Old 06-09-2012, 10:31 AM   #1
EmilGH
FIA Licensed Rally Driver
EmilGH's Avatar
Drives: Lots...
Send a message via ICQ to EmilGH Send a message via AIM to EmilGH Send a message via MSN to EmilGH Send a message via Yahoo to EmilGH
Blinker/Hazard Relay Location
For anyone doing some LEDs for blinkers… Here's where you can find the relay.
It's under the dash. Handing from a clip. 2 screws. 2 panels. You'll find it…
EmilGH is offline   Reply With Quote
The Following 2 Users Say Thank You to EmilGH For This Useful Post:
Astroboy (09-09-2015), ShoGun (08-19-2012)
Old 06-10-2012, 07:44 PM   #2
96z2
Drives: N/A
Thanks. Can you post a video of those LEDs? Curious how they look when lit.
96z2 is offline   Reply With Quote
Old 06-10-2012, 10:01 PM   #3
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
Yeah, I'm also curious! Did you also change the front LEDs?
Lil Abner is offline   Reply With Quote
Old 06-16-2012, 10:48 PM   #4
Lil Abner
Hey man, where did you get those LEDs, and which flasher module did you use?
Old 06-17-2012, 01:21 AM   #5
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
are those the the oem jdm LEDs??
86_ZN6 is offline   Reply With Quote
Old 06-17-2012, 07:42 AM   #6
Lil Abner
Actually, I think they are from V-LEDS.com. But I'm curious how visible they are during the day...
Old 09-04-2012, 04:42 PM   #7
jadewbj
jadewbj's Avatar
Yes, what relay did you use. I want to order one and make sure it fits and works.
jadewbj is offline   Reply With Quote
Old 09-10-2012, 10:10 AM   #8
jadewbj
jadewbj's Avatar
I put my relay in this weekend. The panels came right off without an issue. I thought "this should be done quickly", boy was that a mistake.
It took near impossible feats of yoga to squeeze my fat ass under the dash to reach the flasher relay. Then my giant hands could barely snake their way through the underside of the dash. My hand is cut to shit from trying to pull that sucker off to unplug it.
I almost gave up and said "that hyper flash isn't that bad", and buttoned the dash up. The relay finally came loose and the rest was a breeze.
I am just waiting for my led rear bulbs and switchbacks to come in. Then it will be all worth it.
Thanks for the location info.
Old 09-08-2015, 02:23 AM   #9
Astroboy
Astroboy's Avatar
Drives: None
Is this where I place the control module that came with my leds in order to be able to control the blinker light timer
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 09-08-2015, 02:33 AM   #10
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Yes
The Following User Says Thank You to ZOMFGAARON For This Useful Post:
Astroboy (09-08-2015)
Old 09-10-2015, 05:41 AM   #11
Rookie84
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
I had a very similar experience... TOM'S tails come with new flasher relay so I went to install it after I installed the tails... expecting simple unplug and plug in which would take 10 seconds. Boy, I was wrong. I was getting so frustrated and got to the point that I nearly would not have minded for breaking things just to get this flasher off
Luckily I got it to come off without having to break anything.... haha. But yeah, my hand was also cut to shit.
Rookie84 is offline   Reply With Quote
Old 09-10-2015, 09:09 AM   #12
Max FRS
Drives: 2015 Halo FRS Automatic
To make it easier there is a metal plate held on with two 10mm bolts under the instrument panel cover. I too got cut up removing the relay and then took the metal plate off and it was still tight but much easier to move around and no cuts and scratches. My hands looked like I tried to separate two wild cats before removing the plate. Could have prevented most just by removing the plate. I've been in there several times since and I always remove that plate.
Max FRS is offline   Reply With Quote
The Following User Says Thank You to Max FRS For This Useful Post:
Astroboy (09-10-2015)
Old 09-10-2015, 02:20 PM   #13
Astroboy
Astroboy's Avatar
Drives: None
I did this last night lol.
The Following User Says Thank You to Astroboy For This Useful Post:
Prodigalson (03-11-2025)
SoCal BRZ/FRS Future Owners meet, May 10th, now with poll for location (OC,LA,SD) Mike Southern California 32 05-11-2012 06:47 PM
Front License Plate Location Polish Person Scion FR-S / Toyota 86 GT86 General Forum 44 12-16-2011 12:04 PM
Internet Relay Chat (IRC) Channel Sony Off-Topic Lounge [WARNING: NO POLITICS] 10 11-03-2011 11:36 PM
FT86 On Location at Brussels ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 3 03-25-2011 02:12 PM
