Old 12-04-2015, 01:10 AM   #1
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
2016 Aftermarket HU - Stock Wiring
So I just tore open the dash to install my Pioneer HU and everything is connected but the door speakers don't work. Rear and dash tweeters and mids work great. I suspect there's a factory amp, but there is no wire in the #9 position of the 10-pin harness. The #8 position I have connected to the antenna turn on wire of the HU. I've also tested it with switched 12V to be sure. I'm not sure where to go from here.
Luftwaffel is offline   Reply With Quote
Old 12-04-2015, 12:53 PM   #2
Chimera
Drives: FRS
make sure your remote out from the HU is wired to the harness that goes to the car to enable the stock amp.
Old 12-04-2015, 01:36 PM   #3
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Yeah that's the point. The car has the wire for antenna amp but not audio amp.
Old 12-04-2015, 03:28 PM   #4
StegaDragon
StegaDragon's Avatar
Drives: 13 Sc10n FR-S
Pin 9 should be the amp signal wire
Don't know if it's a 5v signal though
SC10N driver
StegaDragon is offline   Reply With Quote
Old 12-04-2015, 04:43 PM   #5
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Again, there is no wire attached to pin 9 on the factory wiring harness.
Old 12-04-2015, 05:02 PM   #6
StegaDragon
I personally just took the amp out and jumped the pins
SC10N driver
Old 12-04-2015, 05:12 PM   #7
Luftwaffel
Boost Creep
Luftwaffel's Avatar
I have that same manual, on the phone I'm posting from, in fact. It's apparently not fully applicable to this model year.
Old 12-04-2015, 05:56 PM   #8
StegaDragon
Wait your car is a 2016?
SC10N driver
Old 12-04-2015, 05:58 PM   #9
StegaDragon
Then it's pin 9 of the extra connector that doesn't get used
SC10N driver
Old 12-04-2015, 06:13 PM   #10
StegaDragon
Sorry I was looking at the 2013 diagram for my car but it changes from connector "B" to "A" on the 2016
SC10N driver
Old 12-04-2015, 06:59 PM   #11
Luftwaffel
Boost Creep
Luftwaffel's Avatar
So that would make it D12 (28 pin), pin 9, brown wire then?
Old 12-04-2015, 07:26 PM   #12
Luftwaffel
Boost Creep
Luftwaffel's Avatar
K one more question, how do I buy you a beer? You were absolutely correct.
Old 12-04-2015, 07:32 PM   #13
StegaDragon
Yup yup glad I could help, enjoy
SC10N driver
Old 12-06-2015, 03:11 PM   #14
vidarw
Drives: GT86 High
What kind of manual is this?
vidarw is offline   Reply With Quote
Using factory wiring for aftermarket fog light kits Wizardhat Cosmetic Modification (Interior/Exterior/Lighting) 8 12-05-2021 05:05 PM
Aftermarket Headunit to Factory wiring harness? Dadhawk Electronics | Audio | NAV | Infotainment 9 11-13-2015 12:23 PM
Stock amp/wiring questions Matey Electronics | Audio | NAV | Infotainment 5 08-22-2015 09:28 AM
FRS aftermarket head unit installation - wiring MindtheGap Electronics | Audio | NAV | Infotainment 35 01-14-2013 10:00 PM
P8400 Aftermarket deck HELP NEEDED WITH WIRING iamkyle Electronics | Audio | NAV | Infotainment 1 01-13-2013 04:41 AM
