Going Supercharged next race season (2017) and of course i want a forged bottom end.
But planing on keep the stock compression ratio, and that's were my thoughts wonder of
Why spend money on something that's seem to do the job?
Is there even any of you in here that have suffered from blown pistons on FI? (Don't mean NASA astronomical hp outputs now)
Why just don't get forged rods, gasket set and bearings and go whit oem pistons, the car wouldn't go past what a HKS V3 or Jackson kit deliver on E85 anyway.
Fricke is offline   Reply With Quote
Old 02-17-2016, 05:43 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Well if your already in there, may as well replace them
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
Dream20b (02-17-2016), texasbound972 (02-21-2016)
Old 02-17-2016, 06:36 PM   #3
Bykov
Drives: 2014 Monogram FR-S Whiteout
True Chainz
Bykov is offline   Reply With Quote
The Following 3 Users Say Thank You to Bykov For This Useful Post:
go_a_way1 (02-17-2016), Guff (02-21-2016), MrFisty (02-21-2016)
Old 02-17-2016, 07:21 PM   #4
blueap2
Drives: '14 FR-S
My thought process too, OEM pistons haven't failed.. For mild HP (less than 400WHP) why not keep OEM ones.
Swapping out means boring and honing block, sizing new rings, and messing with piston to wall clearances.
Would love to hear some feedback other than "already in there" assuming the labor to pull the engine and opening it is not considered..
blueap2 is offline   Reply With Quote
Old 02-17-2016, 08:30 PM   #5
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
In for answers on this. I'm curious as well. I'm considering building my motor as some point to be reliable enough for the amount of power a JRSC with high boost pulley can make on E85.
xsnapshot is offline   Reply With Quote
Old 02-17-2016, 10:08 PM   #6
mrk1
Drives: Sterling BRZ Ltd
I would talk to shops and get build quotes. I would be surprised to see someone open a motor and not hone the cylinders and install new rings, even when reusing pistons. I'm just not seeing much of a savings.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 02-17-2016, 10:16 PM   #7
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
Wasn't there a design change to the pistons after the early cars? I seem to remember reading about later pistons having more skirt added to them to keep them better aligned in the cylinders.
If anything I just said is true and you have an early car, then go with pistons of the newer design.
-Justin
Justin.b is offline   Reply With Quote
Old 02-18-2016, 02:04 AM   #8
Fricke
Drives: Toyota GT86
But this is the thing for me.
I'm not afraid of doing the engine my self (that's the fun part of you asked me) have som experience of the EJ257 in the past.
So there will be no shop doing the engine, and there for it will be cost effective for me to djust mark the pistons to keep track of where they were, hecke it's a low mileage car/engine so why even bother honing the cylinders and change the piston rings, if I don't see too much wear on the cylinders and piston/rings off course.
And yes I have gone that road before, the motor is already apart, change everything, but not this time around I guess, do there seems to be nothing wrong whit the oem ones, on moderately power goals
Old 02-18-2016, 02:44 PM   #9
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Pistons need to come out to change rods. There are no wrist pin access holes like the ej series. Not a big deal but just letting you know.
Stock pistons will give up around the wrist pin if they do fail, but you should be fine on non-astronomical power levels.
Few people have lifted the heads somewhere in the vicinity of 400. ARP fasteners and all that are a no-brainer on any build.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
Fricke (02-18-2016)
Old 02-18-2016, 02:46 PM   #10
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
when you remove the pistons and rings, they will not be in the exact same orientation that they mated to the bore in when you install again.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 02-18-2016, 02:48 PM   #11
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
the main thing with changing the pistons is that it allows you to drop the compression ratio which is very necessary for big power builds but otherwise I'd agree the stock item is well made and not the weak link of this engine
Matt@Cosworth is offline   Reply With Quote
The Following User Says Thank You to Matt@Cosworth For This Useful Post:
Fricke (02-18-2016)
Old 02-18-2016, 04:51 PM   #12
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
I don't see anything wrong with stock compression on big power builds. We've got folks running forged 12.5:1 compression pistons with over 600whp.
Sincerely,
Zach
The Following 8 Users Say Thank You to DeliciousTuning For This Useful Post:
ATL BRZ (02-18-2016), CSG Mike (02-18-2016), DriftinFRS (02-19-2016), Fricke (02-18-2016), Guff (02-21-2016), texasbound972 (02-21-2016), TheMedakaBox (06-01-2016), wparsons (02-19-2016)
Old 02-18-2016, 05:44 PM   #13
Fricke
Drives: Toyota GT86
Yes did notice that on the FA20, butt personally I don't think that the absence of galley holes/ service holes is a biggi
Yeah will go over the heads to and look over the rockers and beef upp the valve springs
Old 02-18-2016, 05:52 PM   #14
Fricke
Drives: Toyota GT86
Piston rings are not locked down and are freely to rotate on the piston.
But I under stand what you mean.
But i find it highly unlikely that the cylinders has warped on a low mileage car, so that the piston rings has gotten the egg shaped to.
But off course I can measure the cylinders (don't know how to spel the measure meant tool and procedures in English )
Low compression "Drop-in" pistons? autobot84 Forced Induction 10 10-12-2014 06:33 AM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Any alternative for the "opposed pistons" on the front fenders? NOHOME Cosmetic Modification (Interior/Exterior/Lighting) 6 10-01-2012 02:58 PM
