Old 04-04-2023, 12:59 PM   #1
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
To reuse or not to reuse
After reading some not so great things about Motul gear300 in our transmission I decided to swap it out for AMSOIL Synthetic Manual Transmission and Transaxle Gear Lube
When I put in the gear300 6 months ago I used brand new oem washers.... So should I buy new washer again or just send it ?
Thanks
autoracer86 is offline   Reply With Quote
Old 04-04-2023, 01:40 PM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Always use a new washer.
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
autoracer86 (04-04-2023), Jdmjunkie (04-04-2023)
Old 04-04-2023, 01:46 PM   #3
WNDSRFR
Drives: FR-S,GTI
I know that the crush washer manufacturer's lobbyist group says to change the washer every time. But I don't. I did the first time out of an over abundance of caution. But I've reused the washers ever since. I've change the tranny and diff 3 times and the oil many, many times reusing the washers and never leaked a drop.
But Hey, it's your car.
Old 04-04-2023, 02:01 PM   #4
autoracer86
Drives: Toyota GT86
Yeah..... that is kind of my thinking it doesn't help the OEM washers are like 16bucks each lol
Old 04-04-2023, 09:09 PM   #5
Grady
Grady's Avatar
O rings, crush washers it is good to replace every time. It is overkill lets face it worst thing that will happen is you will have an oil seep.
Old 04-05-2023, 11:27 AM   #6
autoracer86
Drives: Toyota GT86
I ordered 2 new washers with my dealer today. I was not man enough to risk it lol
The Following User Says Thank You to autoracer86 For This Useful Post:
Clipdat (04-05-2023)
Old 04-07-2023, 08:23 PM   #7
Griever423
Drives: 2020 BRZ PP
Thanks
This is the first I've read about Gear 300 not being good for our trans'. Do you have a link to that particular discussion?
Griever423 is offline   Reply With Quote
Old 04-07-2023, 09:07 PM   #8
autoracer86
Drives: Toyota GT86
I don't have any saved off hand. But the TLDR is gear 300 is a GL4/GL5 oil. Our boxes are rated for GL3 but will take a GL4. The thinking here is that whatever is in the oil to get the GL5 rating could cause harm to the brass synchro's. Some people went as far as to say the gear300 is not even a GL4 at all.
I found more than one posts about it... Most people seem to switch over to redline MT-90 and Amsoil which are both GL4 only fluid.
I am nervous enough about blowing 2nd gear on track that I don't need to worry that the oil I use might be causing issues as well.
Old 04-10-2023, 04:58 PM   #9
RedReplicant
Drives: None
I've been happier on the MT90 over the Gear 300 anyway, it seems to shift better before everything is warmed up
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
autoracer86 (04-11-2023)
Old 04-11-2023, 12:08 PM   #10
autoracer86
Drives: Toyota GT86
MT90 will be the next if the amsoil(which just arrived today) doesn't work out.
What are you running in the diff ?
RedReplicant (04-11-2023)
Old 04-11-2023, 12:17 PM   #11
RedReplicant
Drives: None
Curious to hear how you like the Amsoil, I've never run it before
It has an OSGiken in it but I've been running Motul Gear Competition 75W140 since it is on the approval list.
Old 04-11-2023, 12:27 PM   #12
autoracer86
Drives: Toyota GT86
Ah okay. Thanks ��. I will make sure to post my impressions but as like as the gear box doesn't grind or blow up on track I will be happy lol
Old 04-15-2023, 11:38 AM   #13
autoracer86
Drives: Toyota GT86
Just quick update... Really loving the Amsoil so far glad I switched. Check out the build thread if you want more details.
Clean and Reuse your Cabin air filter stevesnj DIY (Do-It-Yourself) Guides 15 06-25-2016 09:15 PM
Reuse or get new exhaust hangers? Atticus808 DIY (Do-It-Yourself) Guides 5 01-24-2016 07:15 PM
aux input reuse? pandora Electronics | Audio | NAV | Infotainment 0 08-09-2013 04:14 PM
Reuse your microfiber towels? (on your paint) Nate219BRZ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 07-31-2012 12:16 AM
Reuse the standard scion HU? motofan Electronics | Audio | NAV | Infotainment 0 06-18-2012 05:56 AM
